How to replace engine coolant pump and thermostat
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Patrick Wong, Oct 10, 2013.
  1. Chris Dragon
    Chris Dragon Junior Member
    22
    Thanks Patrick. Based on this post, I've decided to replace the thermostat, but based on this post I'm going to leave the old idler pulley. It should be obvious if it starts to fail and very easy to replace without draining coolant or removing anything else.
  2. Chris Dragon
    22
    I've now replaced the coolant and the coolant pump (and the belt and thermostat) and I can tell you that even with all the coolant drained from the drain cocks and the car on a level surface, coolant still remains in the coolant pump and thermostat. Both gushed coolant when I removed them (and both almost spattered into my eye even though I tried to be extra careful after it happened the first time, so I encourage people to wear wrap-around safety goggles) so I don't think we can know if the tech in that video drained the coolant or not before replacing that pump. I would think that if he hadn't drained coolant, it would have kept gushing coolant a lot longer since the radiator is so much higher than the pump.
    Using the Lisle funnel, I could not get the air out of the system without running the CHS pump by shorting the relay as Patrick described in post #44 of this thread, so I don't know how it could have worked for the tech. Even the Toyota repair manual says you need to run that CHS pump to bleed the system. On the other hand, I had followed a guide that incorrectly instructed to disconnect the CHS temperature sensor and I forgot to reconnect it, so that may have prevented the car from doing its normal running of the CHS pump and maybe that's why it wouldn't break the air lock. As soon as I ran the CHS for a single second as a test, a ton of air suddenly started bubbling out of the Lisle funnel. I then ran CHS for 30 seconds at a time and it pulled about a quart of coolant in over the next 5 or 10 minutes.
    Another thing that video fails to show is connecting a 1/4" ID tube from the radiator bleed outlet back to the radiator expansion tank. I ended up dribbling a ton of coolant from the bleed valve because of that omission.
    BTW, if you get a check engine light after doing the fluid change and you use an OBD2 reader to see a P1118 error code, you likely forgot to reconnect the CHS temperature sensor plug like I did. Although, again, you're not supposed to disconnect that sensor in the first place, you're supposed to stop the pump from running by disconnecting the CHS pump power plug higher up on the CHS canister, or disconnect the 12V battery from the trunk.
  3. Mylar
    Mylar Member
    163
    37
    Cincinnati, OH
    2019 Prius
    I decided to replace the ICE water pump on my 2006 Prius with 132500 miles yesterday. Once installed and test run, I noticed the new pump is leaking around the new gasket. Any thoughts / ideas on how to fix? Should I remove the pump, add a small amount of sealant to both sides of the gasket to stop it from leaking? Any advice would be helpful!
    Thanks,
    Mylar
  4. Patrick Wong
    18,210
    6,511
    Hi Mylar,
    Tell us about the new pump and gasket that you installed: are these Toyota-branded parts, or aftermarket? If aftermarket, who is the manufacturer?
    Also tell us what the pump mounting surface on the engine looked like: was it nice and shiny or was there any corrosion present?
    Regarding the leak, first make sure that the hardware is properly torqued. If you still have a leak then you will need to use sealant. Toyota has a black FIPG sealant which I had bought several years ago for use in sealing a small area of the engine valve cover (I removed the cover on my 2001, to look at the valve train for fun.)
    Mylar likes this.
  5. Mylar
    Mylar Member
    163
    37
    Cincinnati, OH
    2019 Prius
    Thanks for the reply Patrick! I had installed a new Toyota OEM water pump and gasket. I had a service appointment at my local Toyota dealership to complete 3 recalls as well as check out the AC system. I just decided to let them take care of the leaking ICE water pump as well. They installed a new gasket and put the black rtv around the screw heads, something I did not do. It's no longer leaking but it did set me back an additional $206.44. I most likely could have done the job myself, but I have done significant work to my car over the past two weeks and at this point was ready to take a break.
    Patrick Wong likes this.
  6. Patrick Wong
    18,210
    6,511
    Interesting. So, apparently the path of the coolant leak was via a bolt?
  7. JC91006
    JC91006 Senior Member
    16,800
    8,589
    Was the bolt torque properly in the initial installation? First I've heard of this.
