Leather Seats Require a Lot of Air Conditioner Use?
Discussion in 'Gen 3 Prius Main Forum' started by cycledrum, Apr 9, 2014.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I have a pair of leather, non-perforated covers in my car. We had a high 70's, kinda muggy day yesterday, and low 80s the day before. Was getting that kinda sweaty jeans feeling, especially noticeable after getting out of the car.
    Was using light air conditioning off and on the way home. I don't like to use heavy air conditioning. Kinda defeats the purpose for being frugal.
    I got to thinking maybe leather seats are generally for people who are more than willing to just blast the air conditioning for a low cabin temperature to avoid that sweaty feeling on their pants/ skirts / seats. Do you agree?
    I could see very affluent people doing this as I don't they tend to be conservative on fuel or much of anything else.
    dupe post
    dupe post
  2. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I won't buy a daily driver with leather unless it is perforated with seat coolers / fans. I made an exception for my S2000 - but it's certainly not a daily driver.
    Some GM vehicles used to have a lap vent located below the steering column that you could direct toward the offending area.
    cycledrum likes this.
  3. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Goo point about the perforations on the seating surface!
    Luckily I ordered perforated Clazzio's last spring and they were fine with the summer heat.
    One minor downside- the OEM seat heaters weren't as effective with the Clazzio's installed- the leather is fairly heavy duty and there is a layer of foam on them too.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Hey, I grew up as a kid riding in the back of a 1967 Mustang with no air conditioning and vinyl seats.
    Which probably explains a lot.
    But on long, hot drives? My brother and I would literally peel ourselves off the seats in the back. Having bonded on a DNA level with the seats.
    Does Leather mean you NEED to use the AC more?
    Not necessarily.
    If I wanted leather...and this was a problem, I might invest $16.99 or less, into one of the many seat inserts that can act as a ventilating barrier. Take em out when the worst of Summer heat has passed.
  5. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Very affluent people have climate controlled seating surfaces in the back seat. The chauffeur can provide Palm Springs Desert type heat to Arctic Expedition Icing, depending on outside weather conditions or needs. :)
  6. haole man
    haole man Member
    107
    35
    Podunk, California
    This is why I prefer cloth to either plastic or dead animal skins.
  7. The Electric Me
    9,083
    5,801
    Yeah, but not using the air conditioning to it's max on muggy days kind of defeats the purpose of having air conditioning.
    I suspect you could of kept yourself in a humidity free and luxurious coolness and NOT of experienced any great loss of economy.
    On days when I need the air conditioning,- I just use it. I've never been shocked by any DRASTIC loss of economy.
  8. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    There's an old joke about how to tell that a person doesn't live in Las Vegas by the car he drives. One of those reasons is that the car has leather seats. I've been to Las Vegas in the dead of summer too many times, and it was definitely more comfortable with fabric seats than leather seats. Also, as I got older, I decided that is wasn't worth driving my Prius without using the A/C on hot days. I've paid my dues and will live out the rest of my life with the most comfort that I can easily afford.
    Mike
  9. B. Roberts
    691
    212
    Moderate A/C use is fine. When it gets warm, set the A/C to dehumidify and cool the interior to a comfortable level. You don't have to frost the windows to get comfort, even in the hottest weather. I do the same with heat in Winter. Dress for the weather and adjust climate inside car to a reasonable level.
    My MPG doesn't suffer too much in any season, unless the temperatures go to extreme low levels in Winter. That doesn't happen as often as it use to.
  10. Mike500
    Mike500 Senior Member
    2,593
    767
  11. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Ok, let's keep this discussion going. I live in the 'inner' SF Bay Area, between Oakland and San Jose. * It really doesn't get very hot here. That slight humidity we had yesterday is rare.
    Today's weather was typical: 72 deg. F, with some cool breeze. It's like this a lot, even in Summer.
    But, here's the thing: Today I used some A/C and other times opened the windows. The cabin certainly didn't feel hot, BUT ....
    the 'interface' between my body (legs mostly) is where the heat builds up with the leather covers I have. Was the same thing with the auto parts store leather cover last year. Neither are perforated. I don't know how much perforation helps.
    I'll give it some time, but at this rate, I might be switching them out for some cloth covers (good ones) by June or July.
    Hmmmmm...
    * if you go over one set of hills to Livermore, it's 15 F hotter in Summer there. Go over another set of hills, then you're in the Central Valley, add more degrees.
  12. bisco
    52,360
    wouldn't it be cool if someone had aftermarket a/c seat covers?
  13. The Electric Me
    9,083
    5,801
    An interesting thing about this discussion is that I think it brings up a reality about what we are taught or programmed to believe.
