Prius Plug-in and Volt Pros and Cons
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Bill Norton, May 9, 2014.
  1. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    That's exactly why I laughed at his comment. There is no doubt the A/C would have been running while I drove.
  2. Bill Norton
    Bill Norton Senior Member
    2,152
    734
    MONW, Ks.
    Of course you have the AC on in Phoenix while driving.
    Then you get to your destination, shut off the car, lock it, plug it in, and run for the AC to get out of the furnace.
    Then, what is your Li-Ion battery pack experiencing while charging? That was the question.
    If it's like the Leaf battery it starts to degrade in that environment.
    Some describe this as an "outlier" situation, but lots of people live in that part of the country.
    In Phoenix people walk around like they're half dead. In Tucson people walk around like they are dead.
    A little PiP battery in the San Francisco Bay area has an easy happy life.
    Li-Ion batteries need heating and cooling only in certain temperature ranges.
  3. Camfab
    Camfab Member
    124
    36
    2014 Prius Plug-in
    I've got to agree with this, most people that drive these cars, heck most cars, are clueless. It was 105 degrees today in sunny Simi Valley today. I watched my neighbor come home and plug his Volt in. Do you really think 99.5% of any plug in drivers know squat about battery temps? His car is black on black and even if his a/c was on while he was driving it wouldn't matter. I can tell you that cars interior probably hit 140 degrees in ten minutes. If a car isn't designed for this, then the engineers are complete morons.
  4. markabele
    5,084
    1,782
    Nebraska
    You don't think a Tesla is the highest tech car on the road right now?
  5. Seanzky
    Seanzky Member
    150
    28
    NY
    Besides the Ferarri, Porsche, etc. Hybrids, I'd say Tesla is the highest tech car that's readily available to consumers.
  6. Bill Norton
    2,152
    734
    MONW, Ks.
    To me a Tesla is just a bigass BEV.
    Sure it has a fancy big touch screen that does everything, no buttons.
    It consumes power at a decent rate even when shut down.
    You can't leave it unplugged at an airport with the battery low for a long time.
    You just can't go anywhere at anytime in it. You have to constantly keep in mind it's a BEV.
    Range Anxiety comes as standard equipment.
    But, they do offer free power if a Supercharger happens to be on your route!
    Who doesn't love free power? (If you buy the option for it or bought the big battery one.)
  7. Seanzky
    Seanzky Member
    150
    28
    NY
    So despite all the "cons" of a Tesla Model S, you do agree it's the highest tech car then?
  8. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Your Volt-owning neighbor will be fine. The Volt will run its compressor to chill the battery while it's charging. The interior temperature doesn't matter to the Volt.
    The PiP and other air-cooled battery plug-in vehicles are the ones in trouble.
  9. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    It still never fails to amaze me to see FUD being spread on a site that all through the first decade of the century worked so hard to defend itself from FUD.
    I can take my EV anywhere I want to go at anytime. In almost 70,000 miles of drivings Teslas I have never had range anxiety. I guess it none of mine came with that equipment you call standard.
  10. woody weaver
    woody weaver Junior Member
    68
    Frederick, MD
    2014 Prius Plug-in
    Highest as a metric, calls for a quantifier (as opposed to simply 'high tech', which describes a class of technology.) What would highest mean? Most embedded controllers? Most patents? Most inter-device communication (since decoupling is often a classification of high tech.) I'd be quite interested in the results of those statistics.
  11. woody weaver
    68
    Frederick, MD
    2014 Prius Plug-in
    Anxiety is a natural response to uncertainty. Uncertainty can be resolved through knowledge. If you have a true, justified belief that either you can identify power sources within cruising range, or are comfortable with backup remediation, then there should be no anxiety. Zythryn, justified by experience, has a true belief he can find adequate power.
