Consumer Reports Admits Error
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tempus, Mar 7, 2006.
  1. landstander
    landstander darling no baka
    108
    A place where the nuts hunt the squirrels
    Not necessarily. While it's certainly true that the Prius currently retains it's value well, that could easily change as hybrids become more and more common. Not that this excuses the apparent lack of fact-checking in the original publication, of course.
  2. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
  3. brasche
    brasche Member
    156
    Orlando, FL
    Its all very subjective and there is likely no statistical signifigance to CR's projections.
    I did my own analysis using my current gas hog (BMW 735i, ave 17mpg), with $3 fuel costs, current insurance, and $2500/yr BMW maint reserve. My numbers show an 11 year break-even point!
    Costs was obviously not the major factor in my decision.
    Brian, '06 White/Tan #8
  4. ghostofjk
    ghostofjk New Member
    979
    I agree. Consumers Union has been America's unofficial Consumer Protection Agency---regardless of who's been in power---since long before Ralph Nader started doing his own [laudable] thing.
    It's indeed a badly timed error, and CR knows it. But I won't hold it against them. They've helped me make more good buying decisions in my lifetime than anyone else ever could or would have.
  5. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    A bit off topic, but there are those that think:
    • The HOV lane is used to go speed limit when the other lanes are crawling.
    • The HOV lane is for going as fast as you can within your personal comfort level for the vehicle and probability of getting a ticket.
    I suspect the latter group is POed by anyone doing the speed limit or a bit over in the HOV lane.
  6. tochatihu
    tochatihu Senior Member
    9,850
    3,806
    Kunming Yunnan China
    2001 Prius
  7. lowspeed
    lowspeed Member
    267
    Here's a comparison:
    http://www.kbb.com/kb/ki.dll/kw.kc.sbk?kbb...2;&&&comparetab
    Clearly you get more leg room space.
    More technology
    Bigger cargo capacity
    No need to worry about emission passing for life. (15 years)
    Better Turning Radius
    You need to get the upgraded corolla to get keyless entry and other stuff....
    No SKS
    Does the corolla have controls on the steering wheel ?
    After all this its still cheaper to own a prius. Amazing.
  8. Tideland Prius
    16,602
    Tis true but not everyone can afford a new hybrid. If they had a choice between a used 2004 Prius loaded with nav, bluetooth and still gets 50mpg vs.. say I don't know, the new 2008 Honda Fit with none of the above, 50mpg, smaller engine, smaller car but brand new.. the choice becomes difficult... unless you're set on getting a new car no matter what.
  9. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    It's too bad more people don't pay attention to what Prius owners say about cost.
    * There is no comparable car
    * Gas savings are variable to what we owned before,not just the Corolla
    * My insurance was no higher with the Prius then it was w/the Sport Trac
    * Time is $$, time saved at the pump, at the service station, smogging..
    * And maintenance?? How could that have ever been considered higher?
  10. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    Primarily depreciation. I also don't care for the fact that they figured $2/gal gasoline for the next 3 years, then $3/gal and finally $4/gal for the fifth year, but in the article they only mention $3 and $4 gasoline.
    I wrote to Vincentric, the source that's mentioned in the CR article. They put up some new numbers and gave me a link:
    http://www.vincentric.com/hybrid_analysis/index.asp
    Note that this still assumes 56% depreciation on a Prius over 5 years, whereas the Kelley Blue Book value is 35% depreciation from MSRP (private-party transaction, good condition, normal mileage) over 5 years, and actually 0% depreciation on the 2004 MY (first year of redesign) with 33K miles. So there numbers seem like a stretch to me, but at least it's closer to the truth, and the Prius comes out $4600 ahead of a Camry LE and $196 behind a Corolla LE.
    I also think the Matrix is the closest competition to a Prius, that's what I was looking at since it's cheaper and still has decent MPG. Also the HCH, but it was a little smaller and not noticeably cheaper than a base Prius.
    nerfer
  11. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Nerfer, thanks for the info. Interesting stuff. It's good to see that vincentric compares a camry as well as a corolla.
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    CR made a mistake, but i still think their integrity is head and shoulders above most other magazines. they will print a full retraction in their next issue. they have done this before.
    making mistakes is an unavoidable part of life. bad integrity is not. i am confident they will do their best to right things. and yes, after its out, it does not matter whether it was right or not. its only what people remember
  13. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    The article is rewritten (and availiable to read without a subscription). I didn't see a retraction though. :(
  14. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Blogging etiquette says that if you edit an entry for a correction, you make a note on the post.
