Mistakes of a Newbie Hybrid Owner
Discussion in 'Prius c Fuel Economy' started by Dan Lovell, Mar 9, 2014.
  1. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    I for one am intrested in the results of alt driving styles. If someone is willing to drive two different styles and do fill ups to doc. the results.
    Do you know anyone who has evaluated this specific idea on the prius c? I think you have your opinion and don't want to be confused with any information that doesn't support your view.o_O
    IMO PriusChat is to encourage discussion of these type of questions. so lighten up. Their results will not be the final word on this topic. it will be specific to their dirving type/distance ect.. If their mpg is better then we can check to see if our mpg increases with quick acc. instead of slow acceleration.
    it used to be common understood that steady speed gave the best mpg. that is not true on hybrids. So I think there is room for improvement of my understanding of this topic.
    Ronan likes this.
  2. Dan Lovell
    Dan Lovell Junior Member
    35
    Chicago, Illinois
    2014 Prius c
    Let me explain again.
    Near WOT, and just until the car gets up to the speed limit (cruising speed).
    Then feather the gas peddle, using pulse & glide techniques to maintain cruise.
    Today I did this going the same route to work, and I got 59.8 MPG, which I calculated just after topping off the tank at a gas station 600 feet from my home. The round-trip was 19.8 miles to work, then home.
    This was driving with the near WOT to cruise.
    Tomorrow I will get to speed the "normal" way, keeping the graphic out of the power orange as much as possible.
    One thing I'm learning is that near WOT when the engine is cold may not be the best time to do the near-WOT to cruise. I am thinking that it works best with a hot engine.
    Ronan likes this.
  3. xraydoug
    571
    176
    Roseburg, Oregon
    It is my understanding that the prius c actually de tunes the engine so it will warm up quicker. this reduces the amount of power the engine makes and may cause engine to use more fuel. So I think you may be correct.
    To preserve the accuracy of your testing I would do a comparison without warming up. and later do after warming up engine. That way you would gain more info about both ways.:)
  4. Dan Lovell
    35
    Chicago, Illinois
    2014 Prius c
    Stay tuned, because my real world study will be completed this Friday. I have found anecdotally, that getting to speed (cruise) using near WOT is the way to save gas over a given trip of at least a few miles. Anecdotally, I have found that getting to cruise slowly actually hurts MPG; again for trips more than a few miles.
    My five day test should reveal close enough, if my hypothesis is true or not.
    My loop is 19.8 miles (home to work then home). I normally warm up the engine a few minutes via a remote starter, but for this 5 day test of mine, I've decided to just start the car cold, and drive off. I'm not relying on the car computer to calculate the MPG, primarily because I've heard more then a few other C owners say they didn't trust the computer. I calculate manually just after topping off the tank at a station a few hundred feet from my house.
  5. xraydoug
    571
    176
    Roseburg, Oregon
    Sounds logical to me. keep us posted on the results.
    My lifetime mpg on the computer is within 1 mpg, however I am not sure it is always accurate like for short times where the engine is accelerating. I think doing with the pump and odometer will be better.
  6. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    If steady speed doesn't give the best mpg on hybrids, then why did Bob Wilson use cruise control on a flat road to develop his mpg chart? If that's not using steady speed I don't know what is.
    My "view" only happens to be the conventional wisdom developed by the automotive industry and motoring commentators over decades, but if you want some results, read on.
    A 16 mile return city trip, last Friday, fine, dry, calm weather, temperature 68-70F
    Mostly multi-lane roads with 30, 40 and 50 mph limits, even mix. Fairly flat running, with a hill (100 ft elevation) to start and finish, light, steady traffic.
    Driver and 1 passenger, tyres at 40/37 psi, gas E0, cold start.
    43 traffic lights / roundabouts / give-way's - had to stop at 20 of them.
    3 stops for a total of about 1 hour.
    Driving Technique:
    Cruise with traffic, light acceleration (60-75% on HSI pid, Torque Pro).
    Fuel consumption (indicated):
    67mpg - my Fuely tank calculations have shown the car to be 2mpg optimistic.
    Now it's your turn....
  7. vskid3
    vskid3 Active Member
    773
    228
    The computer will be much more accurate than filling less than half a gallon at the pump.
  8. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Truth IS that neither method will be anywhere close to "accurate".
    It might be interesting but it won't really prove anything........especially since the "pulse and glide" technique has been added to the picture.
    Too many possible variables involved to make a good test.
    My question about this statement was a serious one.
    Do you have any real information about that study or are you going from memory here ??
    I was actually driving a car back then and my recollection of the study is a bit different......in that I think it concluded that a firm acceleration at medium throttle was a tiny bit better than slowly creeping up to speed with almost no throttle.
