I have fallen and I may get grumpy.
Discussion in 'Fred's House of Pancakes' started by JimboPalmer, Feb 4, 2014.
  1. bisco
    52,322
    glad to hear it was successful, all the best with the rehab!(y)
  2. ETC(SS)
    7,327
    Prayers sent.
    For the knee and the WX. ;)
  3. bwilson4web
    16,344
    Owch! Sorry I missed the first posts but sometimes I get busy.
    Good luck on the recovery. Then there is getting the strength and endurance back.
  4. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Gravity Check, Complete. Gravity Found.
    Awesome scar. You might be able to use that for stories and sympathy beers for some time to come. Hepe it all goes well.
    But the important question is...you have fallen, but can you reach your beer?
    CanuckPT likes this.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Prayers for good recovery.
  6. isisdave
    isisdave Junior Member
    Murrieta CA
    Looks like mine did, Jimbo, after I skidded out on a wet floor in CompUSA in 2006. One year afterward, we went to Europe and I climbed the domes in St Paul's, London; the Duomo in Florence; and St. Peter's. Sent a postcard to my surgeon. Eight years on now, and it's still fine. It does feel "different" from the other -- not bad, not anything negative, just sorta not quite so linear a response.. a little more tension at the beginning of the flex. If I didn't have another one to compare to, it wouldn't be mentionable.
    The scar will be 85% better in a year, and 95% in two, but never invisible.
  7. bwilson4web
    16,344
    In 1975, I jumped out of a perfectly good airplane and dislocated my left ankle . . . I can sometimes tell when the weather is changing.
  8. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Keep up the good work Jimbo...I know these types of repairs take some months before you start to feel like its getting back to normal.
  9. cyberpriusII
    1,157
    1,833
    Hyampom
  10. ETC(SS)
    7,327
    There's no such thing as a perfectly good airplane! :(
    If you're going to jump out of one however....do so while it's still at the airport.
    Less expensive and better on the ankles.
  11. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I was looking forward to some grumpiness. Why should I be all alone ?
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I am pleased to announce I have the brace off and can now drive again. This should also allow me to walk symmetrically again. Now I can spread grumpy all over Mississippi.
  13. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    Repaired left torn rotator cuff -- I can always tell when the weather is changing (wink,wink).
