Radiator Coolant Leaking a little bit, add black pepper powder?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AllenZ, Mar 30, 2014.
  1. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    I added black pepper powder into a severely leaking radiators on another car, stopped leaking right away. That's many years ago.
    Now I found my 2004 Prius the coolant tank for radiator was empty. Bought a bottle from dealer, add not much and it brings to max level. It tells me the radiator was not completely empty. That's good news.
    Then I monitored a couple of days, found the fluid level in the tank does lower a little bit. Many said it is very likely the water pump leaking. I plan to put some pepper powder into the coolant, see if it will stop the leaking. Do you think it will do any harm long term? Have you ever done that before?
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    New one to me the pepper that is, check the coolant level in the radiator itself. To do so, you will need to remove the plastic splash guard over the radiator to access the cap. When full, it will look like the picture below.
    Chances are your ICE water pump is leaking. This is not a uncommon problem with the Prius.
    frodoz737 likes this.
  3. AllenZ
    640
    63
    Chicago
    Thanks!
    You mean, just filling the white tank is not enough? I thought they are connected.
  4. dorunron
    3,318
    1,105
    Houston, TX
    Correct, some times the bottle will empty out and not refill the radiator when you add fluid to it. Even if it does, you still might have air pockets. Best to check the fluid level in the radiator any time you find the bottle is empty.
    Both the radiator and the bottle should be full at all times if the system is NOT leaking. If the bottle is empty or the radiator is low, there is definitely a leak somewhere. Most of the time it shows up as the ICE water pumping leaking. Very common on the Prius. Just went through this scenario 20 days ago. Took a couple of days to get all of the air out it even after the dealer replaced the pump, belt and bled the system.
    Also, I highly recommend you use only the Toyota SLLC for your Prius. And change the fluid in both the radiator and the inverter loops when the clock hits 100K, and then every 50K after that.
  5. Mike500
    Mike500 Senior Member
    2,593
    767
    The "black pepper will fill and clog the narrow passages in the thermos, and the herter core.
    "Bite the bullet" and replace the radiator and possibly the coolant pump, if needed.
    Replacing the coolant on a Prius Gen II requires a special procedure.
    It is NOT like a 1961 Chevy.
  6. Mike500
    2,593
    767
    You need at least one of these tools;
  7. Mike500
    2,593
    767
  8. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    I've never heard of your method of using black pepper powder but that's not somethingI would recommend doing.
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Ditto.
  10. AllenZ
    640
    63
    Chicago
    I did not invent it. I just heard from someone who had the experience and I though that it makes sense, especially in urgent situations.
    Technically, the pepper powder has different size, that's good for blocking different size leaks. The only issue I had before (on another car), is that leaking continues suddenly, in a few weeks, and then stop sometime later. I guess the powder did not "stick" to the leaked place for whatever reasons. Maybe after parking over night, the leaking place dried up, so does the powder, size reduced, and cannot block the leak the next day.
    I use tire sealer the same way. It blocks the tiny leak in rubber quite effectively for the whole year, except when temp dropped to 0F, the sealer frozen, and I got a flat tire.
    I wonder do I need to replace the radiator/water pump now, or I can depend on the powder to stop leak, and keep an eye on the coolant level, without getting into serious trouble, for couple of years. The car has 210K miles, the market value is probably at $4.5 - 5.5K even with the full options. I only want to put money into it when it is absolutely necessary.
  11. AllenZ
    640
    63
    Chicago
    No, I don't do car fixing. No garage, little tool and very little knowledge. I sold my jacks and hydraulic lifter a while ago on Craigslist. Letting my mechanics to have the business is cost effective to both of us.
  12. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    I'm sure he meant heater core. :)
    Besides clogging of passages, I'd imagine that pepper is acidic. You really want to be adding something acidic to further cause internal corrosion? Who knows what else it'll due to anything else the coolant runs thru (engine's water jacket, passages, pumps, radiator, heater core, thermostat, etc.)? I highly doubt Toyota or any automaker intended for people to add pepper to their coolant.
    I don't think I'd ever want to buy a used car from the OP...
  13. dorunron
    3,318
    1,105
    Houston, TX
    Allen, the ICE water pump and gasket is NOT really expensive. Any mechanic can change it out. The only thing about the Prius is you have to bleed the air out of the system, otherwise you will have problems with overheating and other issues like the heater not working.
    If you are going to drive the car into the ground so to speak I would then put some of the stop leak with round balls in it. That stuff will work and stop the leak. That is IF you don't want to spend money to fix the car properly. I can't promise you though that it won't stop up small passage ways here and there. Stuff works great on older cars that didn't have all the stuff like the Prius has.
    I would not normally recommend this to anyone, but from what you wrote above it sounds like you don't want to spend any money on it if you have to and get every thing you can get out of it.
    I will say this though. If you do use the stop leak and it causes problems with critical parts stopping up that will be the end of the road so to speak. If you ignore the problem altogether and simply keep adding coolant to it you can probably get by for a while.
    Everyone has their own budget and maintains their vehicles how they choose. I do understand and respect your opinion on the age and miles of the car. Yes, it is well over the expected lifetime of the car so you have had a good run out of it. But with a little TLC like a new water pump and some fresh coolant it might just add some more life and miles to what you have already enjoyed.
