Priyus 2008 with 130,000 miles, red triange error, code P0A37
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priuscarowner08, Mar 8, 2014.
  1. priuscarowner08
    priuscarowner08 New Member
    I need some guidance. I have a Toyota priyus 2008 with 130,000 miles. I kept getting red triangle sign, the car will slow down and will need to pull over, shut it down and restart. I went to the dealer. First they diagnosed 12V battery issue, so we got that replaced. The red triangle sign kept coming, so we went to the dealer again, they replaced transmission fluid. They said it was low on transmission fluid. The red triangle sign kept coming. So we went to the dealer again. They said it is transaxle internal problem. The diagnostic code is P0A37. I have a couple questions. In California, what is the warranty for Transaxle problem. In some posts I saw 180,000 miles, 10 years. The dealer said they called Toyota and Toyota does not cover the repair. It is a costly repair. Second , is this code really requires Transaxle replacement. Any guidance is greatly appreciated. Thanks.
  2. Patrick Wong
    18,200
    6,500
    It is true that DTC P0A37 means that a temperature sensor within the transaxle has failed and therefore the transaxle must be replaced. This can be caused by low transaxle ATF which results in damage to the transaxle.
    The transaxle is covered under the power train warranty which normally is 5 years / 60K miles. Check your warranty/maintenance booklet to see whether, as a California vehicle, your car's coverage differs.
    A possible alternative is for you to obtain a used transaxle and have it installed, that might cost you < $2K total.
  3. priuscarowner08
    thank you for the prompt response. what does the low transaxle ATF mean that could have damaged transaxle. we kept the car well maintained with all recommended services.
  4. JC91006
    JC91006 Senior Member
    16,751
    8,556
    Which dealership in CA services your car? I would think the transaxle problem would be diagnosed the first time you went to the dealer. Did they find this problem and also the other problems you experienced? Then you did the process of elimination and changed out the lease expensive first?
  5. jdenenberg
    jdenenberg EE Professor
    3,941
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Toyota only says that you should periodically check ATF (Totota Type WS Automatic Transmission Fluid) level and claims that it is a "Lifetime" fluid. It is only a "Lifetime" fluid if you expect to trash your Prius at 150k miles! My 2004 Prius is at 255k miles and I expect it to live longer. Of course I have drained and refilled my ATF 4 times now to keep the metallic load in the ATF (from wear in the gears) at a reasonable level.
    As was noted earlier, you can have a salvaged, low mileage transmission installed at a reasonable cost. If you are near SF, contact Luscious Garage | Hybrid Specialists, or Art's Automotive or in southern California contact Oxnard Mechanic | Ari&#039;s Garage Automotive Repair Trusted Since 1993. All three are well thought of independent Prius repair facilities.
    JeffD
  6. JC91006
    16,751
    8,556
    The most common reason for the transaxle to be low on fluid is if there is an axle seal leak, usually from the driver's side axle. But that should be a problem the dealer would have noticed when you brought it in. I'm feeling your dealership service department is not that competent.
  7. priuscarowner08
    it is stevens creek Toyota in San Jose, california. they did not diagnose it as a transaxle problem until the third time I went in with the same symptoms (red triangle).
  8. JC91006
    16,751
    8,556
    There is a Prius specialty shop in San Francisco that can help you. They know much more about the car than the dealership. Also their prices would be better when repairing it. It's about 1 hour from San Jose.
    Luscious Garage
    475 9th St, San Francisco, CA 94103
    (415) 875-9030
  9. JC91006
    16,751
    8,556
    This information is on Luscious Garages Blog, the price for a replacement transaxle is as follows:
    Labor: $1,360
    Transmission (Used Unit): $800
    Additional Parts (seals, axle nuts, fluids): $89.29
    8.25% Sales Tax: $75.48
    Total: $2324.77
  10. priuscarowner08
    yes the dealership should have noticed the low transmission fluid, or the axle seal leak the first time I took the car to them and it should not have taken them three tries to get the error code PA037. what do people generally do if the dealership fails to do the right diagnostic of the car and repair? any word of wisdom. thanks.
  11. JC91006
    16,751
    8,556
    This is where the dealership service manager steps in to remedy the problem. I would ask for a refund.
  12. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    If the problem is truly the temperature sensor in the transmission, and not just a problem with the connections at the transmission then there is a cheaper way round the problem.
    The resistance of the sensor at a given temperature must be in the workshop manual for test purposes. Wiring a thermistor of the correct resistance at the connections just inside the transmission would fool the ECU into thinking things are fine as the new sensor would read back the oil temperature. As long as the ECU reads within range the transmission will carry on working and the warning light will not come on. I agree this will not give warning of overheat the particular MG concerned, but under normal circumstances this does not happen anyway, and you have nothing to loose.
    John (Britprius)
  13. Patrick Wong
    18,200
    6,500
    Yes, the question is whether the transaxle actually has suffered damage due to the lack of transaxle ATF or not. A properly operating sensor will show resistance from ~100K ohms at 50 degrees F down to ~30K ohms at 100 degrees F.
    It certainly is possible that the wiring harness connector to the sensor has absorbed some water and the connection is bad or intermittent. That should be checked since that problem would be a very easy fix.
  14. priuscarowner08
    thanks. The red triangle error is intermittent. It comes up twice a week on average, when driving on freeway at 65 to 70 mph. If the transaxle is damaged would the red triangle sign be consistent and always show up when we start the car? The fact that it shows up intermittently, does it change anything. Thank you all for responding. This thread has been very useful.
  15. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    The fact that this is intermittent makes bad or dirty connectors a possible explanation. At freeway speeds the transaxle is getting warmed up also, and that could contribute to connector instability. The thermal sensor plug is on the front facing side of the transaxle case, about in the middle. (The other plug towards the outside end is the speed resolver.) I would attempt to remove and inspect it for damage.
  16. Mr.Electric
    Mr.Electric Member
    287
    105
    San Francisco
    If you are adventurous you could replace the sensor with a resistor and see what happens. It seems like the worst case is you need a new transaxle which is where you are starting off anyways.
  17. alalaska
    alalaska New Member
    Almost the same thing happened to my 2007 with 225k miles. Triangle AND ABS warning with buzzard came on whole driving. Hit the brakes and they locked up. After that all seemed well. Took it my shop they dish. 12volt battery drop and advised me to take it to the dealer. I did they said same thing, and nothing else everything seems to be ok now??
    Don't know of it will happen again but confidence is now now. Any suggestions or advice appreciated .
    iPhone ?
