Nearly out of gas signal?
Discussion in 'Prius c Main Forum' started by David Watson, Mar 19, 2014.
  1. David Watson
    David Watson New Member
    St. Louis, MO
    Does the Prius signal a second or third time after it shows one bar of gas? I know it signals the first time, but I'm always worried that I'm going to run out of gas. I know I get around 50 mpg's, so I just want to make sure it gives me one more chance in case I forget.
    52,286
    unfortunately, no. try not to learn this the hard way, like i did.:oops: it's easy to forget after the single beep. who notices the flashing pip after a few miles?
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Nope. Toyota thought a fuel gauge, a tone, and a blinking fuel bar is enough notification of low fuel. It's about 2 gallons remaining when you hear the tone if you want to play chicken. Loser buys gas.
    iPhone ?
    koipond and Stevie like this.
  4. bisco
    52,286
    and keep the music low so you hear the (barely audible) tone.
  5. David Watson
    St. Louis, MO
    Thank you! Yeah I often miss the beep because of the music. Now I know it's not gonna warn me again.
  6. DKTVAV
    DKTVAV Active Member
    510
    101
    It will beep every time you start the car until you fill up except you keep driving continuously for another 50 miles (depends on how good you are at MPG game) after the first warning.
    ztanos likes this.
  7. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    There likely will be one more beep.
    It's the one that signals the engine stopping and the battery is run down. :eek:
    ztanos likes this.
  8. DKTVAV
    510
    101
    I just tested tonight and it beeps eight (8) seconds after every time (five timess) I pushed the Start button from off, about 10 seconds the ICE starts.
    I noticed the blinking bar (didn't hear the beep) today and drove about 5 miles on the way home. I was lazy to stop by Costco gas and also remember about this thread so I didn't fill up and just tested above to know it will beep until I fill up.
  9. orenji
    orenji Senior Member
    5,887
    3,488
    The final warning signal will be the choking sound from engine before it shuts down, hope it will be on a downward side of a hill :eek:
  10. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    At the beep point my C takes about 8.3 gallons to fill it.
    -Tapatalk2 on Android
  11. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Just fill the car when you get to 2 pips!
    You will never run out of gas, and never hear or miss the "Beeps"!
    Running out of gas is bad in a Prius, why take the chance!
  12. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    KK6PD saved me the trouble.
  13. fuzzy1
    10,588
    That depends on where you are are. On my road trips, refill planning needs to start earlier than 2 pips: [​IMG]
    Also, cell phones don't work over large sections of this road.
    ewaboy likes this.
  14. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Guess what? …you snooze!
    …you lose! :(
  15. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Is that state route 140 between Lakeview OR and (just north of) Winnemucca NV? When I drove it, you not only never passed gas stations, you never passed any buildings of any kind, although at one point you can see Denio NV in the distance.
    [edit] It is US 6 from Tonapah NV to Ely NV
  16. fuzzy1
    10,588
    Bingo. I figured you were the most likely to identify it first.
  17. Hybrid Dave
    Hybrid Dave Member
    184
    73
    St Augustine, FL
    I've driven some cars where 163 miles is nearly a whole tank.
    ztanos, B2FiNiTY and ewaboy like this.
