Toyota Auris hybrid beat by diesel Auris
Discussion in 'Diesels' started by Troy Heagy, Mar 25, 2014.
  1. Troy Heagy
    Troy Heagy Member
    1,218
    Toyota Auris is available with about ten different engines in the European market: gasoline, diesel, or hybrid gas-electric. According to UK testing, the 1.4 liter diesel exceeds the hybrid option:
    83 MPG-UK highway; diesel Auris
    71 MPG-UK highway; hybrid Auris
    I want to see Toyota marry that Diesel plant to the hybrid synergy drive. We know it would get at least +12 mpg higher than the current gasoline hybrid. (I wouldn't be surprised to see 90 for the UK highway rating.)
  2. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Highway...
  3. Troy Heagy
    Troy Heagy Member
    1,218
    Many of us live on the highway (commuting from one suburb to another suburb). We care about extra urban MPG
  4. telmo744
    2,181
    769
    Portugal
    That's hardly true in Europe, many traffic lights and jams.
  5. Troy Heagy
    Troy Heagy Member
    1,218
    Which is a goid argument for why the Diesel Auris needs to have its automatic transmission replaced with the hybrid transmission: To turn off the engine when stopped, boost MPG in stop/go situations, et cetera.
    There really is no reason to oppose the idea of s diesel hybrid Toyota car
  6. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    So why is there no diesel hybrid? Does it not work?
  7. telmo744
    2,181
    769
    Portugal
    @ Troy Heagy - Yes, there is, cost and complexity! By the way, Diesel Auris does not have a automatic gearbox (it's optional)
    @ KennyGS - Diesel hybrid has MPG below expectations...
    KennyGS likes this.
  8. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    What is not true for you, may be true for someone else. :rolleyes:
    I have had two jobs of late (keeping them is another issue though grrr). One where it was 4 miles each way in 100% heavy traffic and another where there was a 25 mile each way commute with a clear 20 miles on highway (at a slow 50 mph).
    My Prius got good mpg's in both runs, but the diesel might be of use to someone doing the long run.
  9. frodoz737
    frodoz737 Top Wrench
    4,669
    2,490
    33
    The problem on PC is most are anti-diesel opinionated, whether it works or not.
    Trollbait and GrumpyCabbie like this.
  10. Trollbait
    12,466
    The main hurdle is cost. I remember a quote that the premium for Mercury Meta One diesel hybrid was $9000. Hybrids and diesel emissions have improved since 2005, but they both add to the cost over a comparable traditional gasoline car. So while a diesel Prius would seem ideal with great city economy and even better highway, chances are most won't opt to pay more for it and just get the gas version.
    META ONE concept bristles with new technology
    Diesels might have a place in PHVs though. Their added cost and weight becomes a lower percentage of the vehicle's total. Volvo's V60 PHV diesel has proven popular.
    KennyGS likes this.
  11. KennyGS
    1,243
    1,044
    Keystone State
    Yet, I see enough people are willing to pay the higher price of a Tesla.
  12. Trollbait
    12,466
    People that would have to think about the extra $2000 for a diesel in a Prius only dream about the Tesla S, and paying for the S means ditching the fossil fuel hose. Paying more to just use a different but from the same source fossil fuel just isn't as appealing.
    fuzzy1 likes this.
  13. Troy Heagy
    Troy Heagy Member
    1,218
    If a diesel hybrid Prius (or Prius C) was released I'd buy one immediately, even if the C ended-up costing 21,000 instead of 19,000.
    65-70 mpg highway would be very appealing (but the standard 47 don't impress me much...
  14. Troy Heagy
    Troy Heagy Member
    1,218
    Is it routine for moderators to edit & erase the last sentence in other people's posts? (It appears so
  15. Alesf76
    Alesf76 Member
    89
    33
    Italy
    I think the main reason we will never see a diesel Prius is that it would be bought mainly in the EU, where hybrids have still a small market, a small % of a small market means very low numbers, too low to justify the R&D for that.
    Btw outside UK in EU you can add a CNG system to an HSD hybrid, adding less than 2000 € you obtain a car than can go at highway speeds for near 3 €/100km.
  16. KennyGS
    1,243
    1,044
    Keystone State
    I have no idea what that would compare to normally.
    My gas costs $3.60/gallon, which is about .67 €/liter.
    If my mileage is 50 mpg, then I can travel 100 km for about 3.16 € in the U.S. I believe gas costs about 2.5 x more in Italy.
    So are you saying the car would achieve about 125 mpg?
  17. Trollbait
    12,466
    No, he is saying that CNG is that much cheaper than gasoline. Regular is $3.65 around me at this time. CNG is $2 to $2.30 per GGE in the same area. Depending on the locale, that may or may not include a road tax.
    The Civic CNG got around the same fuel economy has the gasoline version. The difference in fuel costs means it is cheaper t0 fuel per 25 miles though. A theoretical CNG hybrid one would cost $1.23 for 25 miles to the hybrid's $2.05.
    Compare Side-by-Side
    KennyGS likes this.
  18. KennyGS
    1,243
    1,044
    Keystone State
    Thank you for explaining that.
    I wonder how the total capacity of CNG compares to gasoline. Will fill ups be less/more frequent?
  19. Alesf76
    Alesf76 Member
    89
    33
    Italy
    Right the trick is just very very low taxation for CNG and high taxation for gasoline and diesel. At 50 mpg is between approx. 7-9 €/100 km in EU, CNG hybrids are not very common but there are some.
  20. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    Toyota should build a car similar to chevy Volt, where the car runs on elec, and has a ICE to charge the batt. this could be diesel or gas. I think toyota could have good sucess with this, and a diesel engine seems logical for a generator. the mpg should be great.
