Simple, cheaper mods for my new Prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by vallesj, Mar 17, 2013.
  1. kenmce
    kenmce High Voltage Member
    1,527
    502
    NY
    I'm picturing Sfcyclist sawing the heads off four screws and going out with some superglue... :D
  2. CTitanic
    CTitanic Member
    153
    South Florida, FL, US
    Could you post your pictures please? I would like to see how did you do it.
  3. Charlie5280
    Charlie5280 New Member
    2014 Chevy Volt
    I'd like to see as well
  4. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    My post is an older post. Regretfully, this Fall I had to have an insurance-covered rebuild of my front bumper as a dumpster truck crushed my left front corner, including headlight, while I was inside a coffee house - so I now have a new bumper sans plugged holes. However, I assure you that appropriate black nylon hole plugs of various sizes are super-cheap and available at any good hardware store. These nylon plugs take Toyota paint stick paint well.
  5. DadofHedgehog
    681
    281
    northern Virginia
    Oops - perhaps you meant how the lowered front license plate looks on the Prius. Here are two pix:
    Oops - perhaps you meant to see how the lowered license plate looks on the Prius. I just took two pix and tried to upload them but for some reason the site rejects them. (please note that the PiP has a horizontal silver color bar just above the lower grille which the regular Prii don't have). I'll try again later tonight.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Kind of interesting what people dislike and immediately "modify".
    My "cheap" modification, that I felt was almost a necessity was a wheelskins steering wheel cover. Absolutely could not stand the cheap plastic scratchy Toyota wheel.
    Not easy to install, not cheap for a steering wheel cover, but if you have the entry level steering wheel IMO almost a necessity.
    xliderider likes this.
  7. DadofHedgehog
    681
    281
    northern Virginia
