2013.... How do I shut off JUST the back up beeper!?!?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Gas Mizer, May 6, 2014.
  1. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    That beep.... :mad:
  2. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    Either you get a scan tool or you find a mechanic who has one.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  4. onlinemissy
    onlinemissy Junior Member
    Australia
    I went to my local dealer who absolutely refused, stating that it was against the law to change this in Australia :-(
    If I could find where to plug it in I would do it myself!
    2013 Prius V
  5. Epiphany2000
    Epiphany2000 Member
    126
    San Francisco Bay Area, CA
    You could definitely do it with the MINI VCI for TOYOTA TIS Techstream Diagnostic Cable & Software, although I don't know how much shipping to Australia would cost. The software gives you a plethora of diagnostic information and customization options. However, it also requires a 32-bit windows version, unless you are willing to do some tinkering around with your OS. If you have Win 7 professional or higher (not sure if Win 8 has this option), you can use windows XP mode (virtual machine) free of charge, which is the route I took. You can also check on e-bay for similar products.
    Bear in mind that this solution, despite being very powerful and versatile, is completely illegitimate (the software is pirated), but it does work well.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The OBDII plug is under the dash, that is where you can plug in your OBD device to reprogram it. (I have no idea about Australian law, I barely cope with US law)
  7. Tom_in_AZ
    Tom_in_AZ 2008 Prius (Base), Magnetic Gray, Package 2
    Scottsdale, AZ
    Oh wow, it can not be changed the way that the 2008 prius could be? I was starting to get annoyed by that beeper as well, and was considering shutting it off the way I did on my first Prius.
    iPad ?
  8. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    The dealers in the USDM will change the setting to a single beep if you request it.
    SCH-I535
  9. onlinemissy
    Australia
    I have a few laptops, at least one of them has Windows 7, and I will try eBay
    Thanks for the advice, I will let you know how I go
    Cheers
    Carol
  10. mtbiker53
    mtbiker53 Junior Member
    87
    22
    cape cod
    Did mine with OBD bluetooth and TORQUE app.
    steve
  11. c3 rolling
    c3 rolling Junior Member
    My dealer wants to charge 80 bucks to do it .... (SoCal)
  12. pauerbach
    pauerbach Member
    101
    34
    Tell them to take their $80 and shove it where the sun doesn't shine. That's an outrage.
  13. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    Ok... So I have Torque installed. Now how do I shut the beeper off....?
  14. Par Avion
    Par Avion New Member
    Southernmost California
    I took delivery of a 2014 Prius Four on Sunday, June 1. On Monday, June 2, I was at the dealership service department politely demanding the reprogram of the back-up beep from constant beeping to a single beep. Free of charge. They were nice about it and it was done in a few minutes. No hassle. They also allowed me to switch out the new awful, horrible quality standard cargo mat for the well-made, higher quality standard cargo mat out of my 2012 Prius Two.