    Some things that are considered, the entry level, base or frugal, I think are just victims of perception. Again, I remember back to the 70's and 80's, when I was a kid. Many of the vehicles my parents bought were sold with Vinyl being the entry level upholstery...the first step upgrade was cloth. The vinyl was crappy, it got hot, sticky and split and cracked. So cloth seats were considered far superior. Leather was still the benchmark for the highest "luxury" but it pretty much went Vinyl-Cloth....and Leather if the vehicle was upscale enough to warrant it. I still remember my parents being proud of the new Corolla Station wagon they bought with "luxurious" cloth interior. Well it was luxurious, especially if compared to the vinyl seats of the 1967 Mustang.
    That is why I'm actually more than willing to like my "entry level" cloth seats. There are real benefits to cloth seats.
    The other "economical" or some would say "cheap" thing I actually like? Plastic Dashboards.
    People will complain about hard plastics being used in abundance in a dash board. But I like it. It's durable, IMO looks nice, and usually very easy to keep clean. I wipe down the Prius dash maybe once every 6 weeks with either Meguiars Interior Detailer spray, or 303 Aerospace Protectant. The rest of the time as a result of "cheap" hard plastics, I can keep the entire interior looking great by just using a Swiffer Sweeper insert or a duster to occasionally pick up dust.
    Thank god, I evidently have horrible taste and thus are not easily tempted by those things that are told to me to be the finer things in life.
    cycledrum and milkman44 like this.
  14. Mike500
    2,593
    767
    When I was a kid, my DAD bought a brand spanking new '61 Chevy.
    The dashboard was ALL steel with sharp protruding moldings. The came the steel padded dash wrapped in vinyl with a thin layer of foam plastic. Either of these would have resulted in a bad injury from even a 5 mph crash.
    Plastic, in the form of HDPE apparently is soft and crushable. I rather that the plastic dash crushed than my face and my skull. A crash onto a solid immovable dashboard also means a sudden stop. The brain inside the skull continues to move forward from inertia. This is what has caused most of the brain injuries in Iraq and Afghanistan.
    I'll take plastic any day.
  15. ETC(SS)
    7,335
    It's kind of funny how we've gone full circle on the seating surfaces with Toyota.
    Now?
    The entry level is cloth and the upgraded seats are plastic....unless you go aftermarket and get better plastic or sometimes a for-real dead critter.
    I tend to go with base trims, so I guess I'm "stuck" with the cloth, which is probably the best seating surface going these days - especially when you toss something like a dead sheep skin on top.
    Most people don't buy their options a la cart these days, so I'm not going to pay five thousand dollars in a higher trim level for a bunch of options that I don't want to get the one option that I'm looking for.
    As always:
    YMMV
  16. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    I don't like leather or leather "like" seats for all the reasons being discussed.
    If you wear shorts in the summer time........OUCH !!! :eek:
    I think car makers make a huge marketing blunder if they don't offer cloth as an option on their "premium" models.
    I'm presently shopping for a "road" car.
    Two years ago, Ford had terrible choices for the interiors of the Fusion Hybrids.
    Now it looks like you can get a top of the line Fusion Hybrid and still get cloth seats.
    If that turns out to be true........big applause for Ford and probably a sale too.
    NR427 likes this.
  17. neez
    neez Member
    194
    37
    The AC really doesn't hurt MPG too much unless you're stuck in gridlock traffic, or so i've found. It doesn't affect mpg on my commute at all since they changed it to an electric A/C compressor on the gen3. Sure, it depletes the battery quicker, but it takes a few minutes to do so. I was sitting at Sonic drive in with the AC set to 70 degrees on auto, ordered some food and ate half of it before i felt the engine turn on. I looked over and saw that the HV battery was fully depleted. I was actually really surprised it lasted that long before the engine kicked in.
    So it really depends on your commute and if you're in the right half of the eco range alot, with your engine running to recharge the pack. It doesn't effect MPG too much. If you're doing pure city driving, it will probably take a good hit.
    Double post
  18. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Ok, so I made use of the AUTO climate control on way home tonight. I set it to A/C and 74 degrees which is pretty high. OAT gage said 79 F ....
    the result is it felt pretty decent in the car. So, it seems the Auto climate control will help out a lot.
    Maybe when I set the A/C on without Auto control and put the fan to 2 or 3 clicks the cabin was still high 70s or 80 F , who knows.
  19. orenji
    orenji Senior Member
    5,887
    3,488
    How is not using the A/C being frugal? Are you getting a monthly bill from your local electric provider when using your A/C? (n)
  20. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Sounds like a solution.
    From what I recall, the Gen 3 Prius AC is pretty much the state of the art in efficiency and a big step forward from what is in other cars. I would't worry much about using it for comfort. Whenever its hot I always use it to protect battery life.
