Was it OK to get just one new tire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by southjerseycraig, Apr 10, 2014.
  1. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    I went into Toyota today for my 10,000 mile service plus recall. The tech adviser told me there was a tear in the sidewall of my left front tire, and that I should deal with it right away before the tire started losing air. My normal custom is to buy two tires when there's a need to replace one, but the tech adviser and the servicer thought it was OK to buy only one. The front tires were replaced about a year ago (probably roughly 10,000 miles ago). Was it OK to buy just one, or should I have asked for both to be replaced? I wasn't inclined to argue because, in my experience, dealers are hardly shy about recommending a lot of work. But did I do the right thing, or should I go back and insist on buying a second tire?
  2. JC91006
    JC91006 Senior Member
    16,774
    8,570
    I think you'll be fine with that 1 tire. You should keep the new tire in the back, don't want the slightly thicker thread to interfere with your steering/balance.
    GrumpyCabbie likes this.
  3. Okinawa
    Okinawa Senior Member
    1,333
    320
    Since you had only 10,000 miles on the tire I would say just replacing the one tire is okay providing it is like the tires you have on your car. If it is a different tire with a different tread pattern my preference would be to replace the other for a match. I don't think there will be enough tread wear on the tire to make a difference in the driving or steering characteristics of the car.
  4. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    One will be fine........but I can't help but wonder how big the "tear" actually IS.
    You can scrape off a small patch of rubber, maybe the size and thickness of a nickel without really compromising the tires integrity any.
  5. ursle
    ursle Gas miser
    1,049
    192
    NH
    Well the tire was 1/2 used, now things are ajigle
    Did they put the new tire on the front or move it to the rear;)
    Worst case scenario, you replace all 4 with one of them 1/2 worn in a year or two.
    southjerseycraig likes this.
  6. southjerseycraig
    438
    107
    Cherry Hill, NJ
    I believe they put the new tire on the front.
  7. Seanzky
    Seanzky Member
    150
    28
    NY
    Are the tires in the Prius directional (I haven't checked)? If not, I would personally put mine front left, if it were me in your situation. Since our exit ramps here mostly force us to turn right, the left tire tends to wear out a little faster. If you put it there, with enough exits on the highways it might even catch up. Lol. :ROFLMAO:
  8. Sierra Mark
    Sierra Mark Junior Member
    30
    Mission Viejo, CA
    If the new tire is identical (same brand and model) you should be OK. I had to replace one Yokohama Avid when my rear suspension got harpooned by a metal bar on the freeway and the dealer had to replace a cracked rear axle. I have kept the new tire on the rear so the somewhat uneven tire size is not on the drive wheels.
  9. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I hit some debris on the freeway and sustained a blowout and rim damage to my front passenger side wheel a while back. I replaced 2 tires. At the time, I only had 5k miles on the tires.
    The replacement tires were different brand/tread pattern, and though they were the same size technically, I swear they looked like they were a slightly different diameter than the oem tires.
    SCH-I535
  10. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It'll be absolutely fine.
  11. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Since you have one new tire up front, you may notice the steering pulling to one side, especially when applying the accelerator or brakes. If so, that can be remedied by swapping the front/rear tires.
