Help, Ruptured My Prius!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wbray123, Mar 22, 2014.
  1. wbray123
    wbray123 Junior Member
    71
    Colonial Heights, VA
    Today I parked beside a curb in a parking lot and turned too tight. My rear wheel went on the curb and I backed off at a very low speed. But the car fell on the curb somehow and the passenger side undercarriage got busted up below the front door. Two holes about the size of my fist and a dangling piece that I need to deal with. So, should I repair this? Or just live with it (except for the dangling piece)? Is there an aftermarket piece that would cover it up cheaper than a real repair? Am mainly concerned about rust/corrosion and resale value. It's a new 2013 with 11,000 miles. Car.JPG Car2.JPG Thanks.
      File size:
      117.6 KB
      566
  2. JC91006
    JC91006 Senior Member
    16,815
    8,596
    It's lucky this damage is under your car, you can ignore it and nobody will know it's damaged. You can possibly use a strong epoxy type glue to glue back the piece that's dangling.
    SM-N900P ?
  3. Mike500
    Mike500 Senior Member
    2,593
    767
  4. vskid3
    vskid3 Active Member
    773
    228
    OP doesn't have a C.
    From what's shown in the pictures, there shouldn't be any issues with rust. I would just do like JC91006 said and try to glue the dangling piece up. do not know if it would hurt resale value, mainly depends on how visible it is and how close the buyer inspects the car and how much they care. I wouldn't worry about putting any money into it until you're trying to sell it (or if it bugs you). For all you know, you could fix it and then have something else break the piece again.
  5. Mike500
    2,593
    767
  6. bisco
    52,284
    looks like fibreglas, is it plastique?
  7. Mike500
    2,593
    767
    The parts are actually made of acrylonitrilebutadienestyrene. The abbreviation isABS.:)
  8. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    If you bought your Prius, you can wait to repair or not repair at all. If you leased it, you will have repair before the end of the lease.
  9. JC91006
    16,815
    8,596
  10. milkman44
    milkman44 Active Member
    591
    386
    Ky
    That won't show if you glue it back, possibly back it up with some material on the inside. That sill will come off really easy, pop out about four plastic plugs and a couple of screws with a 10mm socket and it should be easy to clean and repair. The wife scratched the left door sill on a curb and I took both sides off and covered them with a sheet of red carbon fiber pattern film. I'll have to re do them as the plastic film has faded to pink, can't have that on a manly Prius.:eek:
  11. Skateruk
    Skateruk Member
    125
    28
    Nottingham, UK
    Get it repaired and water tight as soon as you can otherwise if rust gets into any steel sections you'll get real big problems further down the line.
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    My two cents is that I'd attempt gluing it.
    Just because it's not visible, and just needs to be "put back".
    A full out repair for that piece could get costly.
    Bodywork is just so expensive that getting it "officially" fixed could become a costly enterprise.
    It's kind of up to the OP what level of restoration they will be happy with. If just getting the piece back in place is the goal, then I think there are numerous grass roots options that would be less expensive than a full out part replacement and/or body shop repair.
    jhinsc likes this.
  13. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Maybe a used one from eBay, already the proper color? That would be my first choice. Second choice would be to take a utility knife and cut off the dangler. From a body professionals' point of view, unless you're plastic welding it, it's not a permanent repair.
  14. wbray123
    71
    Thanks to all. Have cut off the dangling piece and there is no damage visible unless you look under the car. There are holes and fractures in the plastic piece down there so it will not be a simple patch. But will look into patching it later.
  15. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    That will not cause any rust problems. It's up to you what you want to do.
