No USB port, can you charge iPhone while playing through AUX?
Discussion in 'Gen 3 Prius Audio and Electronics' started by cycledrum, Apr 12, 2014.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Hello, don't have an iPhone yet, but considering a 4 S. Couple Q's -
    Does it drain phone battery a lot play iPhone 4 S through AUX on 40 minute commute?
    Any probs charging iPhone with 12V while playing through AUX port? I've heard rumors there can be noise in the audio.
    Maybe stupid Q: iPhone 4 S - is 8GB data decent amount to get a music collection started?
    ok, that's it THX :)
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    The iPhone was designed as a music player as one of its objectives. It will play music longer than it will allow you to use it as a phone. All day music listening versus 8 hours or so of talk time. So the answer is, yes. 40 minutes through AUX will hardly affect the battery.
    I've always heard interference when playing music and using the 12V on my other vehicles. I've had no need to do it in my Prius so I don't know the answer. I do know that the interference is minimal on my other cars that I could easily ignore.
    ~3GB is taken up by the OS. Is ~5GB enough for a music collection? I play music through the cloud so I don't need any space. Others say 64gb is limiting.
    cycledrum likes this.
  3. vskid3
    vskid3 Active Member
    773
    228
    The battery drain playing music that is on the phone is minimal as long as you have the screen off. If you're streaming with an app like Pandora, though, it'll drain quite a bit more. I would just keep a charger at work and charge there if you think it'll be an issue.
  4. Guill
    Guill Member
    165
    Italy
  5. dbastille
    dbastille Junior Member
    New England
    I would try this bluetooth adapter for the best solution...handsfree talk, music and siri integration.
    All automatic and no wires!
