Weird sound when car is off. Has anyone had this issue?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by legoadan, May 24, 2014.
  1. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    I drove my car on a short roadtrip yesterday. We drove 75 miles to one direction, were there for 5 hours and then came back on the same 75 miles. Everything was fine. Now when I got home I went to sleep. Now by random chance, I got up 7 hours later and went to go check on my car. It was locked as I always leave it and the keys were NOT in the ignition. But there was a distinct electronic sound coming from the battery. Like a small motor running. It was odd, does anyone know what this is?
    robertmaria likes this.
  2. Beachnut
    Beachnut Member
    185
    43
    Your car is purring, and wants you to go for another ride! Just tell it a firm NO, STAY, or it will get worse and worse!:)
    legoadan likes this.
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    There are many noises a Prius makes while off, yours sounds like the gas tank integrity check to make sure there is not a leak.
    legoadan and xpcman like this.
  4. bisco
    52,341
    prius is never 'off '.:cool:
  5. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    Ahh, okay Thanks guys.
  6. citroenjohn
    citroenjohn Active Member
    139
    103
    Mid-Michigan
    Others on this forum have said the sounds are the Prius C communicating with the Mother Ship. I'm convinced that is the cause of all the sounds.
  7. Mendel Leisk
    41,854
    With our reg prius I've noticed sporadic hum/click/whir, for less than 10 seconds duration. Never a steady humming sound though, sounds fishy.
  8. robertmaria
    robertmaria Member
    202
    please DELETE this account
    2014 Prius c
    actually the Prii are NEVER off is correct. it may have been the evaporative emmisions canister emptying itself, or the brake fluid accumulator charging itself (like it does when you first open the driver's door in the morning). the car is constantly checking itself. very intelligent,,,
  9. firstrival
    firstrival Member
    102
    There are other threads about it. It's the battery cooling fan. Runs for 10 minutes and starts 5 hours from the time you last turned off the car.
