Prius Plug-in and Volt Pros and Cons
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Bill Norton, May 9, 2014.
  1. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    No, asking questions doesn't offend. Making statements not based in fact, and coming to a Prius forum to tout the supposed Volt advantages are offensive.
  2. Bill Norton
    Bill Norton Senior Member
    2,136
    730
    MONW, Ks.
    All sunshine and a Big PiP PeP Rally. Is that what you want from your forum?
    Some technically minded adults can have a discussion and not resort name calling and getting their feelings hurt.
    Why don't the members with sensitive feeling and Big brand loyalties start a new thread?
    PiP PeP Rally.
    Then leave this thread to the tech enthusiasts that want to talk about what it was, what it is, and what it shall be!
    These cars are the future and us owners are leading the way !!
    There is no "covert effort to greenwash an offensive conspiracy that undermines the young and impressionable minds of existing and potential PiP owners".
    Shouldn't there be a source for the pro and cons of these high tech cars?
    Or should forums be brand specific and only allow the 'Pro' to be posted?
    Where should the Pros and Cons thread be posted?
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    It is probably more toward 10 MPG difference. Remember, gasoline is very energy dense. The difference between 40 MPG and 50 MPG is 6.75 kWh of energy. That amount in electricity can charge PiP battery twice.
  4. markabele
    5,084
    1,782
    Nebraska
    Alright...we've gone about 12 hours now without anyone responding to him. Let's keep it that way. That may be the only way he will go away.
    rxlawdude likes this.
  5. woody weaver
    woody weaver Junior Member
    68
    Frederick, MD
    2014 Prius Plug-in
    "Talk of the Devil, and he's presently at your elbow."
    Profile / "People You Ignore" is the right solution.
  6. Bill Norton
    2,136
    730
    MONW, Ks.
    OK, you only want SUNSHINE.
    Enjoy your closed little world.
    I have contributed in the past to this site. Nobody will talk about ATF changes for a PiP.
    But anything else that does not tow-the-line is 'Trolling'.....
  7. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    When do you plan to change the three clutches in your Volt transmission? Are they in the maintenance schedule? How about ATF change?
  8. john1701a
    john1701a Prius Guru
    12,806
    5,295
    57
    That's a great example of perspective & detail.
    Toyota expended a great deal of effort to optimize their entire system. Having to deal with GM's choice of more battery to overcome engine inefficiencies is a waste. They're trapped with a complex design heavily dependent on ample battery capacity. Meantime, Prius holds its own just fine without.
    In other words, which has the greater potential to compete with the actual competition (traditional vehicles) ?
  9. rxlawdude
    701
    219
    So Calif
    2015 Tesla Model S
    Ah, that's MUCH better! :)
  10. woody weaver
    68
    Frederick, MD
    2014 Prius Plug-in
    This is an important point, and hangs on the definition of 'compete'.
    One can do an endless analysis, and 'its turtles all the way down.' What is the actual metric?
    Probably the most obvious competition would be sales numbers. Another obvious, but more subtle, is 'total use of energy' (although it is important to realize that the most efficient propulsion is shank's mare.) Another might by total cost of ownership -- although that misses an important component of ownership in pleasure.
    It is rather fun hearing the discussion, though.
  11. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I've seen zero evidence in support of your apparent theory that GM designed the Volt with a large battery pack due to having a less efficient engine.
    Everything I've ever read consistently paints a different theory -- that they designed the Volt with a large near-EV sized rechargeable battery pack and then chose an already available small engine used in their European small cars that would require minimal additional engineering cost and risk.
    You seem to be having a hard time grasping the obvious -- the Volt was designed to compete with 70-100 mile range EVs while providing a range extending gas engine. The Volt was never intended to be an engine-focused hybrid with a smaller battery. It was intended to be an EV-focused hybrid.
    They no doubt wanted to compete with Toyota with a car that minimized gasoline consumption and demonstrated advanced technology competence but they entered at a different product design point. GM was obviously not trying to just make their own near-identical Prius clone.
    You seem to think that GM should build a Prius competitive engine-focused hybrid and I agree with you. But that hypothetical future GM one-mode engine-focused hybrid is a different car. Please stop pushing the line that the Volt was supposed to be that vehicle.
