Trans Fluid Change: New Washers for Drain and Fill Plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bauerhillboy, Apr 16, 2014.
  1. bauerhillboy
    bauerhillboy Junior Member
    22
    Since I got my 2010 Prius and changed the transaxle fluid ( as per the experts here), I have had a number of friends buy Prius's of their own. I always have to order the crush washers because no dealers stock them since Toyota makes no recommendation to change the fluid. I run into the same stupid issue each time: The parts guy is not knowledgeable about what to order, he pulls up the exploded view on his computer, and he sees a million unidentifiable parts with little numbers that are hard to read. Then he faxes the drawing to me, and I can't figure out for the life of me what I'm looking at even though I've done this a few times now!
    So...(thank you for letting me vent)...can anybody tell me a part # for these washers so I can call this guy back and order them? Thank you : ) John.
  2. jjPrius
    jjPrius Junior Member
    68
    22
    Southern California
    The part number is 90430-A0003.
    Jeff
  3. bauerhillboy
    22
    Thanks Jeff!
  4. jjPrius
    68
    22
    Southern California
    You're welcome John.
  5. Mendel Leisk
    41,786
    I've changed the fluid a couple of times, had no problems with parts department: they had the fluid, and the washers.
    I didn't need to tell them the washer part number, just description. FWIW, here's the part number on my bill:
    90430-18008
    (maybe different in Canada?)
  6. jjPrius
    68
    22
    Southern California
    I believe the 90430-18008 was superceded by 90430-A0003. I bet they are the same, but the number changed for some reason.
    Fostel, The Critic and Mendel Leisk like this.
  7. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    If it looks like brass or copper or maybe even aluminum, then it probably isn't really a "crush" washer but just a soft washer and if that's the case and it looks to be in good condition, there probably is no real need for a new one.
    About the only place that a true "crush" washer is used any more is on spark plugs.
    Mike500 likes this.
  8. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I bought new ones before I did my fluid change. The washers that came on my car and the ones the I bought don't crush or have any sign of damage or use. I'm very confused on why people say to replace them. Also I always pull the fill plug and check fluid level every oil change.
  9. adamace1
    1,403
    193
    Charlotte, NC
  10. Mendel Leisk
    41,786
    I like to replace drain (and fill) bolt washers, mainly 'cause the instructions say to, and it's cheap insurance. Though it should be cheaper...
    That said, you'd get away with, it's not going to fail. My main problem: maybe next time I won't replace it, and the time after that, and...
    So I replace them every time.
    In the repair manual, transaxle fluid change instruction it says:
    and:
    frodoz737 and jjPrius like this.
  11. adamace1
    1,403
    193
    Charlotte, NC
    Yea I bet Toyota would like people to replace them, it would work out to millions more in profit. Still wondering why a hard metal washer needs to be replaced.
  12. gliderman
    gliderman Active Member
    751
    225
    When I changed my transaxle fluid for the first time, the washers did have some displaced metal as visible rings. I would not want to use them again. Replacing them is cheap insurance. I will replace my transaxle fluid again with my next oil change. I already have the washers and fluid.
  13. Mendel Leisk
    41,786
    They're soft aluminum, you're doing this every 30K miles or so, splurge, lol.
  14. adamace1
    1,403
    193
    Charlotte, NC
    What about when I change my oil, I always check my transaxel fluid? New washer? I really wish they put a dip stick in it instead of charging me a dollar or two every time I want to check the fluid on "MY" car.
    Fostel likes this.
  15. Mendel Leisk
    41,786
    The first time I changed our transaxle fluid (have done 2 changes), I checked the level a day later, just to see if there'd be any drop due to driving. The level hadn't changed, it was still right at the lip. I didn't change the washer at this second inspection.
    I resolved then to not to bother with any more periodic level checks. It just seems to me like Toyota butt-covering, to have this in the schedule so frequently.
    Every time I change the engine oil I just look the transaxle case over, look for signs of fluid accumulation on the underside. Haven't seen anything.
    My 2 cents, if you're not seeing signs of leakage, it's fine, no point in opening up the fill bolt.
  16. El Dobro
    El Dobro A Member
    7,088
    3,270
    For the couple of bucks, I change them.
  17. Mike500
    Mike500 Senior Member
    2,593
    767
    Since the washers deform to match the surface of both the surface under the plug and the transmission drain hole, a wise solution might be to make sure that each unit is returned to the same hole.
  18. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    The Wiseman's Slogan: "...Better SAFE, than SORRY..."
