EXACTLY where is the VPNS speaker on 2014 c1
Discussion in 'Prius c Accessories and Modifications' started by robertmaria, Mar 31, 2014.
  1. robertmaria
    robertmaria Member
    202
    please DELETE this account
    2014 Prius c
    I can't stand it. The space-age squeal of the VPNS sounds like metal rubbing metal without oil. Itz got to go. I read here that itz behind the driver's headlight but I don't see the white connector anywhere obvious. Please help. Mahalo (ps it is a 2014 c level 1)
  2. w2kpugsly
    w2kpugsly Junior Member
    97
    san diego
  3. EndiSky
    EndiSky New Member
    Newbury Park, California
    I had to google what VPNS was! Not even sure if I have that on my 2013.
    w2kpugsly likes this.
  4. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    You do, but if you don't notice that you have it, you don't need to disconnect it. :p
  5. robertmaria
    robertmaria Member
    202
    2014 Prius c
    and so the VPNS speaker is somewhere unknown,,,
  6. Jeremy B.
    Jeremy B. Junior Member
    I am with you in that I can't stand it as well. The speaker on driver's side in the very front. if you look behind the light fixtures it should be there. I haven't unplug mine since I am loaning it but there is another post of someone showing how to disable it.
    robertmaria likes this.
  7. bisco
    52,407
    the approximate location is shown in post #17 of the above link in post #2.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm convinced the Prius crowd is an auditorially sensitive bunch.
    The venom in which the VPNS is approached, along with the intrinsic hatred of the reverse beep.
    I seldom hear my own VPNS. About the only time I can occasionally hear it, is if I'm going through a drive through with my window rolled down. Otherwise? I know it's working but- I never hear it.
    But carry on...maybe my hearing is just getting bad?
    ztanos and Mendel Leisk like this.
