engine temperature?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brin wood, May 13, 2014.
  1. brin wood
    brin wood Member
    100
    upstate NY
    is there any way to monitor the coolant temperature? Or have I overlooked something. I miss coolant temp and oil pressure gauges.
    LisaMcC likes this.
  2. vskid3
    vskid3 Active Member
    773
    228
    The only way is with an OBD-II reader, such as a Scangauge, Ultragauge, or Torque app w/bluetooth scanner.
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    The coolant temp in my 05 Prius averages 190.4 °F after reaching operating temp at 60+ mph using the Torque app and Bluetooth. What are others getting with SGII and the Ultragauge?
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I recall 188F being a frequent Coolant temp on my Gen 2. (my v prefers 195F)
    As I recall, the oil pressure sender is digital, you either have enough pressure or you don't. Since the sender knows no more, no OBDII device can know more.
  5. vskid3
    773
    228
    The standard gauges should be the same with any scanner. That's about what my '05 Prius does according to my Ultragauge, even up to 75mph. I think I've seen 195F a few times going up hills at freeway speeds, pretty sure I've never hit 200.
  6. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Also put PriiDash software on the list for monitoring, which is what I use.
    I have seen just over 94C/ 200F on a hot day while climbing a long hill with a very strong tail wind, such that the relative wind was almost zero. The a/c was also on.
    Any other condition it stays close to 85C/ 185F.
  7. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Almost always 186 using Engine link on my 05
  8. rjparker
    10,100
    6,263
    I use the $30 P10 Obd2 Scanner. Various configurable displays. There is no oil pressure sensor to monitor.
    Like a lot of imported gear, the instructions are minimal but it does work reliably.
  9. rjparker
    10,100
    6,263
    If I want more temps including battery, motor generator and inverter temps along with water pump status, I plug in a bluetooth reader and monitor with the configurable "Car Scanner " IOS app. Realtime details are sometimes interesting during high ambient temperature situations.
    This screenshot was taken when it was 100 f outside after an hour of highway speeds.
    ydpplqbd likes this.
