Friendly reminder: check your spare!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by macman408, Mar 31, 2014.
  1. macman408
    1,179
    368
    Today was my annual maintenance day; rotating tires, oil change, new cabin air filter, etc... Anyway, in adjusting the tire pressures to their new locations on the car, I also checked the spare tire, which is always a good idea. I think at last year's maintenance, I just did a thump test, and it seemed pretty solid, so I didn't unscrew it to get to the valve and actually measure it. This year, I measured it, and it was 34 pounds - the spec on both the tire and door jamb says 60 pounds is the correct inflation pressure, so I filled 'er up.
    So friendly reminder: don't forget to check your spare tire's pressure BEFORE you need it. It doesn't have TPMS, so it won't warn you if it gets low. And if you pay somebody else to do your tire rotation and other maintenance, I wouldn't count on them checking it for you - out of sight, out of mind.
    Side note: Why'd they have to make the spare so that you have to remove it to access the valve? It'd be nice if you could check it without removing the tool kit and tire.
    WolfpackBill, Yakoma, ptn and 2 others like this.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    You can get an extender on eBay.
  3. Den49
    Den49 Member
    498
    272
    Maryland
    Good advice to check the spare tire pressure. I check the pressures in my spare tires in the fall just after the temperatures take a drop, spring and before any long trip. They often require air. I inflate the Prius spare tire to 62 psi, a couple psi over the 60 psi spec.
    jdcollins5 likes this.
  4. Indy John
    Indy John Member
    75
    33
    Indianapolis
    I second the extender idea. I bought one from Accu-Gage. I can check and air up the spare without removing it. If I remember right it was about $10 and worth every penny.
  5. bisco
    52,390
    two great ideas, check the spare and get an extender. i didn't know there was such a thing and hate pulling everything out and flipping the tyre over. thanks guys!(y)
  6. NuttyKat
    NuttyKat Member
    70
    49
    Eastern NC
    2014 Prius c
    Glad I read this thread! When I first checked my spare pressure and saw that the tire had to be removed, I was not a happy camper. Going to order an extender now. Love this website!
  7. bisco
    52,390
    i see the accu gage for under 10 dollars. it's about 40" long, seems like a good deal.
  8. loaddown
    loaddown Loaddown
    34
    St Lucie West, FL
    The reviews have complaints that half of them leak when new.
  9. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Gives you an opportunity to check your spare tire well for water, too!
    :eek:
    exstudent likes this.
  10. bisco
    52,390
    but at least they're easier to fill.:cool: maybe having no spare and putting one above decks is a silver lining.
  11. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I have had mine for several years now and no leak to date. I never put too much emphasis on reviews.
    Okinawa likes this.
  12. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
  13. bisco
    52,390
    love it!:p
  14. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    +1 for removing the spare; might catch an unwanted water leak.
    Don't forget, the extenders will make the spare loose a few pounds when you finally remove it. Air is fed to the hose extension, which is coming from the small volume compact spare.
    Saw the eBay spare tire inflator extender. At $15.67 (1-27-2015), I would rather put that money towards a 12V air compressor. A search on Amazon for "12V air compressor," has them starting from $16.78. $1 more (excluding possible shipping and taxes), you have something more useful. Pepboys and Sears has decent 12V air compressors that go on sale a few times a year; I got one during these sales.
    Yakoma likes this.
  15. bisco
    52,390
    good idea, but it doesn't solve the problem of having to remove the spare to check the pressure. i don't get why the couldn't design it with the valve topside.
  16. retired4999
    2,652
    627
    Eau Claire, Wi.
    Give it the hammer check.
  17. GregP507
    GregP507 Senior Member
    3,002
    481
    Is there any excuse for not carrying an air compressor on-board?
  18. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    I went to check my spare, and it was gone! :p
  19. Mendel Leisk
    41,903
    When we took delivery of our (new) 2010 the spare was down to around 40 psi. So much for Pre Delivery Inspection. :rolleyes:
    I'd agree, it's a pain to check. Same thing to access the 12 volt, you need to haul half the hatch floor out.
  20. jdcollins5
    5,131
    1,346
    Wilmington, NC
    The only issue that I have with one of these is that if not used regularly the seals dry out and the compressor does not compress air. I had one for years and when I finally needed it, no air. The compressor just ran and ran.
    If you have one, use it regularly.
