PRIUS HIGH PERFORMANCE ?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Johnnu, Apr 4, 2014.
  1. Johnnu
    Johnnu Junior Member
    44
    I know that this might be something that 'we' Prius owners don't condone, BUT, there are three questions that come to mind for this OLD street racer turned gas miser:
    1) Is there a way to significantly increase speed/acceleration performance in a Prius?
    2) Has anyone even thought of putting a gas powered V8 in one of these 'sleepers'?
    3) IF speed/acceleration modifications are possible, howzzabout a Forum section dedicated to making our Prius' into sleeper/BEASTS?
    Thanks, J
    2010_Prius_I_White likes this.
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I will link some ideas folks have tried. Modifying the current drivetrain to produce more power serves to charge the battery more often, not the traditional measure of performance. In hillclimbs, where the battery contributes until drained, it can make a real difference.
    If you made a fiberglass replica of a Prius, you could set it in a RWD V8 based chassis.
    Got Hybrid? - Sport - Car and Driver replaced Atkinson cycle engine with Otto cycle engine from Yaris
    http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=20&ved=0CIsBEBYwCTgK&url=http%3A%2F%2Fpriuschat.com%2Fattachments%2F1st_supercharged_then_turboed_nhw10_prius_optimized-pdf.63512%2F&ei=jL4-U5CsLrDKsQSi7oGQCw&usg=AFQjCNFedkd7yL48cE6HGm2gwXvnRoauZA&sig2=Tw1XwO7IonDvF0fE8aKjqw&bvm=bv.64125504,d.cWc Supercharged engine, then trying again with turbocharging
    None of these are 'kits', all custom fabrication.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    There are incremental improvements possible, posted above
    I suspect this means you have never opened the hood. As you read the super/turbo charging articles, notice how space constrained he is.
    There are long threads on PriusChat by folks who think magic overrules physics.
    Mishelle likes this.
  4. alekska
    alekska Active Member
    435
    138
    Atl
    The easiest way would be to add additional electric motor and extra battery, that would drive the rear wheels, like in Highlander Hybrid 4x4 . That would require to modify rear suspension, but its probably easier than to put turbo on this engine.
    - Alex
  5. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Is it just me or is he sending V8 power to a spacesaver spare tire? [​IMG] Looks like a fiberglass Prius body over a chassis that worked would have been better.
  7. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    He has tubed out the rear, widened the factory wheels and installed a ladder bar suspension. If you can get by the Prius hate, it's an interesting build.
  8. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    To each their own, but I don't get it. o_O
  9. vskid3
    vskid3 Active Member
    773
    228
    The Camry Hybrid puts out about 65-90HP more than the Prius, depending on the generation of each. The latest Camry puts out 200HP, compared to the Gen2 Prius' 110HP. That would make for a pretty healthy power increase while still probably getting the Prius' EPA mileage with a good driver.
  10. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    I once knew a guy that put a 318 Chrysler engine into a Sunbeam Alpine.
    He couldn't keep tires on it !! :)
    Alas he eventually twisted the frame from all the torque and junked it for parts.
    If you have a TON of money and time to invest, hell yes GO FOR IT and keep us posted but my personal opinion is that it will be a fools errand.
  11. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Depends. What's it worth to you? The simplest thing would be to leave the front of the car alone and put a six cylinder in the back that just powered the rear wheels. You'd leave the tonneau cover over it so it didn't show, maybe put in a couple of kid seats and some stick figure cartoons in the window as camouflage , have triple(?) the stock horsepower, might make a little money with it as a sleeper.:D