    I guess CR is above that.
    Stealth-Edits all around. Does this mean I need to check back regularly on CR to see if things change? Do I need to take screen shots for comparison day-to-day?
  15. MarcIsrael
    MarcIsrael New Member
    March 9th E-mail from Consumer Reports to me regarding my March 4th notification of their error:
    Thanks for taking the time to contact us regarding our April 2006 report,
    "The dollars & sense of hybrids". Please accept our apologies for any
    inconvenience you may have experienced.
    We've corrected a calculation error involving the depreciation of the six
    hybrid vehicles that, in the report, were compared to similar
    conventionally powered counterparts. The error led us to overstate how much
    extra money the hybrids will cost owners during the first five years.
    Our revised analysis shows that two of the six hybrids are projected to
    recover their price premium in the first five years and 75,000 miles of
    ownership. The Toyota Prius and Honda Civic Hybrid provide a savings of
    about $400 and $300, respectively, when compared with their all-gas
    counterparts-as long as federal tax credits apply. But extra ownership
    costs during the first five years and 75,000 miles for the other four
    hybrids ranged from an estimated $1,900 to $5,500, compared to similar
    all-gas models.
    Previously, our analysis showed that none of the six hybrids we've tested
    recovered its price premium in the first five years and 75,000 miles of
    ownership.
    Please be assured that the error does not affect the main message of the
    report, which is that most hybrids do not save their owners money over the
    first five years, and that the benefits and costs of hybrids vary
    significantly, depending on the model. Because of the wide range of hybrid
    vehicles available, it's especially important for consumers to look
    carefully at all aspects of a vehicle before buying.
    In maintaining our commitment to the highest levels of accuracy and
    credibility, we've posted a revised version of the report on our website.
    The revised report, including a new and more detailed comparison chart is
    posted at www.ConsumerReports.org/autos2006 (Please click on the "The
    dollars & sense of hybrids" link that's located in the middle of the page).
    We do hope that you will visit our website and review our revised report.
    Thanks again for taking the time to write. Your interest in our work is
    greatly appreciated!
    Sincerely,
    Jenny Martin
    Customer Relations Coordinator
    840636
  16. bsd43
    bsd43 Member
    130
    San Francisco Bay Area
  17. OUscarb
    OUscarb Member
    167
    Sooner Land, Oklahoma
    I ordered a Prius in Sept 05' the dealership kept messing me around, so I called another dealer the 1st week of Dec. He said he had one on the lot, and the SSB was coming in on the 22nd. I took it, and since it hadn't reached port as of then, I could upgrade the interior to leather. Worked out great!
    OUscarb
  18. lbligh
    lbligh Member
    137
    24
    Northern Virginia
    The Chicago Tribune has an article about the Consumer Reports error. The first word in the article is "Oops."
    http://www.chicagotribune.com/business/col...hi-business-hed
    A search on "Google News" shows that as of today, there are 43 articles about the error. I suspect there were a lot more articles about the initial, erroneous analysis.
  19. lowspeed
    lowspeed Member
    267
    I had to take a loaner for a day while the prius is getting serviced for these problems:
    http://priuschat.com/index.php?act=ST&f=7&t=16160
    http://priuschat.com/index.php?act=ST&f=19&t=15018
    http://priuschat.com/index.php?act=ST&f=19&t=16922
    http://priuschat.com/index.php?act=ST&f=19&t=16833
    So they gave me a 2006 corolla with 1400 miles on it.
    I must say i miss my prius :)
    There is no way they are in the same category.
    I miss the steering wheels controls, the MFD and i miss the SKS the most. I hate the transmission shifting.
    There is no way anyone but a midget or a kid could sit behind me when the seat is pulled all the way back.
    I miss the hatchback design (way more trunk space).
    I miss the automatic A/C control.
    I did feel the my hands have more room in the prius (where the door is)
    The corolla is simply not in the same class.
    Hopefully they will fix the above small problems.
  20. tochatihu
    9,850
    3,806
    2001 Prius
    The "outdated" CR page I noted earlier has been modified:
    http://www.consumerreports.org/cro/cars/ne...rm=depreciation
    I would not suppose that the Corolla/new Prius comparison is the most appropriate either, but it is up to them to make (and justify) that choice.
    I still see their 5-yr projected resale value of new Prius ($9801) as strangely low. A 5-yr resale for the classic Prius is reasonably $13 to 14k. Meanwhile, a 5 yr old Corolla is about $9k at the same sources.
    If anyone knows where I might see justification for the $9801 price (without paying to do so), please let me know.