    That being said, it seems likely that future versions of the Prius Plugin will get somewhat bigger batteries and reports indicate that a trim line or variant of the Volt next year will offer lower cost and possibly somewhat less battery capacity (but not much less) than the 1st gen Volt. It makes good marketing sense for two cars in somewhat different but related product points to stretch towards each other at a market point that will capture additional customers. In addition, it seems there will be a higher trim line or variant Volt with a higher battery capacity than the 1st gen.
    It's still the same story even as it evolves over time. The Volt brand is focused on providing higher, more EV-like battery capacities than the Prius brand and the Energi brand and unsurprisingly this means different tradeoffs in the engineering design.
    bedrock8x and Zythryn like this.
  12. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    duplicate post
  13. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    There are 4 choices:
    1) Extract more energy from gasoline that is on-board.
    2) Replace it with another fuel (electricity from various sources).
    3) Do #1 and also mix in as much electricity as possible.
    4) Do #2 but get less energy from the gasoline, due to heavy battery.
    A regular Prius is #1.
    BEV like Leaf is #2.
    PiP is #3.
    Volt is #4.
  14. Bill Norton
    2,136
    730
    MONW, Ks.
    usb,
    Toyota expended a great deal of effort to optimize their entire system. ( Great? where does this come from?)
    Except when it came to transaxle maintenance. There, it seems they dropped the ball.
    I started this helpful thread for those who care about preventive maintenance: ATF fluid changes ARE Required. | PriusChat
    On the Volt, the 3 clutches do their engaging and disengaging only in a "No load" state, supposedly..
    The service manual calls for an ATF change at 97,500 miles. (Where did that number come from.)
    Anyway, I will definitely be doing an earlier change than that spec, , after my Gen3 Prius experience.
    Are any PiP owners concerned about the condition of their ATF and is there still a lack of scheduled change intervals?
    (Still no word on what the current PiP manual state on this subject)
    "Having to deal with GM's choice of more battery to overcome engine inefficiencies is a waste."
    Funny, I think pumping gas into your car and sending your dollars to OPEC is a waste.
    I do it too, but rarely. Haven't heard that inefficient stinker in weeks!!!!
  15. Bill Norton
    2,136
    730
    MONW, Ks.
    xrl, I thought lawyers are not supposed to put their fingers in their ears???
    Aren't you trained to be stronger than that?
    Sorry everyone else,, I couldn't resist the poke...
  16. markabele
    5,084
    1,782
    Nebraska
    I wouldn't blame him...you have to be one of the most annoying people (at your own choosing) I've ever came across on this site.
    finman likes this.
  17. john1701a
    12,806
    5,295
    57
    You seem to keep forgetting that my push is for diversity, offering choice. That means additional models with other configurations... not the one-size-fits all we ended up getting.
    As for the "intended", we have already left that past behind. Goals changed along the way. Being different now means identifying the intended audience, the consumers who will be buying it and when.
  18. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I cannot imagine what you would call 'evidence,' but really, consider GM's alternatives:
    They only had crappy small ICE engines, so their choices boiled down to two:
    Larg(er) battery with a crappy ICE;
    Small(er) battery with a crappy ICE.
    That only seems like one real choice to me.
    As for why 40 miles range, that is easy: it matched a study done at the time, and GM was kissing the US government's nice person while begging for another 70 billion or so in bailout funds.
    iplug likes this.
  19. john1701a
    12,806
    5,295
    57
    Btw, the 70-100 mile category didn't even exist back when Volt was introduced. So, there's no way that could have been an original goal.
  20. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I've seen no journalist or even any credible other source dispute Lutz's statements that he originally conceived of the Volt as a BEV and then was talked into a PHEV design with EV first followed by a range extension mode.
    I'm not aware of anything stopping GM from adapting one of their small engines to operate with a pseudo-Atkinson cycle and then build a one-mode hybrid transmission to compete with Ford and Toyota. They know how to do that and seem to have the relevant patent coverage. They could have chosen to do that instead of the Volt.
    But GM has evidently chosen to compete at a unique product point rather than spend time doing another Prius-like hybrid first. They don't have infinite engineering resources. Neither does Toyota which could have also chosen to focus on hybrid trucks and large battery plugin hybrids first but wisely worked on small hybrid cars first when they started nearly 20 years ago.
    The 40-mile EV range target and 16 kWh battery size has been consistent since the Volt concept car was first displayed at the Detroit auto show in January 2007 well before the economy collapsed in the worst recession since the Great Depression of the 1930's.
    Bill Norton likes this.
