Battery will only charge
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by metalic160, Mar 18, 2014.
  1. metalic160
    metalic160 New Member
    So recently I was driving through highway 17 ( steep hill) with 4 people and we'll my 07 Prius was slowing down like never I eventually smelled a little burn but I ignored it I just though the engine was working a bit to hard. Recently I noticed that on the energy screen it only shows that the battery is getting charged it sometimes used the battery to the motor but not often. I did notice though that I run with electricity more when I'm in the city. It's quite weird it's like the electric motor doesn't work on the freeway any answers?
    iPhone ?
  2. metalic160
    iPhone ?
  3. Rich12
    Rich12 Member
    176
    29
    Enough...you're wearing me out w/dupe threads.
  4. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Did the traction battery state of charge meter show just one, purple bar? Commonly, while climbing a long hill, the traction battery will reach minimum charge (~40%), at which point it will not supply the electric drive for the remainder of the climb and you will be limited to only the output of the gasoline engine, which is pretty limited.
    How many miles are on the car? If the traction battery is not holding charge as well as it used to, it may be degrading. On level freeways, the traction battery should rarely be at minimum charge.
    On the freeway, energy flow is often less predictable than in the city. The electric drive is generally used less on the highway than in the city, but it still should be available for moments of increased power demand.
  5. usnavystgc
    3,159
    989
    Tucson, AZ
    This is completely normal. The Prius is designed to use the hybrid mode more in the city at speeds below 42mph. Above that, you'll only use the electric assist when the battery gets near 70-80% to burn off extra charge and maintain it at 6 bars.
  6. metalic160
    Sorry newbie here lol
  7. metalic160
    The car just hit 160,000 and the charge sti holds except I only see the bars being blue and when I'm in the freeway it's just charging the battery except I never see it go green unless i go down a hill and the charge has been holding except I don't ever really so go down to purple lines but somehow I'm still getting 44mpg per fuel tank
  8. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Ok, that means your prius/battery is working perfectly, only your expectations are off.
    When freeway driving it's very common to see the green arrows showing charging of the battery most of the time. Once the SOC (state of charge) reaches 6 blue bars however, then this charging current drops to a very low level, but is still charging. Remember that the power for the entire 12V system (all the ECUs and displays etc) comes from the traction battery via the DC-DC converter. So, on average, it has to be charged slightly from the engine just to maintain its SOC.
    Sometimes I drive for ages with it mostly showing the green arrows charging the battery. Other times it tends to flip about an change directs fairly often. I think that if you're seeing mostly green arrows then you're probably driving very steadily on fairly level terrain.
    Anyway, the bottom line to take away from this is that just because it seems to be mostly charging, that doesn't mean you'll necessarily see the charge level increasing on the display. When it's at 6 blue bars it's basically just "treading water".
    nh7o likes this.
  9. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    I think most curious types would find the use of one of the various monitoring devices/software instructive.Those directional arrows on the MFD are misleading, as they can jump back and forth quite frequently making one think that there important things being done in the energy realm, but the actual currents being controlled at such times are just a few amps, i.e. nothing much. I think there could have been some sort of magnitude information incorporated in the display (thickness of lines, brightness, color), but perhaps they thought it was geeky enough as is.
