Display problems - likely cause?
Discussion in 'Prius v Audio and Electronics' started by GregH, Mar 26, 2012.
  1. GregH
    GregH Junior Member
    Pittsburgh, PA
    I bought a 2012 Prius V (3 weeks ago) and the multi-function display is now behaving erratically. Radio presets disappeared, radio frequency not displayed, Satellite radio unavailable, periodic blank screens when switching applications, backup camera stays on after shifting to Drive, a few others. My dealer thinks a software update might fix it (three-day wait for a flash drive!) or a bad connection, but I suspect a bad unit and want him to order one just in case. Has anyone seen these type of problems?
  2. mega4m
    mega4m New Member
    We're having the exact same symptoms and bought within a week of the time you mention.
    Has your problem been resolved, and if so, how?
  3. Nivonia
    Nivonia Junior Member
    Ontario, Canada
  4. bpprius2011
    bpprius2011 New Member
    Same deal hear with 2011 29,000k just bought yesterday. Turn car off/on temp fixes. Will take to dealer and let you know. Heard it might have internal error code if checked -- not sure about that. Seems like fix is radio replacement.[​IMG]
  5. mp402
    mp402 Junior Member
    Arizona
    I have a 2011 Prius that had the same problem. It appears to be a know problem with my service tech. When it happened I took a picture of the display and then drove to the dealership. It was still under warr. so no issue, they replaced the radio with a "reconditioned" radio. Found out it was not reconditioned when I went to attach my phone and someone else's phone and contacts were setup.
    I call the prior owner of the radio, she programmed her home, to see why she returned it. Seems she is on her third radio, all had the same problem with the bad display. After speaking to the service manager, they were willing to replace the radio again given it was a repaired radio and not reconditioned. Decided to keep the one in the car, hopefully it was fixed correctly and i have another 3,000 miles under the warranty.
  6. cdrom
    cdrom Junior Member
    27
    My 2012 Prius v MFD just started having similar problems as touch mode no longer works. The screen is locked until I either increase or decrease volume using steering wheel buttons. After changing volume then can change functions, such as going from audio to apps screen but screen will not respond to touch. Question, is there a rest button or steps to get the touch function back?
  7. cdrom
    cdrom Junior Member
    27
    Just a follow-up, if the touch screen capability stops try and run the edge of a business card around the inside edge. Doing so should clear out any residual crud which keeps screen locked down and prevents the touch screen from working. Got this simple solution from dealership and their navigation guru.
    MontPriusv likes this.
  8. MontPriusv
    MontPriusv Junior Member
    Montana
    Thank you cdrom for this simple fix!! Just fixed my own non-responsive touch screen using a business card. Took it in to the dealer this morning and they had no idea how to fix it other than replacing the whole unit (which they were going to price out and call me back about). This is brilliant. Thanks for sharing.
  9. Mendel Leisk
    41,826
    Wonder how much replacement of these things is gonna cost, once they're out of warranty. :mad:
  10. blahblah_gc
    blahblah_gc Junior Member
    san jose
    I had the same problem for my 2010 Prius meaning the display is showing scrabble words
    , resolved it by unplug/plug back in the 12v battery. I had to replace the battery, it happened to resolve the issue once and for all.
  11. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    How much do those promotional offers for 250 business cards cost?
