Should I correct my 110v situation in the garage or just add a 220v line for a Level 2 Charger?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by grkmalaka, Mar 21, 2014.
  1. grkmalaka
    grkmalaka Junior Member
    30
    2014 Prius Plug-in
    I picked up a new 2014 Plug-in last weekend and have been charging in the garage.
    My house was built in the 50's and I discovered that 3 outlets in the garage are tied to other outlets in the house while one newer outlet is on its own circuit for the dryer in the garage.
    I've been using the outlet for the dryer for the last week since that 20a breaker doesn't really do much else but my question is:
    Option 1
    Should I spend money trying to segment the other 3 outlets in the garage to their own breaker and use that for charging?
    Option 2
    Spend that money on running a 220v to the garage for a Level 2 charger?
    Option3
    I could just run another dedicated 120v into the garage for the PiP instead. That would probably be the cheapest and easiest solution.
    Obviously, if i take the 220v route, part of it would be tax deductible but i just see the 220v as not needed for this vehicle.
    Thoughts?
  2. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    I would suggest running a dedicated 120 outlet, but use wires that could go 220V at 30 amps. That way if you find a need for 220 down the road, only connections need to be changed.
    xpcman and Tracksyde like this.
  3. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    If you were to use the timer function to charge at night, say in the wee small hours, then the dryer wouldn't be running. Then you wouldn't have to spend any money at all, right? Toyota does suggest a dedicated circuit, but from what I read in your post, the only conflict would be if you are trying to charge and also dry clothes. OTOH, if you were spending the money to get 220v, the dryer would probably benefit by working more efficiently and finishing a load in a lot less time, so you would be killing two birds with one stone. Not sure about the tax situation.
  4. grkmalaka
    30
    2014 Prius Plug-in
    Well the dryer is Gas, just needs 110v for electronics, it's not a 220 electric dryer :)
    I've got the timer in the PiP running from 2am-6am, when the dryer is definitely not running and will save me money all together with not having to change a thing.
    I did pick up an extra charging cable though so I can leave one hanging in the garage and still have the other in the car to charge at work. Trying to maximize my MPGe's!
    Thanks for the help all.
  5. firedoug
    firedoug Junior Member
    28
    Corona, CA
    grkmalaka
    Something I missed the first time I read the manual is the timer on the PIP is has two functions a start and charge until full time function and a end time full function. So if you use the end timer the PIP sorts out what time it needs to start to accomplish a full charge, and then starts at that time. The two functions are independent of one and other.
  6. grkmalaka
    30
    2014 Prius Plug-in
    Doh! I did miss that. So I can set it to 6am as the finish time and it'll calculate what time it needs to start in order to get done by 6am. Awesome, thanks for that.
  7. firedoug
    28
    Corona, CA
    Exactly
    SAMSUNG-SGH-I337 ?
  8. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    The timer will assume the EV battery is without any charge left. If you set it to end at 6AM, it will start about 3AM. It doesn't take into account how much charge is in the battery when starting to charge. Only that it needs about 3 hours to complete the charge.
    Mine usually takes 2 hours and 20 minutes to complete charging from empty.
    retired4999 likes this.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I also have the dryer and washer on the same circuit in my garage. When I first purchased my PiP, I decided to do absolutely nothing in terms of changing my electricity rates, buying a new EVSE, or rewiring. I'll just charge at night when there is no interference with washing or drying clothes.
    I suggest you do the same. So that you know what costs are involved with a couple months I actual usage.
    I found out my increased cost of electricity was roughly equal to the cost of using gasoline in the vehicle instead. This meant any additional cost on plugging in the vehicle is a direct added cost. I changed my electricity rate plan to offset cost a little but the math still said I saved $100 a year using electricity. The cost for a 220V EVSE Is just too high. I plan to upgrade or rewire when they come down in price. I believe the tax credit ended last December.
    iPhone ?
    Hi Burrito! likes this.
  10. CharlesH
    2,796
    1,163
    Roseville, CA
    My electric bill actually went down significantly when I got the PiP. Two reasons:
    1) I changed to a time-of-use electric rate plan, and charge in the middle of the night. I also try to run the dish washer and electric clothes drier during the cheaper off-peak time whenever practical.
    2) I used a Kill-a-watt and found and eliminated a bunch of "vampire" devices that were each pulling a few watts 24/7.
  11. rogerv
    1,639
    317
    I apologize for assuming that just because you mentioned a dryer on the 110 circuit that it was all electric- my bad. Was that extra EVSE cord expensive? A second done would be handy to have, but they were pretty pricey before.
  12. grkmalaka
    30
    2014 Prius Plug-in
    I bought the Leviton EVC11-300 from someone that no longer needed it for $349.00.
  13. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    I think the cost of a 240 line would be very close to the cost of a 120 line. The only real difference is the gauge (and therefore cost) of the wire.
  14. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    The gauge wouldn't change for the same current capacity, but a 240 V circuit has four wires instead of three. Both 120 and 240 use black (live), white (neutral) and bare copper (ground); the 240 circuit has an additional red (live) wire.
  15. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    Incorrect. 240V devices do not necessarily need neutral. Some devices use neutral as well to run a secondary low-voltage internal supply or offer both 120V and 240V downstream outlets. L2 EVSE's are pure 240V (or 208V) devices and do not need neutral. Some use a NEMA 14-50 plug which has neutral (though they may not actually use it internally), just to be cross-compatible with modern dryer outlets and RV parks. Plenty of others use a NEMA 6-50, which does not have neutral.
    Many people "convert" a 120V 20A circuit to a 240V 20A circuit by moving (and relabeling) the neutral wire in the breaker box to a 2-pole breaker, and then change the outlet type on the other side. Perfectly valid for a pure 240V device.
    ftl likes this.
  16. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    If you're thinking of the federal tax credit for EV charging equipment, that expired at the end of 2013.
  17. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Agreed for the Level 2 chargers - I was thinking of appliance circuits, which use the 240V for heating elements but also need 120V for fans, lights, etc. In the OP's case, if the new circuit would be used only for charging the car it could be run as 120V and switched later to 240V, as you describe.
  18. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    I had a house at one point that was built in the 1950's, and most of the wiring was cloth insulation.
    I ended up rewiring the entire house and updating the fuse box to current codes.
    Not sure where you are and what type of wiring, but having a certified electrician scope it out would be well worth the $.
    When having electrician install separate 120v gfi outlet in current house garage 2 years ago for Pip, (built in 80's), had them use wire gauge that would handle 240v if we ever decided to go that route, which we did in December. Same electrician used and we had space in our fusebox for the 240 breaker.
    Good luck,
    Bill
  19. GregP507
    GregP507 Senior Member
    3,002
    481
    I think it would be worthwhile getting the level 2 charger installed if you can. You never know when you'll appreciate a 90 minute charge time.
  20. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    Time of use is expensive when you need to run air conditioning during the day.
