Poll: Are you Satisfied with the Prius Seats ?
Discussion in 'Gen 3 Prius Main Forum' started by cycledrum, Jul 2, 2013.
  1. Fine, and I'm glad I was not forced to pay more for a power seat
    57.7%
  2. Good enough for my Use, although I am sore after a trip longer than 3 hours
    16.9%
  3. So so; I would have been happy to pay $500 more for power seats
    12.7%
  4. So so; I would have been happy to pay $1000 more for power seats
    1.4%
  5. The seat is a problem; I would have been happy to spend $500 more for power seats
    11.7%
  6. The seat is a problem; I would have been happy to spend $1000 more for power seats
    4.7%
Multiple votes are allowed.
  1. davekro
    davekro Member
    493
    68
    SF Bay Area, East Bay
    2013 Prius Plug-in
    cycledrum,
    Thanks for the information and picture. That color does seem like a perfect match, sweet. The center console mount looks good. Are you happy with it? I believe you put a foam lumbar pad (from Bob's awesome Foam Factory :cool: )behind the drivers cover, right? Any info you can share on how you secured the 'cushion' in place or other ideas on cushions under seat covers would be appreciated. What thickness, length/width and type of foam did you use?
    I have temporary auto parts store cloth covers now. As a trial for my cushion, I used blue painters tape to hold it in place (not a permanent solution). From Bob (Santa), I first got a piece of 1/2" neoprene (9" H x 16"W IIRC), then a few weeks later stopped by to get a 1/4" piece of same (6" H) to add to it. It is a good thickness for me (3/4" total). But I am now looking at an adjustable 'air bladder' to try. I am a bit more concerned with how to hold that bulkier item 'up' under a cover, how you supported yours is of interest.
    I am looking at the Rostra 250-1454 Front Mount Comfort Seat Pneumatic Lumbar Support System.This powered.
    $86.85 on Amazon. Someone mentioned it had internal foam that was too thick. I have not herd back from him on it's compressed thickness. I will Call Rostra on this. They were very helpful letting me know why the 'rear' mount would not work for a front (of seats cushioning) mounting. (rear mount has a hard surface that would wear thru the seat cover)
    This hand pump version was recommended by a PC member on my 'Adjustable lumbar' thread*.
    * my thread: Did you: add 'Adjustable' Lumbar support or Replace drivers seat? | PriusChat
    Any additional pics later (y) would be cool.
    cycledrum likes this.
  2. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Seats need more thigh support for those with longer legs…. I find the seat too short for long trips…
  3. mrbigh
    3,686
    699
    Long Island, NY
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I have not added any foam behind the seat cover for lumbar. I get by without it. btw, the GT leather seat covers are working out great.
    I had a 1" x 5" x 8" piece of neoprene cut at Bob's for center armrest. Tried strapping it down on top of leather cover in two places, but didn't stay put so well. Tonight, I stuffed it underneath the leather armrest cover. I cannot get the cover to secure over the original armrest, so I put one strap near the front. Looks a little funky, but the foam underneath stays in place and I have a 1" lift. Function over form.
    Note - Seat cover color not accurate in this photo. dark in garage and flash does funny things.
    I had two 1.5 x 2 x 4 inch neoprene and two 1.5 x 3 x 4 cut at Bob's. Stack one of each to make 3 inch lift on door armrest. So, the center and door armrest heights are fairly even and make 8 and 4 o'clock grip doable.
  5. pamm13
    pamm13 New Member
    Alabama
    I answered the poll that I would pay more for power seats based on another vehicle that did have power seats (not a Toyota). I think the issue is due to my height. I am 5'2" on a good day and my thighs are hitting the front of the seat creating discomfort. I think that would not be the case if my legs were longer. I do a lot of long distance and that is when I have issues. In other cars the solution was to adjust the front of the seat as far down as possible and the back of the seat up. Sounds like it might be uncomfortable, but it did relieve the pressure and gave me the height I needed.
