Charge time
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bwgas, Mar 9, 2014.
  1. bwgas
    bwgas Junior Member
    rocklin
    Can you over charge your battery's with the plug in. Example plug in home from work 6:30 pm and un plug at 6:00 am. Yes I know about the timer but I didn't want to use I just want to plug in when I get home and un plug when I leave the next day. ?????????
    Lourun likes this.
  2. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    No, once the battery reaches an SOC of 85%, charging stops.
    SOC=State of Charge
  3. bwgas
    bwgas Junior Member
    rocklin
    Does it go to a trickle charge or does it go 100% off. ??? Thanks
  4. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    As far as I can tell, it goes completely off. I don't use a Kill-A-Watt but There's no activity from what I can tell once the charger stops. The light on the plug-in port shuts off and brick at the wall is completely cold.
  5. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    There must be a tickle as the 12V battery has float charge on it as long as the car is plugged in.
  6. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    I'd also think there has to be some thing there since you can remotely start the A/C while it's plugged in and the charge should resume. I've never tried it though.
  7. markabele
    5,084
    1,782
    Nebraska
    There is a little gnome in there tickling the battery trying to coax it into taking more. ;)
  8. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    After a charge, the PIP turns off the connection. My Kill-A-Watt then shows 0.003 amps, 1.1 watts. That's not a trickle charge. That's the circuit and led on the Brick.
  9. CharlesH
    2,797
    1,165
    Roseville, CA
    You cannot even trickle charge a "full" Lithium-ion battery without risking fire or explosion. The circuits in the car have some continual drain, but the battery itself cannot be receiving ANY charge once it is "full". When charging completes, a relay in the EVSE opens disconnecting the high voltage from the car.
