Driver side door does not lock or unlock.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by robert c, Apr 8, 2014.
  1. robert c
    robert c Junior Member
    2024 Prius Prime
    All other doors lock and unlock except drivers door. The drivers door can only be locked unlocked manually with your hand. Any suggestions.
  2. xliderider
    xliderider Senior Member
    8,139
    3,274
    Honolulu, HI
    Take it to the dealer to fix under warranty. Could be the switch or actuator.
    SCH-I535
    ztanos likes this.
  3. robert c
    2024 Prius Prime
    Thanks my 2012 has 39000 but maybe the will fix it.:)
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    If they don't fix it. Remove the door panel and make sure that the locking mechanism is still connected. Based on my experience, either the wire came disconnected at the locking mechanism (most likely case) or your door lock solenoid went out (least likely case).
  5. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    You could, also, check the fuses. I'm not sure if the doors are single set on fuses (usually not), I haven't checked the manual on this, yet as I haven't had an issue.
  6. robert c
    2024 Prius Prime
    Took car to dealer, Not under warranty $600.00 to replace actuator. What a rip. Searching eBay now for replacement.
  7. robert c
    2024 Prius Prime
    Update replaced the small motor in the door lock actuator took about 1.5 hours to fix. Cost a whopping 5.50 on ebay I will post pictures later. By the way dealer wanted 600.00 to replace. Here is the picture of the door broke down and a picture of the little motor.
    SirCharlz, mannythewalls and ftl like this.
  8. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    Wow only $5.50 for the original part on ebay?
  9. Valencia Orange
    192
    Valencia, CA
    2013 Prius Plug-in
    Glad you fixed it yourself. What an unbelievable savings.
  10. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    Reason for non-warranty by Toyota?
    Mileage over 36,000?
    Certainly not because the vehicle is over 3 years old.
  11. robert c
    2024 Prius Prime
    From the way my dealer explained it to me if you do not buy the extended warranty your pretty much on your own after 36000 miles. Exception being internal motor (engine) problems or the charging system (Battery etc.). Most all the parts on this car are bolt on so pretty simple.
  12. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I had a drivers door that was not sensing my hand on the door handle ( PIP ) so used the manual control on the remote several times, that fixed it. Same thing on left rear window, would not actuate from drivers position. So I pressed the window button several times at the rear door. This fixed the control from the driver position. Wierd ?
  13. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I'm guessing that your door sensor was on the drivers door? If so, sounds like you have a loose connection somewhere in your door. It might have fixed itself enough that it works, for now. But it might be worth pulling the door panel off and seeing what's inside.