    So for me, in previous cars the power seats offered a greater range of adjustments and I benefit by that. I am going to try padding the back of the seat and using a seat cover to keep it in place. I think that might do the trick based on some of the other replies I have read. Wouldn't trad my Prius for any other car with or without power seat though. Great car.
  6. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    was given a 2014 Corolla Type S as a loaner last week by my dealer, and could not wait to get my Prius back.
    While the Corolla was very fast, and handled like a dream - the seats are nowhere near the comfort level of my 2010 Prius III
  7. Den49
    Den49 Member
    498
    272
    Maryland
    None of the aftermarket seat covers, pads, cushions, etc. are a good solution for when the seat doesn't fit you. They slip and slide, get in the way and create more problems than they are worth. Better to fix the seat itself. Your situation sounds like it could be helped and solved by inserting high density upholstery foam inside the OE seat cover to change the height, thickness and/or seat curvature. I have done this on many cars over the past twenty-five years, including my current Prius. It always works for me. See how, starting in post #55 post of the below thread:
    Seats too relaxed/reclined?! | Page 3 | PriusChat
  8. ursle
    ursle Gas miser
    1,049
    192
    NH
    Can actually see the pole for the first time, it was amusing until now...but, none of the choices fit, you can only vote to complain not to compliment, why am
    I not surprised?
    Just another troll's thread;)
  9. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    #1) The first choice in poll is for people who are fine with stock seat
    #2) I didn't create the poll. another did and the thread was merged with the videos I posted in post #1
    #3) Enjoy telling people to solve their seat problems by merely sittingup and not slouching cause that's what you do best. :p
  10. maynard
    maynard Junior Member
    I have a 2013 prius II and have owned it for 3 years now and 74k miles. it is a torture chamber. problems i never had before are now very serious and toyota does not want to help at all. i have lumbar and lower back pain, sciatica in both legs, serious hip pain in my left hip. it is caused by the tilting when lowering the seats. they do not stay level and tilt back when lowering. a flat out ignorant design. toyota refuses to offer any help. they should retroactively add in the power seat. been a loyal toyota owner for 30 years but never again.
  11. BZzap!
    BZzap! Senior Member
    1,607
    878
    IMO, it's not the seats are so uncomfortable as the fact that they cannot be adjusted correctly. When lowered or raised, the front of the seat just pivots at one point. How stupid is that?
  12. bisco
    52,124
    free power seat if i complain? i'm in! or do i need a note from my chiropractor?
    mrbigh and mmmodem like this.
  13. Friend of Bill W.
    109
    164
    Elkhart, IN
    I'm a big guy so yeah the seats are not the most comfortable. I've thought about trying to find a set of used Avalon seats, alter them.
  14. Myself248
    Myself248 Junior Member
    32
    Royal Oak, MI
    I'm fine with the driver's seat, it's one of the most comfortable I've ever driven. Higher front would be nice (I'm 6'3" and mostly legs), so I may try the washers mod from earlier in the thread. But even without that, I've taken multi-day roadtrips with no issue.
    I added some knee padding to the "flying buttress" by the shifter, because it's hard-nice person plastic and my knee rests against it. 4mm neoprene foam sheet with spraymount, just happened to be gray so it matches the interior. :)
    However, the PASSENGER seat is a major disappointment. My previous car was a Matrix with the fold-flat passenger seat for hauling cargo, and the Prius's ability to haul ladders and stuff is severely compromised without that. When I went to pick up a wide-format printer, I took along my socket set so I could REMOVE the passenger seat (and stuff it back in sideways), as it was the only way to get the printer into the car. I would happily pay a little extra for a cargo-conscious passenger seat and the rear hold-downs (tracks and hardpoints) that the Matrix had.
    (Incidentally if you remove the passenger seat, you have to unplug some airbags along the way. Driving the car with these unplugged will annoy the airbag module, so once you unload the cargo and reinstall the seat, you'll need to clear DTCs. Alternately, get a mating connector and the appropriate resistor value to make a "pacifier" for the airbag plug, but I don't do this often enough to care.)
  15. Tideland Prius
    16,582
    You could pay a little extra for a Prius v with an extra 6" of exterior length. (