    I would expect that finding chargers within cruising range should not be a complicated problem, for normal driving patterns. Augmented with computerized search routines, it should not be a complicated problem for even most unusual driving patterns. I don't think range anxiety is a thoughtful man's problem when owning a Tesla. (And it would strike me that based upon the cost, most Tesla owners are thoughtful.)
    Tracksyde likes this.
  12. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Right. The Volt's battery thermal management system has its own direct connection to the air conditioning system so it can cool the battery independently from the cabin. Tesla almost certainly does the same. It's all automatic so you normally wouldn't notice it.
    However, on a few occasions I have had my Volt's cabin climate controls on "fan only" on a hot day and then noticed cool air flowing out of the vents for a few minutes when the battery decided to cool itself. Even though the battery has its own direct A/C coolant loop connection, it shares that loop and the A/C compressor with the cabin climate system. If the car was turned off there wouldn't be any cabin fan running so you wouldn't be wasting energy cooling the cabin even if the battery is cooling itself.
  13. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Yes, but one person is the progenitor of it all. The mother-FUDder, if you like...
    markabele and Tracksyde like this.
  14. john1701a
    12,818
    5,303
    58
    Again, how often would that situation actually happen?
    If you don't have a sun/rain shelter or garage, would you really be recharging during the day's peak with a PiP?
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Gas engine is used to baby the battery if it is too hot. It is one of the benefit of being a plugin hybrid. Reusing the existing hardware is a weight saving feature so there is no need for liquid cooling that can leak and short the battery.
    rxlawdude likes this.
  16. Bill Norton
    2,152
    734
    MONW, Ks.
    Are facts FUD?
    Are apologists easily brought to name calling?
    Are asking questions not a nice thing to do?
    John,
    Wouldn't a PiP get charged every day or multiple times a day? Does it get nice and cool at night in Tucson?
    Zyth,
    Could it be your "wants" are limited, like the range of your car?
    Plus your car has to be charged to be 'ready to go at anytime'.
    I need one car that does it all. Not an expensive local only car.
    I want to take a vacation to the Rockies in a few weeks. I just go, and Ta'hell with electricity needs.
    +10 hours or so is the first leg. Western Kansas is so nice !! I wish it were longer.....
    I went to a local 'Clean Energy Fair' back in the spring, here in KC.
    There were two Teslas there. One owner said he bought it in Denver.
    I asked the owner how he got it to KC. Did he trailer it?
    He said "I drove it". I said "What about the range?" He said, "I spent the night in a KOA camp".
    I just said, "Oh" and stopped talking at that point.
    From depleted charging a Tesla on 120V @ 1.3Kw is what? +20 hours??? +30 hours??
    We should all stop talking about Battery Pack Life.
    This is a matter we will have to deal with far off in the future, hopefully.
    It's like we are arguing about a weather forecast.
    Only time will tell, right?
  17. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It doesn't lock to the wheels. ICE and the traction motor torque has to oppose each other in order to turn the wheels. That's how Volt PSD is set up.
    The problem is, the 1.4L ICE is in a vehicle that weights more than the Equinox SUV. The wheels/tires has to be sized to stop safely, increasing rolling resistance. It is a snowball effect.
  18. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Since he was at a KOA campground, he probably had had access to a 50A 220/240V connection. Which is why he most likely stayed at a KOA campground to begin with.
  19. Bill Norton
    2,152
    734
    MONW, Ks.
    usb,
    You know what I mean, yes, when that 3rd clutch engages the engine is mechanically connected to the PSD, which is mechanically connected to the wheels. Parallel Hybrid.
    Wheels and tires sized for FUN !! With a matched suspension!
    Still I think the engine could use some SW to make it more Prius like.
    It still takes X amount of power to roll 70 MPH. (Seen the latest Car and Driver?)
    The Prius makes that power more efficiently due to the whole pseudo-Atkins thing, and 13.5/1 compression.
  20. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    There are lots of people who charge at work.
    I hope to be able to charge at work sometime but they won't be giving me carport to do it in.
    Jeff N likes this.
