Prius ECOHITCH, who has one?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by neez, Mar 28, 2014.
  1. neez
    neez Member
    194
    37
    Does anyone have one of these ecohitches on their prius? It's as stealthy an installation as you can get, and it comes in 2" receiver which i like for my bike rack.
    Torklift Central Eco-Hitch Stealth 2" 2010+ Toyota Prius & Prius Plugin Trailer Hitch | Torklift Central
    My main question is does anyone notice any impact on fuel economy on the highway with one of these? Does it bottom out at times? My 2008 impreza hitch occasionally slams and scrapes the ground when i drive into a steep hill.
    Obviously won't be towing, it's manly for a bike rack.
  2. neez
    neez Member
    194
    37
    No one has this hitch?
  3. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    My buddy has the older version that you had to cut the panels. He hasn't had any complaints on MPG or scraping. I don't think it would be any different than other hitches and perhaps better because it is more tucked into the car. If I were buying the hitch this is the one I would get.
  4. BreitrthnU
    BreitrthnU Can you smell the premix?
    255
    Tampa, FL
    Although I don't have this hitch, I do have a regular Curt hitch and I still get a calculated 48mpg I get 50 when I really drive like a granny. So I doubt theres a noticeable hit in MPG. Keep in mind you don't have to cut anything on the Curt.
  5. Torklift Central
    Torklift Central Junior Member
    Kent, Washington
    The EcoHitch for the 2010+ Prius does require minimal cutting into the car's plastic cover, this allows the hitch to be completely hidden behind the bumper - maximizing ground clearance. This picture shows the small cut points that are made during installation.
  6. neez
    neez Member
    194
    37
    cutting the plastic shielding doesn't bother me, i think i prefer the hidden look but most importantly the larger 2" receiver.
  7. fuzzy1
    10,602
    Sorry, I was traveling and didn't see this thread until now.
    Yes, I have this hitch. It was installed too soon to get any precise before/after MPG comparison, so I don't know if the raw hitch produces any loss. If it does, it is small.
    But the rack and bikes, not surprisingly, do produce a substantial MPG hit. Percentage-wise, I think the loss is about the same as the roof racks on my two previous cars, about 15%. But because the baseline fuel consumption of this car is much less, so is the absolute fuel cost of this hitch-mount bike carrying arrangement.
    With the car unloaded, my hitch has 10 inches of ground clearance. I'll be shocked if it ever drags on anything.
    I intend put the equivalent Torklift hitch on the household's new '14 Forester too, but haven't yet reached that stage.
  8. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    Does the hitch come with a template to make the cuts or do you have to eyeball it? What do you use to make the cuts?
  9. Torklift Central
    Kent, Washington
    The hitch comes with detailed installation instructions on where to make the cuts and a picture of the completed cuts. We suggest making the cuts with an air saw:
  10. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    As most people don't have an air saw and you are just cutting through plastic, I assume you could use a small saw such as one used for drywall?
  11. Torklift Central
    Kent, Washington
    Yes, you should be able to use any small saw that works for you so long as it has a fine-tooth blade - fine tooth blades make the cleanest cuts. You can also use a larger tooth-blade but the plastic might fray in which case you would want to clean up the cut with a razor blade. It's really your own preference but the air saw tends to work the best.
  12. Correllaaron
    Correllaaron Junior Member
    San Jose, CA
    I have installed the 2" on my 2012 Prius 3 and my friends 2010 Prius as well. This thing is great. I do not notice a hit on MPG, but it does make the car heavier. Feel free to ask me any questions as I have installed several.
  13. fuzzy1
    10,602
    Living in Torklift's home region, I just went to their shop to have them install it.
  14. Ktnws
    Ktnws Junior Member
    San Diego, Ca
    Is the torklift really the only 2 inch hitch available for a 2011 prius? Everything about it sounds great, but the price! is this just an overall fear of liability or is there a real issue? I have a 29er mtn bike full carbon, maybe max 27 lbs that i want to stop cramming inside the car (fits, but is a pain). My bike is worth nearly as much as my car and I have the kuat NV bike rack for a 2 inch receiver left over from my days of driving a 4 runner. The rack cost me several hundred dollars and therefore, I would like to find a 2 inch receiver and reuse vs buying a new one....and absolutely no way am i playing around with some crappy adapter from 1.25 to 2. Also do you just buy them online? anyone know of a place in Southern Cal that would sell and install?
  15. Jason Nguyen
    Jason Nguyen New Member
    I have installed the ecohitch in my prius, it's well worth the money they are asking for, ordered it on Monday, recieved it by Thursday,. I bought it for the reason that I'm getting ready for later purchases of a truck or SUV when my family gets bigger and don't want to buy a 1-1/4 to 2" adapter
  16. OkCorrell
    OkCorrell Junior Member
    The 2" hitch gives a much more solid feel with accessories. Especially the double bike rack that I carry with it. I would recommend these to friends and family.
  17. engineerd
    engineerd New Member
    Sorry for bringing up an old thread. I just installed an ecohitch on my car and while the finished product looks great, I was very disappointed in the installation process and instructions. Maybe it's just because my car is the Plug-In version. Since this is one of the threads that convinced me to get an ecohitch I'll post my experience here.
    1. The installation instructions read like the person writing them hasn't actually done the installation. There were typos, unclear descriptions, and the fastener size call-outs were wrong. The instructions specified to cut way more of the plastic than is necessary.
    2. I DID have to trim some sheetmetal to get mine (new version, ordered 9/4/2014) to fit.
    I've marked up the instructions with some comments here: ECOHITCH INSTAL - Imgur
  18. bigmike98208
    bigmike98208 Junior Member
    I just installed one on my 2010 last night and didn't cut those tabs off that you did. I agree that the instructions aren't very clear on where to cut the plastic except for the 6 x 3-3/4" rectangle around the receiver but I was able to eyeball it and mark where to cut with a sharpie. I used a sharp box knife and electrician scissors to cut the plastic. I couldn't get a lot of the plastic fasteners to go back in the holes in the bumper cover because they are too long and hit the hitch. I also broke almost all of the fasteners that connect the rear plastic cover to the one further forward.
    Glad I was wearing eye protection because when that underbody cover came off I got a face full of dirt and gravel!
  19. Torklift Central
    Kent, Washington
    From your feedback here we have forwarded a request to our tech support team that works with our engineering department and is involved in creating the installation instructions to review and make any necessary clarifications to our installation instructions. One of our EcoHitch specialists would like to contact you directly to discuss our installation process of EcoHitch for Toyota Prius and address any other questions, or suggestions you may have. We greatly appreciate your feedback as it is critical for us to meet our goals of continuous product improvement. Please send your contact information to [email protected] and we will respond to you promptly.
  20. engineerd
    Emailed, thank you.
