2013 vs 2014
Discussion in 'Gen 3 Prius Main Forum' started by Gray Runner, Mar 22, 2014.
  1. Gray Runner
    Gray Runner Junior Member
    24
    Framingham, Massachusetts
    I am looking at a 2013 and 2014 same options, does anyone have opinions one which model would be better? Is there that much of a difference in the horsepower that I will notice?
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Basically same car.
  3. STEELJBS
    STEELJBS New Member
    28
    Gloucester Va.
    You can save a lot of money buying a 13 right now. But really no big difference.
  4. Gray Runner
    24
    Thank you for the quick reply
    Going to dealer now. I have an 08 now, son is getting the 08. I'll get the new one
    Burna J likes this.
  5. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    I'd go for the 2013 if it's cheaper, no real difference.
  6. Vman455
    Vman455 Senior Member
    538
    555
    The Middle
    2013 and 2014 models are identical; I would get the 2013 (actually, I did get a 2013 instead of a 2014 a few weeks ago).
  7. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    I have the same question a few months ago and I ended up with 2014 pack3.
    Everything is the same but the title is 2014 vs 2013
    iPhone ?
    HaroldW likes this.
  8. CapeAnn
    CapeAnn Member
    114
    25
    Northeast United States
    There's a difference with regards to the new IIHS small front overlap test. This is the reason I went for a 2014 made after Nov. 2013 model. It was the deciding factor in not getting a Prius C (which I really wanted), or a screaming deal on a 2013.
    quote from IIHS " Beginning with 2014 Prius and Prius Plug-in models, the front structure was modified and the side curtain airbags were lengthened to improve occupant protection in small overlap frontal crashes. Then, starting with 2014 cars built after November 2013, the 15-inch alloy wheels standard on most models were sourced from a single supplier to provide a more controlled crush during the small overlap test (note: information about when a specific vehicle was manufactured is on the certification label typically affixed to the car on or near the driver door)."
  9. Gray Runner
    24
    I will check the mfg date to make sure, thanks
