20,000 mile service
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Steve terry, Apr 30, 2014.
  1. Steve terry
    Steve terry Member
    217
    Oklahoma
    Toyota just told me my 12v battery was bad. It is only 9 months old. Is that normal? They are chcking to see if it is under warranty.Only mod I have is the HID headlights. I normally keep them on all the time so startup may be an issue
  2. Seanzky
    Seanzky Member
    150
    28
    NY
    Does your HID use a relay that taps directly to the battery?
  3. bisco
    52,220
    definitely not normal, but stuff happens. should be warranty, unless they notice the hids.
  4. Steve terry
    Steve terry Member
    217
    Oklahoma
    The HID has a relay and is tapped into the fuse box
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Genuine Toyota spec upgrade or dodgy cheap Chinese kit from ebay?
  6. Seanzky
    Seanzky Member
    150
    28
    NY
    Is it a 55w or a 35w?
  7. Steve terry
    Steve terry Member
    217
    Oklahoma
    Retroft 35 W . Not a cheap ebay brand. The printout showed bad so they used another machine and it showed good. It was at 75 % which sounds odd. Will a weak battery prevent the EV mode from working as often as usual? Seems like when I run around town, it does not kick on when I am at a light as much.
    Retrofit HID
    this is the slip with battery test.
  8. Seanzky
    Seanzky Member
    150
    28
    NY
    Bad battery causes a lot of problems. If you're using a 35w kit, why does yours use a relay harness? I have one from Xenon Supply and don't use a relay. Nine months sounds too early for a battery to go bad which was why my first question was if you had a relay.
    SGH-T999 ?
  9. Steve terry
    Steve terry Member
    217
    Oklahoma
    Half the people said get a relay and half said don't get a relay. So I thought it would be safe to get one. I stoppped leaving my lights on. So hope that helps.
