TRD Plus Package Sway Bar on PIP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Alyn99, May 16, 2014.
  1. Alyn99
    Alyn99 Junior Member
    37
    2014 Prius Plug-in
    I've seen some posts here promoting the TRD plus package sway bar for use on a PIP. My new 2014 doesn't seem to sway much at all and I have no interest in modifying the current shock/coil set up as it rides great with my 44/42 inflation set up. That being said, if the TRD sway bar would improve handling/cornering ability on the stock PIP without any other mods, for $270 I would self install it in a heartbeat. An local Toyota dealer will warranty the TRD sway bar for 3 years and has said it will not invalidate my warranty. My hesitation comes from the fact that Toyota did not install ANY sway bar on the PIP and am wondering if that was a cost cutting play or was the suspension reconfigured in a way that a sway bar was overkill. Thoughts from anyone who has actually installed the TRD plus package Sway bar on a STOCK Prius Plug-in without lowering or changing the shocks? Did it make enough of a difference to warrant the investment?
  2. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    You'll find a few posts here in this forum, but many in the Mods & Accessories forum.. but the short answer is "yes, it makes a huge difference".
    I know a couple of other PiP owners who installed the RSB (who normally would never consider modding their car) who were pleasantly surprised at the difference and dont regret the purchase.
    I'm sure the lack of a rear sway bar is both for cost cutting and, generally speaking, "unnecessary" since your typical Prius owner wouldnt know the difference (or even care) whether the car had one or not.
    I've installed the RSB, front and mid lower chassis braces and will soon be installing the Cusco front strut tower bar. The RSB made the biggest difference. But I expect the front strut tower bar to make a noticeable difference also. The first item I installed was the mid lower chassis brace, which I did notice. But I suspect it was because it was the first item I installed.
    KLD_Prius_PI_Synergy likes this.
  3. Alyn99
    37
    2014 Prius Plug-in
    Good to hear. I will start with the RSB. I assume all your mods were to an otherwise 'stock' plug-in Prius suspension?
  4. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Yes, correct, stock.
    If you decide to install yourself, if you Google it, there's a guy (probably on here somewhere too) that installed it himself and created a tutorial on his blog. He installed without jacking up his car. The thought was appealing to me so I tried it without jacking up the car and I dont think its possible with normal sized human hands :). I fiddled with it for about 10-15 minutes before I just decided to jack it up and remove the rear wheels. It made it soooo much easier. So, if you read or hear it can be done without jacking the car.. yeah, I'm sure its possible.. but if you own a jack, save yourself the frustration.
  5. Alyn99
    37
    2014 Prius Plug-in
    Ok, jack's not a problem. Thanks for the tip!
  6. Alyn99
    37
    2014 Prius Plug-in
    I've decided to go down this road and allocate about 1k for a handling upgrade while still keeping the stock rims, tires and shocks for now since they're new. Seems consensus agrees with what you did, so in terms of install order (don't have the cash to do it all at once),where would you start and are you sure they didn't make any improvement to the 2014 suspension over the 2012 ?
    1) Front chassis brace - does Rude person's even still make these??? Link?
    2) Mid Chassis brace - does Rude person's even still make these??? Link?
    3) TRD RSB (plenty of links for this one)
    4) Cusco front strut tower bar
    This order seem right or should I do the RSB first?
  7. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    As far as I know, there were no changes from 2012 to 2013 to 2014 in the Prius suspension. The stock mid chassis brace was updated in 2012 (I think) from 2010. Rude person's said the newer one was much better than the earlier one, but he believed (and I as well as many others here agree) that his mid chassis brace did make a difference. He tossed around some numbers about increased rigidity n' all that.. but bottom line, its better than stock. :)
    I'm kind of torn about the lower braces even though I have them. I did them first so each brace was somewhat noticeable. But I wonder if it would still be noticeable if you did the strut tower bar and the RSB. I guess my point is.. the lower chassis braces help.. I'm confident in that. But would they still be helpful if you already had the STB and RSB? I don't know. But I wouldnt remove my Rude person's braces and sell them either.
    In any case, your order is pretty much the same as me. I guess the benefit of following that order is you'll know the parts you bought and installed made a difference because you will notice it. Not sure if that's helpful, but it would make me feel better :ROFLMAO: . But I pretty much followed that route for the same reason(s).. its cheap to start with lower braces.. easy to install.. and I figured if it made the car funner to drive, then I would continue with the mods..
    BUT.. now that I have the RSB, I think it made a huge difference.. much more of a difference than the lower chassis braces. So I guess if I had a chance to try out each component first, individually, I would've gone with the RSB first.
    If you want to get Rude person's's braces.. you'll have to find them on eBay because he was told he cannot conduct business on PriusChat (I'm guessing since he's not a paid advertiser or something along those lines). A couple weeks ago he said he was going to stop selling for a bit since he was going on vacation.. so dont be alarmed if you cant find them.. it just means he's not back yet.
    Something else to consider.. now with all the pieces installed, you really feel the weakness of the tires :ROFLMAO:
    xpcman likes this.
