Until We Meet Again...
Discussion in 'Gen 3 Prius Main Forum' started by car compulsive, May 16, 2014.
  1. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    I traded the Prius in for a 2014 Accord EX sedan, 4 cyl. with CVT. I wanted a sedan with more room, comfort, quietness, handling, and power than the Prius. I was originally planning on another hybrid, but the Accord hybrid system is untested with a small trunk and no spare tire, I didn't care for the Camry's cabin, and the Avalon just didn't justify a $10K jump over a gas Accord. (Especially with some Accord owners reporting MPGs in the mid and upper 30s.) My observations about the Camry & Avalon can be found here: Observations After Shopping Camry & Avalon Hybrids | PriusChat
    I had high hopes for the Toyota offerings, but they just didn't sweep me off my feet.
    I'll probably be back in a hybrid in the future. Especially if the next generation Ridgeline gets a rumored hybrid powertrain. All the best to you Gen III owners.
    F8L likes this.
  2. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    What about the Fusion Hybrid/C-Max Hybrid?
  3. CdotK
    CdotK Member
    376
    46
    ^^ what he said... The Fusion is much nicer than the Honda by far!
    hybridbear likes this.
  4. car compulsive
    741
    274
    Michigan
    The Fusion cabin is rather tight, I don't like the short window driving-in-a-bathtub feel, and I don't like the styling in general. I like the Cmax cockpit and driving it around town, but it pitches fore & aft on the freeway and has limited cargo space for that style vehicle.
    Greg75 likes this.
  5. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    I've been reading some great reviews for the 2014 Accord Hybrid. The small trunk and no fold-down rear seating is the only minus I can find. It has an electronic CVT, similar to the Prius. The EPA numbers are close to the Prius.
  6. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    Actually, the HAH eCVT is nothing like the Prius, otherwise Toyota would be suing Honda for patent infringement. The HAH works like the Chevy Volt most of the time. The ICE of the HAH is not connected to the wheels, the Prius ICE is connected to the wheels. The HAH ICE spins a generator which sends electricity to the electric motor which is connected to the wheels. Since the electric motor RPM has a linear correlation to wheel RPM the highway efficiency of this setup would not be the best. Thus Honda designed a clutch plate that will engage at highway speeds which directly connects the ICE to the wheels.
    This is very different from the Prius.
  7. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    By similar, I meant they are both eCVTs: neither one uses a variable mechanical transmission. I know they use different implementations.
    The Accord hybrid might be more efficient overall than Toyota's synergy drive, given its EPA numbers are better than the comparable Camry hybrid.
    #7 co_prius_3, Jul 7, 2014
  8. bisco
    52,383
    and no spare tyre.
  9. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    You're right. It comes with a tire repair kit, but no spare.
    #9 co_prius_3, Jul 7, 2014
  10. bisco
    52,383
    it does come with a bottle o' slime.
  11. El Dobro
    El Dobro A Member
    7,093
    3,271
