*WTB Coilovers or springs SoCal (2010 + )
Discussion in 'Private Sales' started by si12j12, Apr 29, 2014.
  1. si12j12
    si12j12 Member
    64
    Interested in coilovers or possibly springs for a 2010 +
    Interested in pick pick up atm in the SoCal area.
    Let me know what you have, interested in purchasing ASAP
    Thanks
  2. si12j12
    si12j12 Member
    64
    still looking....
  3. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    731
    Boulder Hybids, Boulder, CO
    Are you looking for front or rear? what is your reason? better handling? more payload capacity? or to restore factory handling on a high mileage car?
  4. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    I'm sure it's just for lowering/aesthetics
  5. si12j12
    si12j12 Member
    64
    Aesthetics is correct, however after installing springs I am still unhappy and want wore dampening control .
    SGH-T999 ?
  6. shawnb2
    shawnb2 Active Member
    533
    107
    22
    Thousand Oaks, CA
    I have a slightly used set of Tanabe Z40 coilovers that I bought from a user on here and only ever installed the rear shocks. Somehow either the rear spring perches weren't sent or I lost them, but either way it stopped me from going forward with installing the rest. The rear shocks are currently on the car but easy enough to remove. The new perches and all of the hardware to mount them is about $400. The full set retails for over $2200. If interested I'd sell everything I have for $1000. So you'd be into them for around $1400 when all said and done. The shocks have literally been on the car for maybe 2 months. Let me know what you think.
  7. shawnb2
    533
    107
    22
    Thousand Oaks, CA
    You know what. I'll make it $900 just because I really want to move these. You won't be disappointed. Check them out on their website, Tanabe Sustec Z40 Coilover Fully height adjustable as well as 40-way adjustable for dampening. I've just decided to start working the car back to a bit more of tame state. Not stock by any means, but not lowered and running 19's. I may even have a source to help you out with the hardware for the spring perches to get the price down a bit. Depends on his schedule. If you decide to go with them I'll work with you to get the parts. Let me know.
  8. shawnb2
    533
    107
    22
    Thousand Oaks, CA
  9. Eugene Hong
    Eugene Hong Member
    114
    30
    Bay Area, CA
    So do you currently have aftermarket springs on the car?
  10. si12j12
    si12j12 Member
    64
    Love the idea of owning those but price range is a little high for me, thanks for the offer anyway.
  11. si12j12
    si12j12 Member
    64
    Yes but the ride height did not accurately lower the car, in stead of 1 inch drop all around the drop in the front is lower than the rear which is evident and annoying for me.
  12. Eugene Hong
    Eugene Hong Member
    114
    30
    Bay Area, CA
    Which brand? H&R?
  13. si12j12
    si12j12 Member
    64
    No , cheap Megan springs
    SGH-T999 ?
