Battery use at or near hwy speeds question
Discussion in 'Gen 3 Prius Main Forum' started by Former Member 68813, Apr 25, 2014.
  1. Former Member 68813
    3,524
    983
    US
    I drive my prius mostly in city/suburbs with limited hwy time. I drive in a way to minimalize battery use. Ie no EV, top ECO zone ICE accelerations, coasting with no battery use, etc.
    I recently noticed that battery fan kicked to moderately loud (a rare event in my driving) after several miles of hwy driving and later near 50 mph acceleration after exiting hwy. Flat terrain.
    I also remember some old post on gen 2 that someone lost a HV battery after a near 100 MPH driving stunt.
    Question: why battery use at those high speeds? I always thought ICE only was used at those speeds?
  2. vskid3
    vskid3 Active Member
    773
    228
    What was the outside temperature? The fan is programmed to speed up as the car goes faster, since the noise from the car will cover the noise from the fan (usually). The battery is used a little at higher speeds, but only hills really work it.
    I doubt going 100MPH killed the HV battery. I may or may not have taken my Prius to 90MPH a few times and its fine.
  3. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Why do you minimize battery use?
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Minimizing conversion losses is a good plan. How sure are you that your Prius is not charging the battery?
  5. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    Your driving style ensures that the HV battery will be near optimum charge (60%). At this level the car is programmed to make full use of the battery to minimise fuel consumption. You can't win!
    GT-I9300 ?
  6. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    What you are really going for is to minimize the total energy use and that includes the battery.
    Mostly because the bulk of the energy stored in the battery comes from the gas engine too.
    I consider this to be a "hyper-milling" technique but some of the components are pretty easy habits to cultivate with just a little practice.
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The battery is used at highway speeds to help maintain speed. If the car didn't use the battery it would have to use the engine, requiring fuel enrichment as it opened the throttle. This is a major inefficiency of gasoline powered engines.
    I'm talking here of almost imperceptible uphill spots as you drive along. If you watch the schematic display showing the flow of energy you can see this at work. Best seen when using cruise control.
    This use of the battery is not problematic. Taking the battery to full charge or low charge levels is what will damage it. That's why the Prius operates the battery between the 30% to 80% charge level. But you -can- shorten the batteries life by deliberately taking the charge level to high levels or down to low levels. I doubt you could actually -measure- the shortened life however. As I'm sure you have seen, the systems won't let you get into "dangerous" areas for the battery.
  8. Mendel Leisk
    41,901
    The increased fan noise doesn't sound good. Have you ever checked if it's clean? Apart from the fan noise increase, is the battery behaving normally, ie: charging/discharging readily?
  9. Former Member 68813
    3,524
    983
    US
    In the story I mentioned, battery was weak already. It went kaput after the fast drive. It could be incidental I guess.
  10. Former Member 68813
    3,524
    983
    US
    Yes, I noticed that in city driving, if the HV battery is full (due to regen braking), the ECU will make an effort to burn that extra charge in the next acceleration. I didn't realize that applied at hwy speeds.
  11. Former Member 68813
    3,524
    983
    US
    Because that gives me max MPG (so I know) and min wear and tear (so I think).
  12. Former Member 68813
    3,524
    983
    US
    I got in habit using HSI display only and I don't look at the flow of energy. I find that distracting. I need to dust my Torque app and do some current measurements.
  13. Former Member 68813
    3,524
    983
    US
    I plan to check it at 40-50,000 mile mark. I'm not there yet. I suspect it's squeaky clean as no pets are rarely passengers in the rear. Battery is fine and overheated only once when my wife drove it like a maniac (40MPG!) and parked it in the sun.
  14. Roger T
    Roger T Member
    198
    48
    MA
    I used to be at the opposite of you. I tried to use battery as much as possible and hope to recover the electricity from mandatory acceleration/higher speed battery charging/generative braking. I stopped this practice since i was aware of the problem of traction battery wear.
    Use the battery as much as possible actually gave me quite high MPG. I once got 60 mpg on a 15 miles trip that consists of half highway and half local.
  15. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    I personally do not see the point of saving the battery, the whole idea of hybrid's is the efficient use of all excess energy. This is done by both regenerative braking and storing excess energy from the engine in certain circumstances when the engine has to run faster. Then the energy is put to use as needed to boos performance like climbing a hill, ect...
    All you have to do is watch the energy flow display to get a good idea of how this actually works. Plus if you do some research you will find that Prius battery failure rate is extremely low. I believe I read somewhere that for all Prius-es ever built it is around 0.3 of 1%. Use the battery, is my take, as the is what it is there for in the first place.
  16. Easy Rider
    982
    210
    N. Central Florida
    So here we have the same "old" problem being quoted again.
    On short trips, the displayed MPG figure more closely resembles an "instantaneous" number than a true average. Under many conditions that use a lot of battery, the system seems to "estimate" that those conditions will continue to exist......seemingly forever. And if the car doesn't estimate that, then the driver DOES. :)
    I routinely see numbers in the low 60's in my C with mixed driving on trips of 20 miles or less.
    But then when it's time to fill the tank and get the "real" mileage, it usually ends up in the low 50's.
    And the actual is always 3-4 MPG lower than the computer says on the trip ODO.
  17. Easy Rider
    982
    210
    N. Central Florida
    That is absolutely correct.......for most owners who are not obsessed with squeezing out the last drop of mileage. :rolleyes:
    I think you are missing the main point, however.
    It is not really "saving" the battery by not using it; that is just a side effect of using as little TOTAL energy as possible, since most of the battery energy really comes from burning gas too.
  18. Roger T
    Roger T Member
    198
    48
    MA
    Great point.
    In fact, even if I use the battery as much as possible, I have never seen one occasion that the battery indicator goes down to less than 2 bars and then the ICE fires up to charge it.
    It is possibly because I don't really stay on the all EV range all the time... I don't drive in local speed too often. From acceleration to catch up traffic to other scenarios, the battery mostly keeps at 3 to 5 bars...
    I don't practice this way any more tho.
  19. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    When you get down to 2 bars of battery then the display turns purple. Shortly after hitting the 2 bar level the ICE will turn on to charge the battery and will not turn off until the SOC is above a certain minimum threshold.
