2010 Nav and ETA
Discussion in 'Gen 3 Prius Audio and Electronics' started by jdcollins5, Mar 2, 2014.
  1. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    There have been many threads on here ranting about the Nav in general and the inaccuracy of the ETA in particular.
    I agree that the Nav is no match for a Garmin and the manual is difficult to read and understand, but I find it very functional once time is taken to adjust the settings to match your driving style.
    I set a trip this weekend to my granddaughter's birthday party. The route calculation was 244 miles and ETA 3 hours 30 minutes. The first half of the trip is 75 mph and the second half is 70 mph. I arrived in 3 hours and 34 minutes after about a 5 minute restroom stop. Close enough for me :)
    I had a two segment drive coming back and both segments were just as accurate.
    So, if set up correctly it can perform satisfactorily.
  2. Roland1555
    Roland1555 Senior Member
    282
    69
    Vancouver BC
    I too find that the 2010 navigation system works very well and I have no problems with ETA as I make sure that the system is set up with correct parameters. That is not to say that anybody with issues have not done the same, perhaps the map data for different regions has something to do with it, but my experience up and down the west coast and southwestern states has been excellent.
    Roland
    jdcollins5 likes this.
  3. bathala
    bathala Member
    128
    30
    Area 52
    This is the first time I purchased a car with NAV and I also have good experiences with it. It may not be the best NAV out there but it gets the job done.
    I also own a portable navigation. Although it also took me where I wanted to go, when it's not in use, I had to stow it away to prevent break-in. Secondly, I seldom need direction and my portable device typically requires recharging before I can use it because it couldn't power by itself. That means "no guidance" until it's recharged.
    Only grumble I have with the Prius NAV is the cost of updating the map - when it becomes a necessity to do so.
  4. jdcollins5
    5,131
    1,346
    Wilmington, NC
    The fact that the Nav is built-in is another nice feature. No external devices to have to hide away to prevent break-ins and theft.
    I agree that the cost of the map updates is much higher than it needs to be. I have found that I only have the need to update the map about every 3 years. My car came with 2008 and there were enough new streets and highways by 2011 to warrant an upgrade. I suspect that there may be enough changes to entice me change again when the 2014 versions come out in the fall.
  5. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    Driving Speeds that I use are 25/45/70. That puts me pretty close to Google maps ETA.
    Cost of updates? Agreed. Torrent saves.
    SCH-I545 ?
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    I use driving speeds of 25/55/75. I will adjust the 75 to 70 at times depending on the trip and the highway speeds.
  7. Hybrid Dave
    Hybrid Dave Member
    184
    73
    St Augustine, FL
    For anyone unhappy with the cost to update the maps on the 2010 navigation dvds, I bought the 13.1 update on eBay for $14.95. Works great. Definitely better than the $199 that Toyota charges for it.
  8. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    I used torrent, it was no cost (except dual layer DVD+R)
    bigrin likes this.
  9. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    2012 IV with HDD radio with Nav. Can you get the update and install on a USB stick and update the maps?
    Thanks!
  10. MP_terp
    MP_terp Junior Member
    Knoxville, TN
    Did you buy from "incrediblebooks" ? I use eBay a lot, but would likely avoid a purchase without an item-specific photo. But, if you've already done it & had a successful result, I would do it. Thanks for sharing!
  11. Hybrid Dave
    Hybrid Dave Member
    184
    73
    St Augustine, FL
    Yeah, that is the seller I used. It works perfectly and the disc shipped really quickly, I had it on my hands in 4 days.
  12. MP_terp
    Knoxville, TN
    Thanks for sharing! That's going to help lots of us! :)
    SCH-I545 ?
  13. bathala
    bathala Member
    128
    30
    Area 52
    My baby doesn't support DVD. If there's a USB version I may consider updating my map. I had situations where my NAV is showing I'm driving off-road. :(
  14. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Yes your unit is updated by USB.
