Car slightly collided when parked? Any damage to the transmission?
Discussion in 'Gen 3 Prius Main Forum' started by Roger T, Mar 7, 2014.
  1. Roger T
    Roger T Member
    198
    48
    MA
    My car was parked on the side of the street. My neighbors car parked behind mine. Unfortunately, a car crashed on the left side of my neighbor's car, pushing it to the right onto the curb, then possibly hit/scratched my car on the left rear bumper, and drove away. The only damage on the car is as you see on the attached pic. There is no dent on the bumper, and the bumper stays in place. Just a little scratch you see in the picture.
    To be honest i am not sure whether the damage is from the shattered pieces from the car OR the hit-and-run guy actually hit my car with his?
    The photo is what I took right after the accident. In fact there was some slight scratches at that spot before the accident happened.
    If any chance, my car was slightly(?) hit by hit-and-run car, do you think my car suffered from other damages other than the damage on the picture? Will the transmission have any damages? What about car frame? My car did not seem to be hit from my opinion...
  2. Mike500
    Mike500 Senior Member
    2,593
    763
    Not likely. The Prius does not have a mechanical "parking pawl" like a conventional automatic transmission.
  3. matt b.
    matt b. Member
    251
    60
    L.A.
    drive the car for a week with no radio on windows rolled up see how it feels really test drive it put it through its paces and see if you feel the same as it did on day one and also you could take it to your mechanic or toyota dealership and have it checked out for your own peace of mind
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    With such a minor scuff, your car probably didn't even hardly move. I wouldn't worry.
    mtbiker53 likes this.
  5. Les_PL
    Les_PL Active Member
    317
    248
    Gdynia, PL
    As far as I read on this very forum it has a such - now I'm confused..
    using P | PriusChat
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I suspect the bumper cover flexing was the only movement on your car. If your car was moved there would be a creased or crumpled panel.
    Les_PL likes this.
  7. Les_PL
    317
    248
    Gdynia, PL
    Seeing the damage I also think that big rounded bumper absorbed the shock. Any securing pins broken?
  8. uropip
    uropip Member
    138
    S.E. MASS
    2013 Prius Plug-in
    Cosmetic damage. Confident u have nothing to worry about. U did get hit though. Thats not from debris.
    Galaxy Note 10.1 ? Pro
  9. hlunde
    hlunde Member
    419
    74
    So how is the transaxle locked when the vehicle is un-powered?
  10. BZzap!
    1,607
    877
    I does have a park pawl. It's just electrically actuated.
  11. hlunde
    hlunde Member
    419
    74
    Not quite the traditional pawl but a rotation lock indeed. This thing really needs a manual override so that the vehicle can be readily towed if dead, without dragging wheels or inserting wheel dollies. What was Toyota thinking?