  8. Alyn99
    37
    2014 Prius Plug-in
    Thanks for this detailed reply! I have read that installing the RSB alone without the STB induces some oddness of its own so best to do those in tandem, which seems logical. I may start there as I can find no post stating that ' hey, I installed the TRD RSB and hated it, no difference", etc..). Are there service issue that having an STB installed causes? i.e. it needs to be uninstalled for certain maintenance procedures? Does it violate warranty?
  9. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    It shouldnt violate any warranty. The only way Toyota COULD try to invalidate part of your warranty is if they could prove that the STB CAUSED damage that would not otherwise have happened without the STB (and being such a "basic" device and how it connects to the car, I cant see that ever happening). But Toyota could never say "oh, you have an STB, then we wont warranty your hybrid system" since they are totally unrelated (see this article for more info)
    The Cusco STB does not interfere with anything that comes to mind (brake fluid reservoir cap can be removed and fuse box cover can be removed too.. I believe the Tenabe one restricts access to these items). But even if you ever decided to do something crazy, like pull the engine :ROFLMAO: , the actual bar of the STB comes off with just a couple of nuts/bolts.
  10. Alyn99
    37
    2014 Prius Plug-in
    Ok, will check for sure with dealer on warranty first as it is a lease. Thanks for the help!
  11. Mr.Electric
    Mr.Electric Member
    287
    102
    San Francisco
    I did 4 new struts on my 2010 and it definitely made a difference. I used kyb brand struts. Tire and wheel changes make the most noticeable change to handling IMHO.
  12. spacebunny
    spacebunny Junior Member
    San Francisco
    I contacted a local Toyota dealer about the RSB part cost and installation. They indicated the part is only for the regular (Non-PIP) Prius. That said, the parts guy indicated the mounting points are identical so he wasn't sure why the RSB wouldn't be compatible with the PIP. Clearly it mounts just fine, so I'm curious if any folks have had different experiences at the dealer. If so, any dealers in the Bay Area you can recommend?
  13. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    You don't need a dealer to install the RSB. Any one with a few tools can do it in their driveway. A car lift makes the job much easier. The TRD part comes with full instructions/parts that any local auto mechanic can follow.
  14. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    When my co-worker was trying to buy the RSB for his PiP, he got the same line from the local dealer about it not fitting the PiP. I do recall reading somewhere around here (probably the Accessories and Mods forum) that someone got it installed at a dealer. This seems like one of those things where you could get a different answer from someone else at the same dealer depending on when you call.
  15. RightOnTime
    RightOnTime Senior Member
    758
    1,626
    183
    Kidnapped in OC, CA
    The RSB fits like a glove on my Plug In! Toyota's part number for the RSB has not been updated for compatibility for the PIP. This was reflected from the response from the parts guy.
    Overall the RSB did improve the handling characteristic of the car without sacrificing ride comfort and is a good investment!
  16. Christopher O'Brien
    153
    79
    Toronto
    2013 Prius Plug-in
    A good and helpful conversation, lads! I'm getting all of the above-mentioned items for my PiP, and I'm also getting some lowering springs which I'm having the devil of a time deciding on because it's a bit scary for us PiP-ers due to our heavier rear ends :eek:.
    I have to say that I have received little good info from my dealer about any of these items, even the TRD RSB, an official Toyota part! Maybe it's all down to whether or not one's dealer has any real car guys on staff, or perhaps it's just that there's an official Toyota policy for staff members — even if they are real car guys — not to get involved with enthusiastic owners like us, as if doing so might cause Toyota some sort of trouble.
    Actually, the company is a complete mystery to me in another way, too. I'm a hard-core environmentalist, sure, but I'm also a hard-core motor racing fan, and I'm completely baffled by Toyota Canada's (and Toyota USA's) seeming total lack of interest in the amazing success of the company's own TS040 hybrid prototype in the World Endurance Championship (toyotahybridracing.com). The car has won the first two races of the series (beating Audi and Porsche in the process), but not a word on Toyota Canada's website, and only news about NASCAR, drag racing, off-road etc. on Toyota USA's racing webpage. Strange...
  17. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
  18. DadofHedgehog
    681
    281
    northern Virginia
    Yes, absolutely and for the better.
  19. Alyn99
    37
    2014 Prius Plug-in
    Finally did some upgrades. I installed Mike500s front brace and his box version center brace. Install went smoothly, slightly filed down one hole on front for easy fit and did not need ramp. Noticeable difference on my 2014 PIP immediately. Ride was firmer in a good way. Car turns better, like it's on rails. My main concern was the lateral twist I was feeling when the Ice started each day. This lateral movement is gone now although I still feel the ice kick in slightly in terms of a vibration because of the stiffening of the suspension. This I can live with, just hated the sideways lurch I had without the brace. The ride is firm, a bit more abrupt in an uneven parking lot but much better on the highway and on the twisties. Am happy with the upgrade. Don't feel the need to go further. The strut tower and rsb are pretty pricey and I'm not feeling the need for better handling. In the end the Prius is what it is and the thing I need most when cornering is more Hp and that's not going happen with the PiP nor should it. For 180 bucks my suspension upgrade is done. Rude person's is a great guy. Walked me through the install, a wealth of info. Pretty pathetic he is banned from selling here. This new website "upgrade" is garbage, plastered with ads, mostly annoying, none of them helpful, can't see the posts for the popups, yet a guy who can really contribute is persona non grata. Sad.
    ELYKB and Tracksyde like this.
