Where is our recall?
Discussion in 'Prius c Main Forum' started by FHariton, May 20, 2014.
  1. FHariton
    FHariton Junior Member
    White Plains, NY
    2001 Prius
    My dealer told me our hybrid drive was the same as the regular Prius, just scaled down. So why were we not recalled and fixed like they were?
  2. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    Our system is similar but no major components are shared. So quite possibly no need. If we need/deserve it we'll get one. Our powertrain is the most similar to genII even then we are a decent bit different.
  3. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    The recalls I'm aware of were for the GenII, and were to replace the intermediate steering shaft on certain vehicles (some were not properly heat treated, but not all), modify the gas pedal for floor mat issues (cut off the bottom inch), and replace the inverter coolant pump.
    If these are what you refer to, they have been fixed long before our cars were built. We will get notice if our C has an issue in the future.
    And, welcome to PriusChat!
  4. mertechperformance
    532
    126
    Nor-caL
    I believe he's referring to the genIII ecu reflash
    SGH-T889 ?
  5. Mendel Leisk
    41,750
    The latest gen 3 hatchback recall changes the car's acceleration behaviour, they were worried about overstressing some components in the inverter, causing them to crack under hard acceleration. There's a good possibility the C's design varies enough that it's ok as-is.
  6. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    I went out and checked my C and I don't think there is going to be any problem with overstressing components from rapid acceleration:LOL: Don't get me wrong I can accelerate as fast as I need, just not likely to break a drive shaft kind of acceleration.
    I really hope they don't recall the thing and reduce the power:sick:
    HotDogWater likes this.
  7. mertechperformance
    532
    126
    Nor-caL
    They're not talking about driveshafts, lol. Components in the converter ha ha.
    SGH-T889 ?
  8. xraydoug
    571
    176
    Roseburg, Oregon
    Ok, I just couldn't help but make fun of the awsome torque of my C.
    mertechperformance likes this.
  9. mertechperformance
    532
    126
    Nor-caL
    That's the thing we've got torque, just no power
    SGH-T889 ?
  10. xraydoug
    571
    176
    Roseburg, Oregon
    call it what you want, it won't slam you back in your seat, My wife has a 12 hycam and that is a different story, I wish they would put that in a prius c, that would be fun. and still would likely get almost 50 combined. we get 40 with it in the camry. beef up the drive shafts and put that 2.5l with the larger hybrid components. the 12 and on camry hybrid weighs less than the older ones, I wonder is it has lighter battry.
