display shows MPG decrease while braking
Discussion in 'Gen 2 Prius Main Forum' started by theclarinetguy32, Apr 26, 2014.
  1. theclarinetguy32
    114
    Fox Valley, WI
    I saw a really weird thing happen about half an hour ago. Hadn't driven that car today until I made a quick trip a bit ago to pick something up.
    As I was coming back from the store I noticed the display was showing extremely low numbers with barely any speed/coasting. After I got up to ~30mph and started slowing down, I noticed the display was actually showing the mpg decrease as I applied the brake.
    Don't have a lot more info at the moment since I needed to get back to a project and couldn't drive around, but has anyone seen this type of behavior?
    51,843
    even tho you were braking, i suppose the ice could have been warming up or recharging the battery.
  3. theclarinetguy32
    114
    Fox Valley, WI
    hmm, possibly. The outside temp was showing 43.
    the thing that strikes me as odd was with just a little acceleration the mpg's were in the low teens at a max. I would expect to see this when flooring it trying to get up an onramp, but not in a parking lot with the battery at full/green.
  4. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    battery at full green? really?
  5. bisco
    51,843
    how long had the ice been running from cold, mpg's are pretty low in the warm up cycle. why was your battery full, had you just come down a large hill and how many miles on her?
  6. theclarinetguy32
    114
    Fox Valley, WI
    yep. Oddest thing right? I have to run some some errands tomorrow afternoon and I'll see what I can do for watching as much detail as possible.
    When I parked it on Friday I had just come back from a highway trip, so the battery would have been decently topped off. And since I hadn't driven it at all until this one quick trip to the store, I figure the little bit of braking would have topped it off again.
    ~80 k, something in that range. Can't remember the exact reading.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Even with a full battery, if the ICE is warming up, your MPG will be low. Nothing to worry about.
  8. theclarinetguy32
    114
    Fox Valley, WI
    alright, I can understand that for driving during the warmup period, but would that possibly relate to the MPG dropping when braking (lightly as in rolling into a stop sign/light)? I was watching the display and it went from 99 to ~95 after applying the brake, ~90, ~86, ~79.
    I just don't recall there being a drop when letting the regen function do it's thing.
  9. fuzzy1
    10,409
    In normal regen after warmup, the ICE will shut off and the display should show 99+ mpg. But during warmup, the ICE should be burning fuel at a nearly constant rate. That warm-up fuel is counted in the calculation, so as you slow down, so does the computed mpg.
    uart likes this.
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    OK, so 99 .. 79 means we're not exactly talking low MPGs here right. This is very simply the engine idling. Could be due to being cold and/or cabin heat requirements, or could simply be "stage 3a" (See link).
    In any case the drop in MPG when slowing is precisely what you would expect for an engine that is idling. Think about it, fuel consumption of an idling engine is constant (independent of speed), so the slower you go then the more fuel is consumed to travel any given distance. With L/100km (metric) fuel consumption units I see this literally every day.
    Link: http://www.techno-fandom.org/~hobbit/cars/five-stages.txt
    Edit: fuzzy beat me to the punch. What he said. :)
  11. theclarinetguy32
    114
    Fox Valley, WI
    All good info!
    But.... what if the variable of the ICE not running during the braking session I mentioned? I do recall the screen showing only wheels to battery, nothing for ICE.
    Would ICE warmup running not register on the display if the initial driving stage only needed battery power?
  12. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    During the warm up period, the car tries not to use the engine for power, so there are no arrows from the engine on the MFD even though it is turning over and burning fuel. I see the behavior you are describing every trip I make. The initial phase begins with a long downhill section, all braking, engine warming up, and some variable MPG on the display depending on how fast I am going.
  13. bisco
    51,843
    it could be the sign of a bad cell or two in the battery mains.
  14. uart
    uart Senior Member
    4,220
    1,211
    Australia
    No, if it's not supplying power to the wheels then it doesn't register. Like nh7o, I see this every day. It's like you were telling me that your wheels are turning when you drive, it's literally that ho-hum. :LOL:
  15. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yeah, or it could be that they accidentally put deuterium oxide in the radiator instead of water and it's just about to go critical. *Or* it could be something very mundane that many observant Prius owners see almost every day. :confused:
  16. bisco
    51,843
    see, the deuterium oxide problem isn't as prevalent over here. but anything's possible, i guess.:p
  17. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    That is why I don't pay much attention to the instantaneous MPG on the power distribution screen. The long-term average tells me what I need to know. And it says 48.2 MPG today, which is just peachy.
  18. uart
    uart Senior Member
    4,220
    1,211
    Australia
    LOL bisco. I'm just making the point that there's no need to go for worrying or extravagant explanations when there's a very simple and logical explanation already at hand. :)
  19. bisco
    51,843
    agreed, my idea of gallows humour.:cool:
    uart likes this.
  20. uart
    uart Senior Member
    4,220
    1,211
    Australia
    BTW. There's a minimum speed at which you can detect the engine idling by watching the instantaneous MPG. Fully warmed the engine only uses about 0.2 GPH (gallon per hour), but it can be considerably more when cold.
    The MPG due to the idle GPH can be calculated as MPG = MPH / GPH. So for example at 15 MPH the MPG at fully warm idle (stage 3a for example) would be about 15/0.2 = 75 MPG. Above 20 MPH the MPG due to idle GPH is likely the get pegged at 99.9, which is why you cant always notice that the engine is idling just by watching the MPG.
    When the engine is warming the idle GPH is likely to be somewhat higher, so you'll probably notice the MPG drop if you travel below about 30 MPH.
    On Prius that use the metric L/100km unit of fuel consumption it is much easier to detect the engine idle fuel consumption, as the L/100km increases as the speed decreases.
    With this unit you get L/100km = 100 * (L/hr) / (km/hr). So if for example the prius was using 0.8 L/hr at 20 km/hr the idle fuel consumption would display as 100 * 0.8 / 20 = 4L/100km. Again this figure could be higher at cold idle.
