LED Turn Signal Relay/Flasher
Discussion in 'Gen 3 Prius Accessories and Modifications' started by pauerbach, Apr 24, 2014.
  1. pauerbach
    pauerbach Member
    101
    34
    I replaced my front and rear turn signals with these LED bad boys:
    They work great and are even brighter than OEM, though they hyperflash like I expected. A new relay...
    ... is on its way. I love Amazon so much. Does anyone have experience replacing these units? I asked the dealer while I was in for an oil change if they knew anything about it and the service manager looked at me like I was speaking in a foreign language.
    ozjimjam likes this.
  2. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    There's a long thread somewhere on here about it. Basically, you need to reach up under the steering wheel into the dash to disconnect the stock flasher. Unlike most cars, the flasher itself is fixed and does not pull out, the connector does.
  3. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    The flasher relay does come out. Most people are not world class contortionists who are able to press the release tab while pulling on the relay to get it out. ;)
    SCH-I535
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It is a horrendous, back breaking, knuckle scraping job. Enjoy! :)
    Dylan Doxey likes this.
  5. Air_Boss
    Air_Boss Senior Member
    4,198
    1,184
    New Yawk
    Any video?
  6. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    its actually not that hard if you've seen pics
  7. Air_Boss
    4,198
    1,184
    New Yawk
    Where might those be?
  8. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    I can take some for you in the morning, if you'd like.
  9. Air_Boss
    4,198
    1,184
    New Yawk
    Gratefully received. I get the impression one needs to plank oneself on the front seat locating head adjacent to brake pedal and maneuver arms up above the steering column, but maybe the photos will show the actual contortions required.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    That is what I had to do. Perhaps the newer models have made it simpler. Priusmpg I am sure will show us.
  11. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    one is also able to plank on the door sill and have the head adjacent to the brake pedal. Another tip is to turn on the turn signal and use your hearing and touch senses to locate the really once in that position. I have attached a video which shows the factory relay location and I IMG_1510.JPG IMG_1512.JPG have attached photos of the connecter so one can understand where to put pressure on the plug to disconnect it.
    Inza2, adizon, Daves09prius and 2 others like this.
  12. Air_Boss
    4,198
    1,184
    New Yawk
    Thanks, this photo recon is very helpful.
  13. xliderider
    8,140
    3,276
    Honolulu, HI
    My back hurts just watching the video. :(
    SCH-I535
    spiderman likes this.
  14. randalla
    randalla Member
    370
    Lexington, SC
    Hey Priusmpg, that's a great video you did showing the unplugging of the flasher connector. Can you tell me what kind of Flasher (model/part number) that it is that you are installing in place of the connector shown in the video and if your problem of hyperflashing LED turn signals has been resolved? I've installed LEDs in all four turn signal locations and am also experiencing the hyperflash syndrome. thanks!
  15. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    Here ya go....the one I purchased from here...works like its supposed to! I think I got a migraine putting this stupid thing in...not fun at all but worth it in the end! haha
    NoMoreNow likes this.
  16. Accordlayingkit
    1,616
    1,747
    377
    Yea that looks easy but defiantly not 41 second easy!
  17. Air_Boss
    4,198
    1,184
    New Yawk
    Maybe after you've done it 41 times, 41 seconds easy...
    Accordlayingkit likes this.
  18. okdonk
    okdonk Junior Member
    29
    Las Vegas
    Thank you for the video guide. Will be installing mine today.
    Update: Guide is so helpful. Installed mine and fixed the hyper flashing issue.
    Thank you!
    #18 okdonk, Dec 23, 2014
  19. s2kinfinite
    s2kinfinite Junior Member
    Thank you everyone for the information. This maybe a dumb question....
    Once the relay is installed does that mean both the front and rear signal bulbs need to be changed to LED?
    Any suggestions on the best bulbs for front or rear if any?
  20. xliderider
    8,140
    3,276
    Honolulu, HI
    No, you can run incandescent and LEDs in any combination.
