  1. Burna J
    1,065
    3,334
    53
    Long Beach, CA.
    Thanks toyopri808. I'm real happy with them.... But what's IG?
  2. Eugene Hong
    Eugene Hong Member
    114
    30
    Bay Area, CA
    I think it stands for Instagram
    Burna J likes this.
  3. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    finally able to install my projector fog lights....
    Michael325, ptn, Dylan Doxey and 4 others like this.
  4. Heresjohnnee
    Heresjohnnee Junior Member
    56
    St. Louis
    Dylan Doxey, Dawit and ckam1989 like this.
  5. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Looks good Bino. How the new light out put compared to it old setup?
    How's the cutoff with these projectors?
    VS980 4G ?
  7. xliderider
    xliderider Senior Member
    7,907
    3,137
    Honolulu, HI
    +1, I'd like to see a good shot of the cutoffs.
    Light output should be no problem as they are HID. Hopefully, the reflector bowls can deal with the heat from being enclosed in the small confines of a foglight projector housing. Does the housing have some heatsink material or heat dissipating fins, etc?
    SCH-I535
  8. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Now with 3 daily drivers to swap winter tires, it was time to upgrade to air! (Especially with tire shops getting more expensive and tendonitis making it harder do it with only hand tools.) It's an IR 2115QTiMAX with 300 lb. ft. in reverse and selectable forward force. It's very light (2.5 lb.), small, quiet and works OK with my 6 gal. pancake compressor set at 120 psi. The second of 4 force settings puts the lug nuts a bit under 76 lb. ft. and the torque wrench finishes the job. The 6 gal. tank is small, but it flows enough air to break the lugs loose, recover while jacking the car, remove the lugs, recover while swapping wheels & starting the lugs, tighten the lugs, and recover while lowering the car & torquing the lugs.
    I bought it on Amazon, as I had a gift card from Christmas. This is a 3/8" drive unit and I wish I would have bought the 1/2" unit (same size and power) because many stores don't carry 3/8" impact sockets (especially deep sockets in sizes above 3/4".) I ended up finding a 3/8" to 1/2" impact adaptor and a 1/2" drive 13/16" deep impact socket.
    Now the the Prius is done, I just have to wait to be sure winter is over to do the Ridgeline and my wife's Fit.
    Specs:
    2115QTiMAX
    Obligatory Prius pic:
  9. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    here's some pic of the light....
    ckam1989 likes this.
  10. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :) Vehicle height looks perfect. Persona wheels are BEST!:)
  11. CTitanic
    CTitanic Member
    153
    South Florida, FL, US
    ;) Guys, picture rotation is an easy feature included in many editing tools for PC and smartphones.
  12. xliderider
    7,907
    3,137
    Honolulu, HI
    That looks great! (y)
    Can you get a shot against a wall about 15 to 20ft away? :)
    sfv41901 and ckam1989 like this.
  13. Chop
    Chop Junior Member
    Cincinnati, Ohio
  14. longshot
    longshot Junior Member
    68
    Where did you get these?
    cm_tenderloin ?
  15. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    Looks great BINO. Always wondered how those were.
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I was just about to ask the same thing
    VS980 4G ?
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    U can get the signal mirrors w/covers on eBay
    VS980 4G ?
    longshot likes this.
  18. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I could do that.... I'm just a little busy this coming days but I'll post it as soon as I have a pic ...
    ckam1989 and sfv41901 like this.
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    :D
    Totally understandable
    VS980 4G ?
  20. aportades
    aportades Team Thrust Racing
    76
    177
    San Diego, Ca.
    Thanks man!!!
