Rice your trim rings
Discussion in 'Gen 2 Prius Accessories & Modifications' started by hobbit, Mar 11, 2006.
  1. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    So, following up on a recent post about trim rings, mostly having
    to do with selling them, I've been playing around with what one
    might be able to do with them. I think most of us agree that the
    wheels look better without them entirely and there's no perceptible
    mileage loss, but not being quite content to leave it at that I've
    generated a few "artists conceptions" of what painting them black,
    or roughly matching the tires, could do for the overall look.
    Opinions and discussion encouraged. Maybe there's actually a use
    for these things after all, or maybe I'm just nuts.
    First, the "basic black" which here, given the mistiness of the
    original pic, is a little *too* black but might be close to the
    look one would get with a heavy coat of matte:
    http://techno-fandom.org/~hobbit/pix/tide-black-rings-1.jpg
    But the rings have features that would easily allow masking off the
    continuation of the wheel spokes, lending some possibility to a
    larger "floating asterisks" look:
    http://techno-fandom.org/~hobbit/pix/tide-black-rings-2.jpg
    Of course one could mask or hand-paint parts of the rings in any
    fashion at all, with one fairly obvious follow-on giving that
    "Ben Hur war-chariot" look...
    http://techno-fandom.org/~hobbit/pix/tide-black-rings-3.jpg
    Or the obvious spinning checkerboard:
    http://techno-fandom.org/~hobbit/pix/tide-black-rings-4.jpg
    Original photo credit is from Ben Anderson at Priusonline,
    http://priusonline.com/viewtopic.php?t=7328
    _H*
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i will say one of the best color repro's of a tidelands i've seen... at least on my monitor
  3. Tideland Prius
    16,554
    I like the 2nd and the 3rd. Good thinking!
  4. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    The "Ben Hur" thing looks pretty cool.
  5. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    I also think the "Ben-Hur" look is really neat.
  6. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    numbers 2 and 3 look the best to me. Number 3 - checkers - looks a little too busy in my opinions.
    Can you try one modifying number 2 and coloring the triangular pieces next to the 'spokes'? I would give it a go but I don't have graphics software on this PC and someone spilled coffee on my work PC. What I mean is that the tires would look something like this: /-\ /-\ No, not the Ben Hur points; still flat on top like number 2. Sort of like flat-tipped arrows.
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    The Ben Hur is good but how do you do the extendable central hubs to rip out the tires of Hummers? Oh yes how far do they go out, I don't like getting close to those things.
  8. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    I actually did # 2 to my disks with black tape. This is what it looks like.
  9. hobbit
    4,089
    469
    Bahstahn
    Hmm, that's actually kinda sharp. A little more of the rim shows
    than I expected, but that's not necessarily a bad thing.
    _H*
  10. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    Wow -- that looks great! Hmmm... I'm suddenly thinking of an airbrush and some masking tape. I used to paint model cars, but that was a long time ago. I wonder what sort of paint would be best -- probably the same kind I used on the models.
  11. TonyPSchaefer
    14,816
    2,500
    66
    Yeah, that does look pretty neat. Black tape? What kind of black tape and aren't you concerned with it peeling away?
    Thanks to hobbit for starting this thread. And since I have four currently-unused rims hanging in my garage I might try some black tape experiments of my own. (once the weather turns and stays warm)
  12. Allannde
    874
    138
    Washington State
    Not worried. It is the kind of tape which is used on packages for mailing. The real common stuff which is either clear or brown. If you look, you can find it in several bright colors including black. I got mine at the local hardware store. If you can't find it there you might try a hobby shop which supplies RC airplanes. They use it to cover the wings of Foam airplanes. It is really quite durable. If it does come off it is easy to replace. Of course it will stick better if the surface is clean when you apply it.
    I took a razor blade and cut a narrow strip around the outside edge to expose just a little (you can see it) because I didn't like the look of black on black. That is a matter of what looks good to you. After all "beauty is in the eye of the beholder."
  13. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    What a hoot!! I've thought about painting mine to match the car (seaside pearl), but I like what you've done. My rims are as yet unscratched and I'm reluctant to actually paint them because if it doesn't work, I'm out the 200 bucks for the set of four.
    Has anyone actually painted his/her rims? If so, what kind of paint? I wonder how paint would hold up under the continuous assault of road grit.
    I like the "floating asterisk" best.
    Bob
  14. Allannde
    874
    138
    Washington State
    I had the same reservation about painting which is why I used tape. This tape can be removed without leaving damage. The "floating asterisk" would be easier to do. Simply don't cut the tape off the outside edge of the disk like I did.