  14. JC91006
    JC91006 Senior Member
    16,767
    8,564
    The leaking you are describing doesn't seem to be an "urgent" situation where you need to add black pepper, which is really the craziest thing I've heard.
    Just top off the radiator and the coolant reservoir and watch the levels. Change the water pump if it's leaking.......but I don't think this would be a major leak, most everyone that has this leak, it's a very slow seeping leak.
    dorunron likes this.
  15. drmanny3
    drmanny3 Member
    124
    Orange County, CA
    Hey, only a fool will add pepper to the coolant system. Don't even consider doing. You will most likely cause additional damage and dramatically increase the costs associated with fixing the car. The Prius is a pretty solid performer and should continue to work for you for another 100000 miles. So think first doing something that frankly belongs in the look at what stupid people used to do to their cars. You may not need to replace the radiator as they seem to hold up. The weak link could be the water pump. It is relatively cheap. You can purchase one off eBay for under $30 . The belt costs about $10 It takes about 2 hours to do the work. Not really that difficult. There are some youtube videos on actually changing out the pump. A good additional item is the yellow lisel mentioned above. I found one at Pep Boys for about $30. It really makes filling the radiator and getting rid of the air trapped in the system. You are correct in that the top plastic tank is connected to the radiator. The way it works is when the car gets hot and the fluid expands it goes into the top tank. As the car cools down it is drawn back into the radiator. So if you are seeing some of the level drop it may be filling the radiator. I would remove the top piece so you can gain access to the radiator cap. Be careful if the car is hot as you can easily burn yourself. Once cool you should be able to check the level. Also you can shine a flashlight over at the water pump and look at the inside of the pulley. If it is wet then you got a leak.
    Manny
  16. AllenZ
    640
    63
    Chicago
    I reject the notion that if Toyota did not put it in manual, don't do it. I do appreciate all the advices. But so far I have not heard convincing argument on why the all good all tasty pepper powder could cause unimaginable damage to this unusual hybrid car. Too much fear for no solid reasons.
    It's not all about saving money on replacing parts, plus time and efforts. Probably more importantly, I want to know if my hypothesis works. My common sense tells me that it can't cause serious problem. So, bear with me.
    I've also done some other crazy things on this Prius, and actually enjoy it.
    1. I bought refurbished 12V battery from Interstate battery for $30, 70K miles ago. So far so good.
    2. I buy used tires with 80% thread left, at $25 each installed, mixed brand. I do make sure the two front tires are same size. Rear ones don't have to, but by chance, they happen to be same size. So far no issues. I do drive conservatively (though not a hypermiler), which demands less from tire.
  17. JC91006
    16,767
    8,564
    It's your car, there's nobody here that can stop you in testing.
  18. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Really? So, can or should Toyota or any automaker put in a comprehensive list of EVERYTHING that shouldn't go into a car or be mixed into its fluids in the manual? Because they didn't put in stuff like no urine, feces, blood, fruit, cookie dough, bread, eggs, cheese, hair gel, baking soda, Crisco, cooking grease, spices, sugar, salt, acid, base, sand, rice, etc. into the oil, coolant, transmission fluid, etc. means it's ok? Should manuals look like drool-proof paper ?
    Common sense? If all the compounds typically in black pepper and its particle size were typical of that of coolant and water, along w/its pH value, ok... But, nope.
    FWIW, I found Importance of pH Value in Engine's Coolant on coolant pH level. If I am correct about black pepper being acidic, then it would make the coolant's pH lower.
    The Earth First eco terrorists would do stuff to stop logging by pouring sand into the crankcases of bulldozers and quick rice into their radiator... They'd also do stuff like spike trees w/metal spikes so that the chainsaws would kick back and likely kill the logger, but I digress....
    I suggest you try putting in sand into your oil crankcase and quick rice into your radiator because Toyota didn't so not to... ;)
  19. Patrick Wong
    18,204
    6,505
    I was really surprised to find this website that also advocates the use of 1-2 tablespoons of ground black pepper as a means to fix a radiator leak. However the website also says that for radiators with plastic side tanks (which the Prius has) that this is at best a temporary fix.
    How to Fix a Radiator Coolant Leak
    As previously suggested, the OP should first figure out exactly what is leaking. If the engine coolant pump is leaking, which is the most likely suspect, then I doubt the black pepper will help since the worn bearing is subjected to the shaft spinning and therefore any seal formed by the pepper will break.
    The OP asked whether the addition of black pepper would harm the coolant system. Keeping in mind that the Prius coolant system is highly complex, with the engine coolant valve which switches coolant between the cabin heater core and the coolant heat recovery canister, and the canister itself, not to mention the three pumps that are part of the system (engine coolant, CHRS pump, and heater core pump) there are lots of places for the pepper potentially to be trapped. When the engine coolant is drained, at best 6.5 US quarts will come out while the capacity is 9 US quarts, so obviously substantial fluid is trapped by the heater core and the valving.
    I personally would avoid introducing such foreign substances into the Prius coolant system. However if the OP wants to do that, that is his business.
    cwerdna, dorunron and AllenZ like this.
  20. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    In my old mustang I used a raw egg whites once... the egg essential cooks and the bitsand pieces flow and fill the holes.
    a nice temp fix, but not long term...
    there are all sorts of quick fix products that you can buy that will do the same thing.
    radiaotr stocp leak - Google Search
