AVG MPH Question
Discussion in 'Gen 3 Prius Fuel Economy' started by JC91006, Mar 21, 2014.
  1. JC91006
    JC91006 Senior Member
    16,685
    8,521
    Hello people,
    I have a question on my 2010, my Avg MPG reading is around 47mpg, however my aveg mph reading is only 18. It seems to float around this number, not going up or down much. This car is driven on streets often but how can I avg only 18mph for so long? Even if I drive 30 miles on the highway, it would still have a similar reading. Any clues?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Where are you reading aveg mph?
    If it is one of the Trip data try resetting.
  3. bisco
    51,249
    i am always surprised how low avg mph seems, but 18 is really low. i think it's time divided by miles, so includes time stopped at lites and etc.
  4. JC91006
    16,685
    8,521
  5. JC91006
    16,685
    8,521
    You have to ignore the fuzzy screen, I have one of those early 2010's that never got fixed under warranty. Thanks Bisco, I guess I spend a lot of time stopped at a light
  6. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    Not to worry - It's just the math. any time you stop your're dragging the mph way down.
  7. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    I'd have a headache if I had to look at that screen all the time (n)
  8. JC91006
    16,685
    8,521
    I don't drive this car much, but even if I do, I rarely look at that screen. The odometer is clear and not distorted.
    One day I'll take it apart and clean it.
    SM-N900P ?
    jdk2 likes this.
  9. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    I've noticed mine doesn't change by very much, up or down. Does it calculated trip to trip, when trip meters are zeroed, whenever the tank is refilled?
  10. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    It zeros when you reset that particular trip. It's just an average for the trip. Trip A and Trip B can be set independently.
  11. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    I figured that out when it comes to the avg mpg but does it do that also with the avg mph readout to the far bottom left?
  12. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    I don't have any mph display on the bottom left, only on the lower right of the trip display.
  13. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    Sorry. Meant lower right.
  14. RRxing
    RRxing Senior Member
    2,533
    1,807
    NEPA
    The Average MPH resets with a Trip A or Trip B reset. Low MPH (like mine) is just letting you know how crappy a commute you have. :D It is calculating miles/time, including when the car is not moving.
