spoiler mileage test
Discussion in 'Gen 2 Prius Accessories & Modifications' started by tumbleweed, Oct 27, 2005.
  1. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    I have run some unscientific and unverified mileage tests with and without Brian's spoiler.
    I used MFD mileage figures, the tests were run on an 8 mile stretch of freeway with very light traffic, two runs each direction first without then with the spoiler. That is 32 miles without, and 32 miles with the spoiler. I used the cruise control set at 70 mph which means the speeds would be between 69.5 and 70.5 by my speedometer. The cruise control was left on for the entire distance of each test run to eliminate driver inconsistencies. The terrain is gently rolling and there was no wind, the temprature for the "without spoiler" runs was 63 degrees F and the temp for the "spoiler" runs was 65 degrees. The tests were conducted about an hour apart, just time to go home and install the spoiler. The battery was at 6 bars at the beginning of each run, all windows closed, A/C off vent fan on lo, headlights off. In other words the conditions for each run were as close as I could make them.
    The results were 48.6 mpg for the 32 miles without the spoiler; 49.1 mpg for the 32 miles with the spoiler. No discernible difference.
    Maybe not the most accurate test ever done but as good as I could come up with at the time, and I think, good enough to convince me that the spoiler has little or no effet on mileage.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Well done and your study design is very good. I think that at 70mph you'd find a difference due to drag if a significant difference exists.
    Did you reset the for each of the 4 runs or did you consider the 2 runs without the spoiler as 'one run' as far as the mpg reset? IOW, did you hit reset 3 times or 5 times total?
    Well done.
    I presume you've commented elsewhere on your impressions of the effect of the spoiler on the handling and stability? Or is it too early for that?
  3. efusco
    19,891
    1,196
    Nixa, MO
    BTW, I think it would be great if 2 or 3 more people who are anticipating getting their spoiler would conduct this exact same experiment. Maybe with the only variable being trying a higher or lower speed, but even then it would probably be even more informative and build the evidence stronger if everyone ran on a freeway at 70mph with CC the whole way.
  4. tumbleweed
    4,067
    691
    Eastern Oregon
    I hit the reset button, as close as I could get, at the exact same point at the start of each run. Then read the displayed milage at the same point at the end of each run. So I reset a total of 8 times and took 8 readings. Then I averaged the 4 readings "without" and the 4 "with" which gives a good answer because the distances were the same.
  5. efusco
    19,891
    1,196
    Nixa, MO
    Would you mind posting the raw data for each run? That way, if there's a statistician on board they could determine the reliability of the test, create graphs, find means and medians and lots of other numbers to confuse us!
    Actually, I'm thinking that if we can get a few other people to run similar tests we can then take all the raw data and perhaps find any small differences...there should be some.
    It would also be interesting to see a longer run, but that creates more variables.
  6. tumbleweed
    4,067
    691
    Eastern Oregon
    Here is the mileage data for each of the runs:
    Without the spoiler, temprature 63 degrees F.
    South 42.7
    North 53.2
    South 44.0
    North 54.4
    Average 48.6
    With the spoiler installed, same day about an hour later, temprature 65 degrees F.
    South 45.0
    North 53.7
    South 43.2
    North 54.6
    Average 49.1
  7. tumbleweed
    4,067
    691
    Eastern Oregon
    No I can't say how well it works yet. My Prius was never one of those that didn't track well and drifted all over. The problem I hope to solve with the spoiler is instability with an approximate 10 to 20 knot or higher head wind, it's kind of flakey under those conditions. I expect any car to blow around a little when the wind gusts but I thought this one was excessive. We haven't had any wind since I installed the spoiler so I haven't been able to give it a good test. Unfortunately any such test will be subjective.
    I have a stiffening plate on order which I think will help also. In addition I am still running the OEM tires and I don't think they track to well over 60 mph or so.
  8. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    If you look at the correlating measurements with and without spoiler, you see that the first south runs are much wider apart than the rest. If you drop those, the difference is much smaller, thus concluding that the spoiler is insignificant.
  9. brucecbromberg
    brucecbromberg New Member
    If the spoiler does not alter the mileage in any significant way, one must conclude that it does not alter the areodynamics in any signficant way either. Therefore, a conclution of it being insignificant in reducing any lift or enhancing proformance in any way is drawn. But it looks cool!