  8. Mylar
    Mylar Member
    163
    37
    Cincinnati, OH
    2019 Prius
    Not sure. After spending all day working on the car and then to have an issue, I was more than happy to pay the $200 to correct the issue. Below is a picture of the old water pump which was removed at 132k miles.
  9. Patrick Wong
    18,210
    6,511
    My daughter is now driving the 2007 and at a recent dealership oil change (Rancho Santa Margarita Toyota, south OC, CA), she was informed that the engine coolant pump was leaking and that it would cost $600 to replace it. I asked her for photos to confirm this problem and was satisfied it was real. So I told her I would change the coolant pump myself. I bought the correct pump for $57 and the serpentine drive belt for $14 plus shipping via weborder at Autonation Toyota Gulf Freeway (Houston, TX).
    She's visiting now and drove the car to Tucson, so I changed the pump this morning, with the odometer showing 73K miles. Attached is a photo showing coolant seepage at both weep holes, similar to Mylar's photo in post #28. There was sufficient leakage so that a light spray was deposited on the underhood sound insulator pad and a pink line was painted on the air conditioner compressor as well as other deposits here and there on the compressor housing. Of course the inside of the coolant pump pulley was coated in dried antifreeze deposits.
    I provided a photo of the original serpentine drive belt which shows lots of cracking which is to be expected at this odometer reading and age. The outside surface of the belt was starting to glaze.
    Note that when the new serpentine belt is installed, that provides excellent holding force on the coolant pump pulley which makes it very easy to tighten the pulley bolts. When removing the bolts, the old belt will likely slip due to surface glazing, so I use a long screwdriver inserted through one of the pulley holes, to more-or-less lock the pulley in place. You can also get a special tool to hold the pulley in place but there isn't much room to hold that tool and also work on the pulley bolts with a box wrench or a socket wrench.
    It is really helpful to be left-handed when removing the pulley bolts and the pump mounting bolts/nuts.
    I had removed the engine undercover because I had expected to open the radiator drain valve. However it turns out that valve is extremely hard to reach. I recall that the 2004 valve is easy to get to, so I don't know if the 2007 radiator was redesigned or if something was moved into the way. I ended up just pulling the coolant pump without draining the coolant, so I got a nice gush of coolant, some of which was caught in a drain pan while the rest coated the garage floor. I hosed off the latter with water.
    I was able to install the serpentine drive belt from above, so in retrospect there was no need to remove the engine undercover plastic panels. I could reach on both sides of the crankshaft pulley to satisfy myself the new serpentine belt was properly seated.
    Some posters have complained of difficulty in loosening the idler pulley 14 mm locknut, so I provided a photo to show what I use: a 14 mm 6-point socket, a 3/8" cheater bar, and a piece of steel pipe to extend the length of the cheater bar. This is very simple, and has worked really well on all three Prius that I have owned.
    Other posters have reported that thread sealant was used on the locknut. I noticed some red paint on the end of the nut, but I believe that paint was used to show the nut was torqued down. The reason for my belief is that there was no red substance on the threads.
    #29 Patrick Wong, Sep 28, 2014
    koolingit likes this.
  10. balmeral
    balmeral Junior Member
    Iowa
    I am about to attempt replacing a gen 2 Prius water pump. I do not have too much experience working on cars but I have read as much as I can about this water pump replacement process. The one thing I need advice on is reapplying tension to the new belt after replacement. I do not have a belt tension gauge and I have read this is an important step. How can I perform this step without a tension gauge? Thanks!
  11. Patrick Wong
    18,210
    6,511
    Press on the belt at the center of the longest length, exerting 22 lb force using a finger. The new belt should deflect 0.4".
  12. balmeral
    Iowa
    Do you have a common reference so I could have an idea about how hard to press? I have no idea what 22lbs of force would feel like if I was pressing on something. Thanks for the response!
  13. bisco
    52,187
    maybe you could press on a bathroom scale to get the 'feel'.
  14. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    I didn't move the tensioner pulley when I did my '04 pump; I took the pump pulley off first and just stretched the new belt enough to hand start the pump pulley bolts and then weaseled the pulley into place and carefully tightened the pulley bolts. of course you got to be very careful cause you don't want to cross thread your new water pump. tension of the new belt seemed fine.