  9. Dan Lovell
    35
    Chicago, Illinois
    2014 Prius c
    I came across the pamphlet while my father was cleaning out his garage. It said that a brisk start up to cruise saved gas over a steady slow rise to cruise speed. I know this to be true with my 2007 Yaris, and I am convinced of this after driving that car many ways for 160,000 miles.
    In short, keep the time accelerating as short as possible.
    Now will it be true for the C? I'll know for sure soon.
    As to the accuracy of my testing, true it is not scientific, and is not absolutely accurate, however it is accurate enough to show a trend, and that is all I need. I'm an engineer by trade so I am going about this with the knowledge of what factors I can control and which a I cannot. I've not many delusions here.
    Perhaps, but I've heard other voices saying that the computer is not to be relied upon.
    I'm using both the computer and calculating manually through the replacement of gas.
    Cruise control?!? Oh gosh no!
    Steady state using cruise control is Far, Far, Far from being the best way to get the best MPG.
    You won't find any die-hard HyperMilers ever doing that, no way.
    The best way to get the best MPG is to keep the cruise control off, and do pulse & glides, feathering the gas pedal.
    When it comes to Hypermiling, cruise control is not your friend.
  10. hieronymous
    hieronymous Member
    154
    92
    2013 Prius Plug-in
    Darn, I only got 84 mpg on half a dozen flat-running, round trips in the city since Xmas using cruise control - I just knew I was doing something wrong!
    GT-I9300 ?
  11. Dan Lovell
    35
    Chicago, Illinois
    2014 Prius c
    You could have gotten better without cruise control.
  12. NewYorkan
    NewYorkan Junior Member
    64
    Only true if we live in hilly area. Same here in NY. We basiclly live on the mountains. lol. So cruise control is number one gas killer. But I can see that cruise control can do better in flat area like texas. Last time, I was there, i can see th highway disapperred from hoziron. Cruise control is so steady, and probably do better job than our leg.
    Accidently, found this on the wiki. Toyota Prius/Driving tricks - Wikibooks, open books for an open world
    " A gasoline ICE (Internal Combustion Engine) is more efficient (in terms of power produced/fuel consumption) when operating at higher effort due to smaller throttle losses."
    Suprisingly, they said exactly what Dan said. Don't know how good is this wiki website. But for over 20 years of driving, I was always thinking opposite way. Where more gas injected to the engine, the more unburned gas came out the muffler.
  13. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    You have to be careful though when it comes to efficiency. Better efficiency doesn't always mean less gas. Think of it this way. You have a garden hose with a nozzle on it. If you turn the nozzle to mist, it is nowhere near as efficient as if you just let the hose run full. But at the same time you are still using less gas.
  14. vskid3
    773
    228
    MPG isn't the same as the efficiency of the engine. They're generally related, but not the same thing. The efficiency of the engine is based on the amount of power produced per gallon. An engine at or near WOT and at lower RPMs (around 1500-2500RPM) is where most engines are most efficient. Its known as Brake specific fuel consumption (BSFC). That's the logic behind brisk acceleration being better and why P&G is generally better than cruising with the throttle almost shut.
  15. orenji
    orenji Senior Member
    5,887
    3,488
    All these years we have been told to drive with cruise control on, to save gas and money, I guess that was incorrect all these years, who knew! ;)
  16. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I know that... that's why I said it.
  17. Dan Lovell
    35
    Chicago, Illinois
    2014 Prius c
    You are correct. We are told to use cruise control because pulse and glide is too fatiguing and takes too much concentration for the masses to do. So the next best thing is to use cruise, but it certainly is not optimal.
    minkus likes this.
  18. hieronymous
    hieronymous Member
    154
    92
    2013 Prius Plug-in
    Well I'm getting 84 mpg with cruise, so when someone walks the walk, and demonstrates doing better than this, then I might believe it!
    GT-I9300 ?
    orenji likes this.
  19. fuzzy1
    10,553
    For more than half the drivers out there, cruise control is still an improvement, and for nearly no effort, so it is not really incorrect.
    But plenty of us learned that there is room to do even better, without excessive effort.
    Ronan likes this.
  20. vskid3
    773
    228
    My mistake, looking back at your post I'm not sure why I thought you were wrong.
    If someone isn't focused on driving for mileage, cruise will likely get them better mileage. I'll P&G if I'm alone on the road, but I'll usually use cruise if I don't have enough room around me. I also use cruise on road trips, because there's not a whole lot you can do at 65-75mph. I would rather not have a sore foot when I get to my destination. ;)
    ztanos likes this.
