EV Range Post Polar Vortex
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by priuskitty, Mar 8, 2014.
  1. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    My results are based on all EV, no HV mixed in my calculations
    SGH-M919 ? 4
  2. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    The battery-pack being cold makes a big difference.
    I clearly saw that between work and my non-heated but insulated garage.
  3. EVExtend
    EVExtend Junior Member
    2013 Chevy Volt
    You'll see a big improvement once temperatures warm. I did a lot of cold weather Lithium Ion battery testing in the past. The ability to extract charge in below freezing temperatures just isn't as good. Around 65-70 degrees is ideal, it seems.
    It's a dichotomy of sorts... If you want to preserve Lithium Ion batteries, you keep them cool (such as temperatures in a refrigerator). However, if you want to extract maximum capacity from them, that happens when they're nice and warm. The problem is that the hotter they get the more you can also degrade their performance over time.
    Cold won't harm them though (unless it's to the point that the electrolyte freezes).
  4. El Dobro
    El Dobro A Member
    7,093
    3,271
    Even with all the single digit days we had, the lowest the EV reading ever went to is 10.1.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Actually it is. It will be for all Californians this summer as we approach what may be the worst drought in a 100 years. I don't really care if I get the highest EV range I've ever gotten if my grocery bill shoots through the roof because farmers don't have enough water.
    I'm not a meteorologist but I blame the cold you guys got and I didn't as I sit on a lawn chair basking in the near 80 degree sun with an ice cold drink in my hand.
    Might as well enjoy this weather.
    iPhone ?
  6. Oibm
    Oibm Junior Member
    Los Angeles
    2013 Prius Plug-in
    Speaking about California, one of my highest EV ranges was something around 22 miles. My current range is around 20 miles.
    mmmodem likes this.
  7. markabele
    5,084
    1,782
    Nebraska
    Dang! What is your commute like?
  8. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Must be some long down hill round trips!
  9. uropip
    uropip Member
    138
    S.E. MASS
    2013 Prius Plug-in
    "warmer" weather has me back up to 10.8
  10. Oibm
    Oibm Junior Member
    Los Angeles
    2013 Prius Plug-in
    You are right. I use around 80% of my EV range for my way back home, which is a long down hill. In essence I use 0 (cero) gas during it. Loving my Plug-in
  11. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    How about your way to work?
  12. Oibm
    Oibm Junior Member
    Los Angeles
    2013 Prius Plug-in
    My way to work is a long uphill. Not very steep.
  13. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    How's EV on up hill?
  14. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Mine never went below 10.8 even during the depths of the February cold spell. The ICE did run nearly every trip though which has tanked my lifetime mileage!
    Surprisingly it hasn't started much of an upward trajectory yet - on occasion I see 11.1 but today it was at 10.8 again (although it was 12 degrees here this morning with about 3" of new snow!)
  15. Oibm
    Oibm Junior Member
    Los Angeles
    2013 Prius Plug-in
    It is not great. Around 10 miles. I tend to use my EV only on way back, downhill, to take maximum advantage of EV.
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I guess I started this thread a little too early:cry: It will be 10 F tomorrow morning:confused:
    retired4999 likes this.
  17. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    It was 6F here this AM. EV actually went up to 9.8, although not sure why and of course the ICE started when I went to work. It hasn't been that much warmer and looks to be back to winter tomorrow.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Update: May 9, 2014 temps in the seventy's, yesterday 87 record high. my EV range has soared to 11 miles EV. which is accurate given I'm driving on flat terrain around 40 MPH, to and from work. Same as when I got my PIP way back in April 2012. Whoo Hoo! Polar Vortex is OVER!!!!!!!
    retired4999 and bisco like this.
  19. bisco
    52,386
    gotta love the kitty.:love:
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    SM-G900T ?