  15. balmeral
    Iowa
    Thanks for the response! I haven't gotten to the repair yet but I do think I will take off the pump pulley. I guess I will bring out a 25lb weight to help me guess for tension. Another question I had was with holding the water pump pulley in place when I need to remove it. Can anyone describe the best method for doing this? I read on this forum that the best way to do it was to use a wooden dowel or something similar to keep the pulley from turning. I couldn't tell whether they were wedging the dowel between a belt and pulley, or inserting the dowel betwee a spoke on the pulley and then wedging it against a solid non moving part? Thanks!
  16. Patrick Wong
    18,210
    6,511
    First, try to loosen the pulley bolts before you do anything else. If you are lucky, the serpentine belt will exert enough friction to hold the pulley in place.
    If the belt surface is glazed due to time in service, then the pulley will slip. The repair manual suggests using a special tool which can be inserted into two of the pulley holes to hold it stationary.
    I inserted a long flat-blade screwdriver through the pulley, as shown in a photo at the beginning of this thread. As the pulley tries to rotate, the screwdriver blade will move up and be held against the engine compartment wall next to the pulley. You only have to overcome the tightening torque of the pulley bolts, which is supposed to be 11 ft.-lb.
    #36 Patrick Wong, Nov 3, 2014
  17. Shazane
    Shazane Junior Member
    Patrick Wong I have a question for you: My water pump was replaced not to long ago. However, I just replaced the 3-way valve for the cooling system and I believe the P1116 code is telling me to replace the thermostat. Can you confirm that the thermostat is on the passenger side of the vehicle, down next to the water pump???? After replacing the 3-way valve (Heater bypass valve), I attempted to put new coolant back in, I needed 1 1/2 gals. I could only get 1gal to go back in. I have read the forums and watched the youtube videos, showing how to turn the water pump on using a multimeter or a wire on the pump relay. Non of those methods worked for me. I tried everyway possible to get the air to bleed out. It just isn't happening. If I run the car, turn it off and let it sit overnight, water still wants to come out of the radiator cap, when I try to take it off. At this point, no more fluid is going in, yet it is 1/2 gal short of what I took out. I went and talked to a Prius tech at the dealership. He said that this is no way to get the air out, that is stuck behind that new valve that I replaced, without being hooked up to the dealship's laptop. This guy seemed like he would tell me if there was another way. All I know, is that I have tried everything that has been mentioned in these forums and I have not had any success. So, before I go pay for an hour labor at the dealership to remove the remaining air, I want to change the thermostat. I would like confirmation on it's location, if you would help me. Thanks, Shane
  18. Chris Dragon
    22
    100K maint - 5 shows where the thermostat is located in the second to last picture on the page. He's holding a rectangular mirror in front of a pipe and you can see the thermostat in the mirror. The thermostat is a mechanical device and the coil you see in the reflection is a spring that holds the valve shut. When the fluid around it heats enough it causes it to open. Since the car can't directly talk to the thermostat, it seems unlikely that the car would have any way of knowing if the thermostat needed to be replaced except maybe if it notices the coolant temp hits 176F and doesn't slow down increasing in temperature above that point. The car does have an electronic thermostat somewhere and I've watched the temperature hit 176 quickly and then slowly increase because the mechanical thermostat let coolant start to flow. If you have the Torque app you could perform that same experiment but maybe not if you think coolant isn't reaching part of the system.
    When I did my coolant change I used a Lisle funnel and followed the steps shown in this video:
    Here's a bunch of notes I took regarding the video and the process:
    • Attach Lisle funnel and always keep it filled about halfway.
    • Despite having no real seal between the funnel and the radiator throat attachment, the funnel only leaked a couple drops throughout the process.
    • Hook a ¼” ID hose up between the bleeder and the radiator expansion tank. You can see the silver tube where the hose can be hooked on above the bleeder if you lean back and look through the hole that allows access to the bleeder.
    • Open the bleeder and pour coolant into the Lisle funnel until it won’t take anymore.
