ev & eco indicator on at the same time?
Discussion in 'Gen 3 Prius Main Forum' started by StarCaller, Mar 7, 2014.
  1. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    that's the normal thing?
    like when I accelerate from a stop, using the throttle only very lightly, the car stays in ev mode, but the eco indicator is on, too.
    (I confirmed with torque, that the ice is not running)
    should it be this way or should just the ev indicator light up?
  2. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    They're independent of one another.
  3. bisco
    52,763
    oh ya, ya. eco is a mode that controls throttle response and hvac. ev attempts to keep ice off when inside all control parameters. when you press eco/normal/power, it stays there unless you change it. ev can be selected or will fill in the icon when car auto enters it.
  4. StarCaller
    1,284
    733
    jdk2: that's what I thought.
    but every time my speed gets quicker than walking speed, the eco sign shows up (even with the ice NOT running).
  5. StarCaller
    1,284
    733
    bisco: no, I didn't mean the pre-selections, I meant the display of the current 'engine' state.
  6. bisco
    52,763
    eco should be on all the time. unless the '14 is different in some way.
  7. StarCaller
    1,284
    733
    so the ev sign will never be on by itself? (except when driving very slow)
  8. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    EV can be on and ECO off if PWR or Normal modes are selected. You'd still have EV on at low speed.
    ECO/PWR/Normal just sets throttle mapping. EV indicates that the car is being propelled by electric.
  9. bisco
    52,763
    i'm not sure if normal has an icon. if not, than ev could be on by itself.
  10. StarCaller
    1,284
    733
    are THOSE two indicators meant to be on at the same time?
  11. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    They can both be on at the same time or each can be on regardless of what the other one is displaying. They're totally independent of one another.
    ECO shows that you've depressed the ECO button on the dash at some time. EV shows that the ICE is not running. EV will also be displayed when you depress the EV button on the dash.
    Push the PWR button on the dash or depress the ECO button again and the ECO in your display will disappear.
  12. StarCaller
    1,284
    733
    now we're talking. I thought the eco sign will only come on IF the ice is running.
    BION
    STARCALLER
