Navigation Question
Discussion in 'Gen 2 Prius Audio and Electronics' started by krainium, Mar 5, 2006.
  1. krainium
    krainium Junior Member
    57
    Northbrook, IL
    OK, I've read the manual and must be missing something. I have an '06 with navigation and am trying to remove the POIs for restaurants and hospitals so I can provide other voice commands to the Navi. My screen says I must remove current POIs to give additional commands, but I can't find a screen to do that with. What am I missing here?
    Pressing the delete POIs doesn't eliminate the symbols. Does anyone have a simple set of instructions for the NAV system like a "Navigation System for Dummy's" book? I sure need one as I have a very expensive tool that I can't seem to master very well. Thanks.
  2. XLR8
    XLR8 New Member
    161
    Las Cruces, NM
    Go to Voice mode and say "hide all icons". I don't know for sure if that's what you need...thinking so. That's what I know for now.
    Hope that helps,
    Aaron
  3. aaf709
    3,862
    2022 Prius Prime
    You should have a separate manual for the NAV system (I got one for my 2005). Mine's out in the Prius, but it does have something on that. As have the voice activation, you should be able to just press the button and say, "P-O-I off." Say POI as three letters, otherwise it'll add Hawaiian restaurants. :)
    Oh, so it's "Hide all icons" for the 2006? Live and learn.
  4. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    From the map screen, press the "map view" icon/button at the bottom. On the screen taht pops up, press the "display POI" icon. This will bring up a list of POI's (like restaurants, gas, etc). the ones that are currently being displayed will be highlighted. Simple pressing on the highleded ones will deselect them (in otherwords, ignore the "delete" button at the top).
    I probably would have been confused too if the guy at the dealer didn't show me this when i got the car!
  5. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    I also use the "Hide All Icon's" voice command to clear the POI's from the screen.
  6. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    I use the voice command "POI off."
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    For me "POI off" is the one most constant voice command that works every time.
  8. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    On my 2004, I find "POI" is enough.