    • The official instructions say to add coolant to the radiator cap (where the funnel is) and squeeze inlet and outlet hoses a few times to work out air. I did see some air come out when I did that.
    • Close the bleeder.
    • With your foot off the brake pedal, press the start button twice then press and release the gas pedal twice.
    • Press the brake, shift into neutral, release the brake.
    • Press the gas twice.
    • Press park button (another guide said hold brake before pressing park but I don’t think I did) and press the gas two more times.
    • You should get a “Problem” message on the MFD. I didn’t actually see it say “Problem” like in his picture, but it did show a triangle with an exclamation.
    • Hold the brake and press the start button to “ready on”.
    • It should go into inspection mode where the motor runs continuously and I think it keeps flashing the triangle exclamation.
    • When in Inspection Mode, engine speed depends on accelerator pedal position:
    • Accelerator pedal not depressed: idle (approx. 1000 rpm)
    • Accelerator pedal depressed <60%: approx. 1500 rpm
    • Accelerator pedal depressed >60%: approx. 2250 rpm
    • Patrick Wong used the above inspection mode but also set heater to MAX HEAT “so that coolant would flow into the heater core”, whatever that means. May as well do it.
    • It’s important to run the CHS pump by shorting the relay. Short the relay when the car is off and the pump will run immediately as soon as you touch the terminals. I didn’t expect it to run immediately so I flinched away after the pump ran about a second and yet air and a plume of coolant immediately came out of the lisle funnel leaving faint spatters. It kept going for a couple minutes, draining at least half the funnel into the car. I added a larger black funnel pointing down into the Lisle to prevent the plumes from spattering everything.
    • After running the pump for 20 seconds, waiting, and running 10 more seconds, the tone of the pump changed significantly from high fast to slower and lower pitched. A couple mins later bubbles stopped coming out and the pump sounded possibly even lower pitched when I ran it again, spurring a few more bubbles.
    • I ran the car on max hot for a couple minutes. I meant to put back the relay but forgot, so I guess it didn’t matter. Coolant in funnel hadn’t changed noticeably. Turned off car and ran CHS pump for 30 seconds but no more bubbles appeared.
    • Ran car again for a few mins, ran CHS, no bubbles. I noticed that the first time I’d run CHS, the coolant kept pulsing up and down in the center of the black funnel. But the last two times I ran it, fluid remained perfectly still. So I’m going to call it done. I did open bleeder valve periodically and never saw anything happen.
    • Open the bleeder periodically until only coolant ever comes out.
    • Coolant came out of the bleeder before I put a hose on it but after I put a hose, nothing ever came out. Wth?
    • VIdeo says "Top off the coolant reservoir" (I think he means fill the expansion tank to full) and you’re done.
    • Close bleeder to 13 IN-lb. I don’t have anything I can easily measure that with so I just push my thumb pretty hard on the short end of the allen wrench since 13 inlb is pretty meager.
  19. Patrick Wong
    18,210
    6,511
    1. My post #1 at the beginning of this thread contains multiple photos. The last photo shows the hole where the coolant pump would be installed, which faces the passenger fender. That photo also shows the hole where the thermostat is installed, which faces the radiator. A radiator hose is attached to the thermostat housing.
    2. If you can find the CHS relay which is located in the small relay box mounted above the engine, you should be able to manually run the coolant heat recovery system pump following the instructions which I had posted on PC. An alternative is for you to purchase Mini VCI which is a clone of Toyota Techstream.
    3. It will be much more useful for you to figure out how to power the CHRS pump, than it would be to replace the engine thermostat which is not likely to help the P1116 fault code. If you truly cannot figure out #2, then you should seek professional assistance.
  20. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    P1116 is the coolant temp sensor out of range. That may be because it's in air, not water, if your engine is not bled correctly. It's probably not the water pump. Wait until you get the system bled, see what happens.
    You really have to figure out a way to run the CHRS pump. (Is it plugged in? I think the instructions I followed for the valve replacement had me unplug it.) If you can't get the hack to work, buy a Mini VCI. I got that and an old computer for about $50. I wouldn't drive it until you get that 1/2 gallon in, and get the P1116 to turn off.
