  1. ckam1989
    ckam1989 Active Member
    185
    358
    Irvine, CA
    2014 Prius Plug-in
  2. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,460
    92
  3. ckam1989
    185
    358
    Irvine, CA
    2014 Prius Plug-in
    I got some prius toys from my sis for my bday : ) today.
    They're so adorableee. Came a set with 4 colors.
    I'm going to leave one in my car.
    Now to find some way to stick it to my dashboard without damaging it... hmmm.
  4. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    none at the moment
  5. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    clearance was not really an issue..... I was suppose to put on my other front lip that I have but decided to not to install any right now.....
    Dylan Doxey likes this.
  6. Chris S
    Chris S Active Member
    323
    111
    Gilbert, AZ
    Detailed it up after having the windows tinted; 35% front, 15% rears and a 5% windshield strip.[​IMG][​IMG]
    iPhone ?
    Dawit, jdk2, Dylan Doxey and 2 others like this.
  7. Southbound
    Southbound Member
    91
    29
    Palos Heights, Il
    Picked up a WeatherTech cargo liner, now have Weathertech mats throughout!
  8. Dylan Doxey
    1,389
    3,460
    92
    Looks Awesome
  9. Dylan Doxey
    1,389
    3,460
    92
    Today I added some washers to the driver side front seat mounts.
    I was able to add as many of seven of these without depriving the OEM bolt enough length to get a full bite of threads.
    I spend between two to three hours a day in this seat. I hope this is gives me enough tilt to ease the hot spot a little.
  10. Dylan Doxey
    1,389
    3,460
    92
    Also, I finally got my Shark Fin installed!
    Here's the before picture, featuring the OEM post antenna.
    While doing the dry fit I used some electrical tape to mark the alignment.
    Queue the Jaws theme music.
  11. LeMeowz
    LeMeowz Member
    NorCal
    Did the signal mirror install yesterday!
  12. CTitanic
    CTitanic Member
    153
    22
    South Florida, FL, US
    I replaced the ugly Toyota antenna for one of these
    During the installation I found that the actual antenna is just the bottom portion of the antenna, the two top fragments are just cosmetics. So to increase the reception I disassembled the antenna, removed the paint from the top of the actual antenna and used a spring to extend the antenna actual size.
    Here is a picture that will explain the trick by itself.
    I don't have any scientific way to measure the gain but living in South Florida it was enough to get some HQ FM stations.
  13. CTitanic
    CTitanic Member
    153
    22
    Today I completed my LED upgrade.
    I used the same LED bulb type to replace the one in the trunk (above) picture and the one in the back seat dome. Pushing away the contacts did the trick.
    Blue LED for the doors...
    Well, and I ended replacing the antenna, here is another picture.
    All these changes cost less than $30! And they improve the esthetics of the Prius a lot. Even KIA has learned that and they are applying it in the USA market. The PRIUS is a wonderful car but there is a lot to be improved in this field.
    Alan Ellis and Burna J like this.
  14. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    Finished installing clazzio leather seat covers. clazziofront2.jpg clazzioback.jpg My fingers will be sore for a while:)
  15. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Changed the reverse beeper to single beep, thanks Carista app
    ckam1989 likes this.
  16. Mikzwol
    Mikzwol New Member
    27
    Clovis, California
    just finished installing my tail 20140311_152316_HDR_1.jpg 20140311_152316_HDR_1.jpg 20140311_152316_HDR_1.jpg 20140311_152213.jpg 20140311_152316_HDR_1.jpg 20140311_152213.jpg 20140311_152316_HDR_1.jpg 20140311_152213.jpg lights
  17. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    They look sweet against that Black
    Mikzwol likes this.
  18. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Your exterior mods have made that car look great :)
    Mikzwol likes this.
  19. striker308
    302
    43
    Thanks for the heads up here milkman44 I guess I must have been under a rock for the past few months this is the first Ive heard of this app.
  20. Manila Ice
    Manila Ice Hybrid and V8 Lover
    96
    63
    Chino Hills
    installed my stock rims back cause I'll be teaching my daughter how to drive and she will be driving this once in awhile.