  10. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    I was wondering when someone would finally reach that conclusion. Most of the "performance" enhancements sold these days are nothing more than style statements. Even the giant wings that people slap in the back of their riced out Hondas don't do much under about 80 mph, and unless they've done some wind tunnel testing, it's just as likely to provide way more drag then downforce. Race car teams spend millions in wind tunnels to tune wings that produce downforce with minimum drag, and the designs are usually carefully guarded secrets until raceday. If you somehow found a tiny spoiler that creates downforce but no drag at legal highway speeds, I'm sure IRL and Champcar would be interested in the design.
    I've never thought my Prius was loose at highway speeds (which is what a rear spoiler would help, if it actually did anything). If anything, my car pushes a bit. A spoiler would just make that worse.
    If I could go to the parts bin to improve handling for my Prius I would start with about 25 percent higher rate springs (not lowered since the car already bottoms on speedbumps), improved dampers, and about 50 percent stiffer anti-sway bars front and rear. (Of course none of that shows on the outside)
  11. Jim West
    Jim West Junior Member
    On the rear wing of many open wheel race cars there is a small vertical strip set at about 90º along the trailing edge of the wing called a “Gurney flap†(named after Dan Gurney) or “wickerbill.†It provides considerable down force at high speeds. Some Porsches have an active rear spoiler that comes up at about 75 miles an hour. Both of these devices increase down force appreciably. It is likely that the aftermarket spoiler for the Prius would raise the drag coefficient rather than lower it and it would not help at all on cross-winds. Nevertheless, it would likely generate considerable down force; it’s just a question of whether the Prius can go fast enough to for it to have an effect. I love aftermarket parts. I have a number of them on my ’91 NSX. However, it is good to keep in mind that some of them look better than they work.
    I have a Silver Prius with a #7 package plus leather coming in before the end of the month. This is my first post. I Hope I wasn't out of line and too boring.
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i appreciate your trying to be as consistant as possible, but the range of variation in your results tells me that your distance was probably too short.
    also, i consider a ½ mpg to be a significant change. if this was to pan out over time, it would be well worth the mod imho. i think a real test would have to involve extensive data for a known run before and after the mod to get a long term trend.
    i also suspect that the difference might be small and not overcome the deviation of the data.
  13. mcmurray
    mcmurray Junior Member
    52
    Gold Coast, Australia
    I just got my '06 Prius and I'd like to know how is the aftermarket spoiler different to that on mine?
  14. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    What is the real difference between the two spoliers?
    does the replacement still have the 3rd brake lite installed?
  15. darelldd
    6,059
    389
    Northern CA
    I don't think we'll ever have a definitive answer by road-testing.. especially if 0.5mpg is the type of accuracy we're after! The only way I can see meaningful testing is in a wind tunnel.
  16. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    The spoiler underdiscussion is the one available at the <a href=\'http://www.priuschat.com/shop/product_info.php/products_id/24\' target=\'_blank\'>BT Tech Prius Rear Aero Spoiler</a> link in the PriusChat Offers box.
    I'm not so sure it applies down pressure (it's so small) as much as "spoil" the lift over the back end of the car.
  17. mcmurray
    52
    Yep, got that one Bill - but is it any different (and how?) from my stock '06?
  18. Bill Merchant
    4,096
    85
    If you follow the link and look at the pictures (click for larger images) you'll see that the BT Tech spoiler attaches to the hatch glass just in front of the stock spoiler. The BT Tech spoiler is about 1.25" wide in cross section and goes from edge to edge on the glass, for a nice fitted appearance. I think it should also work with the "B" type spoiler Sigma (another sponsor) sells.
    The BT Tech spoiler is used in addition to the stock spoiler, it does not replace it, like the Sigma "B" spoiler does.
  19. mcmurray
    52
    Ok .....now I see it. Too much sun up here in Queensland....bad eyes!
    Thanks Bill, I will read more and see if I can determine if it is worth adding.
  20. hycamguy07
    2,707
    Central Florida
    Ahh, ok I thought this was the other Spoiler that replaces the origanal..
    I didnt think the BT one would do much as it really doesnt spoil much. I mean it doesnt stick up..
