Is it just too hot for the A/C to function?
Discussion in 'Gen 3 Prius Main Forum' started by DigitalDervish, May 2, 2014.
  1. DigitalDervish
    DigitalDervish Junior Member
    Lost Angeles
    Right now it's 101 degrees outside and the A/C on my Prius just ain't gettin' the job done. It doesn't even feel like it's blowing cool air anymore, just lukewarm air. How can I cool down the cabin more? Temps like this only happen a couple times a year here. What do Prius owners do in places like Pheonix where 100+ temps are the norm?
  2. ReDave
    ReDave Member
    82
    25
    Central California, Sierra/Sequoia Foothills
    2019 Prius Prime
    parking in the shade ,
    when its' 110 it just takes a long time to cool it down if it's been parked in the sun
    using a wind screen and sometimes rear deck shade helps
    for years i worked downtown, and gladly paid 40 bucks a month to park in a multi storied thick cement parking garage, by the time i got out to the street it was nice and comfortable in the cabin
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    At least on the v, and I think on the liftback, PHV, and c as well, Eco mode limits the A/C. If you are in Eco mode turn it off and see if the A/C does not ramp up. I use Eco mode 8 months a year, but not on summer afternoons.
    DigitalDervish likes this.
  4. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    Lots of Prius in Phoenix, and no real complaints from what I've seen. Parking in shade with windows cracked does make a huge difference. Parked in the sun, cabin temp can reach 180 degrees. It will take a while for any AC system to pump out that much heat, but within a minute or two the air coming out of the vents should feel cold even if the air in the cabin is still hot. If it doesn't feel cold right at the vent you might want to get your system checked. If it is cold but just takes time to cool the cabin, usually opening the windows part way and setting the system to fresh air and max cold should help speed up the process. Once its pushed the hot air out of the cabin and its down to about the same temp as outside close the windows and set the ac to recirculate. Pretty common procedure on most vehicles in Phoenix ;)
    Rob
    Good call on checking eco mode, my Gen 2 doesn't do that and we haven't had our v through the summer yet.
  5. DigitalDervish
    Lost Angeles
    You may be right on the Eco mode... I set my car on Eco shortly after I bought it and haven't really touched it since. And when the heat has gotten to a certain point (usually high 90s), no amount of letting the A/C run will cool the cabin down. After an hour of driving around town, the air just kept blowing lukewarm today.
  6. BZzap!
    BZzap! Senior Member
    1,607
    878
    The ECO mode defaults the A/C to recirculate function and eliminates outside air from mixing with the cabin air. It also lowers the fan speed slightly. In this mode the cabin air is constantly re-cooled to keep the A/C compressor from running excessively. I know that when I run my car in ECO mode with the A/C on it deals quite nicely with high outside temps. Right now it 100 degrees in my area and the A/C will darn near run you out. I attribute the cooling efficiency to the fact that I have highly reflective window tint installed. It makes a huge difference. I guess what I am saying is, "Get your windows tinted".
    James4455 likes this.
  7. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    POINT -- Regarding: Window Tinting & Windshield Sun Screen = "...keeping the HEAT outside by not letting it get inside in the first place, as much as possible."
    Just remember that solar energy accumulating inside a glass enclosure is *how* a green house "works."
  8. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    To recap and simplify:
    Be sure you are NOT in ECO mode when you need MAX AC.
    Also be sure that you are not in RECIRC mode for the first few minutes.
    If the outside air is 110, the air trapped inside likely is 150 or more.
    If possible, drive with the windows down for a few minutes.......to help exhaust that super-heated air inside.
    If none of that helps, you probably need your AC system serviced.
    sdtundra likes this.
  9. Mendel Leisk
    41,824
    One tip I've heard, for A/C start up in a hot car:
    Set the system on Auto, with A/C on, and raise the target temperature until the fan speed drops from full speed. As the A/C starts to become effective and fan speed drops, lower the target temperature, but never so much that fan speed reverts to full speed. Keep doing this until you get to a comfortable level.
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    For hot summers I use a heat shield and with window visors I can leave the windows open slightly. This helps reduce the super hot air. I start with the windows down and the AC set for 72. Once the cabin temp has cooled somewhat and the AC is blowing cold I close the windows. Auto AC will have the vents in recirc. Once on the highway it does not take long to cool the cabin and the AC fan starts throttling back. The quicker I get the cabin cooled the slower the increase in battery temps.
    ECO will not cut it in a hot car. Once the cabin is cool you can go back to ECO. If the cabin is hot your batteries are hot.
  11. bisco
    52,282
    i've heard that opening one door and quickly opening and closing the opposite door will remove excess heat before starting.
    jdcollins5 likes this.
  12. TomB985
    TomB985 Member
    137
    68
    Isanti, MN
    That's a myth, it's just not true. You get the most BTUs out of the highest fan speed. Doesn't always feel that way because the air coming out is warmer than if it were on a slower speed. But the cabin will cool down faster because of the greater volume of cool air.
    All you're doing is distracting yourself while driving while limiting the efficiency of your air conditioner.
    Nora likes this.
  13. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    In the summer, I roll down all windows initially when entering the car to let the out the hot air. Even in 100 degree weather it helps reduce the heat load on the a/c system. I have my temp normally set at 74 degrees and for a few minutes it will blow out full blast in recirc mode. Some people think you should set the temp to it lowest setting but it won't cool off any faster in doing so. Once the temperature come down, 74 is just about right in maintaining a comfortably cool cabin.
  14. Former Member 68813
    3,524
    983
    US
    How about putting in a manual mode with low speed fan? Sounds much simpler than your Auto workaround.
  15. Steve terry
    Steve terry Member
    217
    Oklahoma
    My wife always laughs at me because I open a door on each side and sometimes open the rear hatch for a minute. Getting the hot air out is my first priority. With the recirculate set it will keep cooling the cabin air. If you keep it on outside air, it will have to cool down the outside air. When air moves slower across the coils, the air is cooled down better. That is why in your house, the fan is set lower for AC and higher for heat. It gets hot here in Oklahoma too. 100 to 115 on a bad day.
  16. BZzap!
    1,607
    878
    What you are doing is reducing the A/C temperature differential by evacuating hot air from the interior. Anything you can do to reduce the differential will help the A/C do a better job of making the interior more comfortable. Using the recirculate mode, reducing radiant heat (thermal window tint)and shade are going to help. The air conditioner is only capable of aproximately 20 degrees of temperature differential. This means, if you introduce ambient outside air into a confined space at the same volume as the air conditioner the temperature will reduce by 20 degrees. The more you re-refrigerate the air in this confined space the cooler the interior temperature will get. When an A/C is working properly the registers will get to about 45 to 50 degrees F. However, the differential will not allow the interior to attain that temperature. So the the more you can keep the outside air and radiant heat out of the car, the better off you'll be in the hot weather. Phewwwww! What a rant!
    TomB985 likes this.
  17. 70AARCUDA
    845
    209
    Tucson, AZ
    Summary: Keep HOT outside, Keep COLD inside.
  18. Steve terry
    Steve terry Member
    217
    Oklahoma
    That is what I said but without all the good details :)
  19. BZzap!
    1,607
    878
    I couldn't take a picture. I opted for a 1000 words. :)
  20. Troy Heagy
    Troy Heagy Member
    1,218
    Your AC needs a recharge of coolant (maybe).
    Also I leave my windows open at work (secure area). It stops the temp going over 100.
    iPhone ?
