piece of plastic (bottle neck ring) could be in oil?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Apr 29, 2014.
  1. cyberpriusII
    1,157
    1,833
    Hyampom
    Gosh, I should change my name on here to CyberWhiner....
    Anyway, end of month, time to change oil.
    Did it, and realized one of the bottles of oil is missing that little ring that separates from the cap when you twist off the cap to pour in the oil.
    Odds are, it probably went down the filler hole (although, who knows, maybe a mouse grabbed it when I was not looking).
    Anyway, car is sitting there. All done, but I hesitate to fire it up.
    Logically, I THINK it's fine. If the plastic is in there, it will melt and join all the other detritus flowing around, right?
    Thoughts, concerns....should I try to sell it to the L.A. Clippers...
    Maybe DoRunRon wants to add it to his fleet....
    Kris
    52,351
    there are many things that i could say, but as usual, i don't know anything for sure.:)
  3. JC91006
    JC91006 Senior Member
    16,827
    8,600
    That ring probably didn't break off and still on the cap
    SM-N900P ?
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Yeah, it was probably still attached to the cap. Unless you have all the bottles and caps and one is missing. :(
    SCH-I535
  5. KennyGS
    KennyGS Senior Member
    1,243
    1,045
    Keystone State
    First of all, don't worry about anyone calling you "Cyber Whiner."
    Secondly, I can't imagine the ring went down your oil inlet, so you're probably fine... "Chainsaw Woman."
  6. cyberpriusII
    1,157
    1,833
    Hyampom
    O.K., must have been that bottle of Rogue IPA Voodoo Chocolate Peanut Butter I was drinking....
    So, I put on a pair of latex gloves and went diving into the dead mice, dog crap and misc. other refuse that is in my garbage can.
    Indeed, I am not yet 30, but my eyes must be failing as I did end up finding the "ring."
    Anyway, sorry for the panic. Just was not sure if I was in real trouble or not.
    But. Here's a thought, what if some CyberWhiner did do this? Is it an issue ( ie- I could see myself doing this sometime in the future)?
  7. bisco
    52,351
    prius engine would chew it up and spit it out.;)
    jdcollins5 likes this.
  8. JC91006
    16,827
    8,600
    The Rings are engineered to break off or stay on. Millions of hours went into the design so it won't end up in your engine
    SM-N900P ?
  9. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    ;) Kris actually remembers me. I must have made a impression...
    Don't worry about it Kris. We all make mistakes, so don't feel bad or anything like that. You are still A OK in my book. You will never will be a "whiner" either in my book. At least you care about your vehicle. Most folks just put gas in them and drive them until the engine quits, then ask "What is wrong..."? :eek:
    Take care and God bless you! (y)
    Ron (dorunron)
  10. Patrick Wong
    18,210
    6,511
    It wouldn't be good. The plastic would end up in the valve train and get chewed up.
    I suggest that a funnel should be used when adding fresh oil. This reduces the likelihood of spills onto the valve cover. A further benefit of the funnel is that the spout ideally will have a smaller diameter than the plastic ring from the oil bottle cap, thus trapping any rings that manage to get loose.
    I recall seeing a loose ring or two get into the funnel, so Kris' scenario is not impossible to occur. Envision that the ring is left on the bottle, but is partially rising up on the threads as the cap is removed. Then, as the bottle is inverted, the ring could fall off.
    dorunron likes this.
  11. cyberpriusII
    1,157
    1,833
    Hyampom
    Patrick, that funnel idea is great. And would probably mean I don't have to take off the air filter cover to put in the oil.
    In other words,,,,,it would make me happy!
    Patrick Wong and dorunron like this.
  12. AzWxGuy
    AzWxGuy Weather Guy
    1,065
    547
    Tucson, AZ
    2021 Prius
    Jees, the Gollum (Smeagle) is a creature only a mother could love ...
    Taking a closer look at the oil fill port, there is a baffle plate maybe about a half inch below the neck. I would imagine if a security ring (tamper ring?) fell in there, it would have an equal chance of standing up and being retained visibly in the opening as it would landing flat and being washed further down into the head. I wonder what the melting point of that type of plastic is. If it were to make it past the baffle plate, it would probable lodge in one of the various corrugations on the top of the head. Alternately, it might be able to travel down a sufficiently large oil way into the lower block and spend its days sucked up against the oil pump screen or relaxing on or in the oil. I wonder if it would float or sink or experience neutral buoyancy?
  13. yzfrider2001
    yzfrider2001 Junior Member
  14. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Well thankfully it's too soft to directly damage anything in the valve gear, but it would melt and make a mess. It could possibly interfere with oil flow, so definitely something you want to avoid. I'm not 100% certain but I think it would eventually melt and either dissolve into, or get washed away by, the hot oil.
    Actually the much more common occurrence is the loss of the small little plastic/foam liner that typically sit in the top of the plastic cap (to improve the seal). I've heard a surprising number of reports of people ending up with these things dropping into their oil. I think what typically happens is that the little seal/liner sticks to the top of the bottle and pulls away from the cap as it's unscrewed. Then when the person doesn't notice it there stuck there it goes straight into the engine when they start pouring. So if you're worried about things accidentally falling into your oil filler then I'd watch out for this in particular.
